Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Water leakage in dishwasher? Cant turn on. Model LD-12AW2.
The rubber seal for my dishwasher had been removed by a family member. I did not notice this and turned it on. Half way through the cycle I stopped it and checked to see as it did not sound right. I noticed the seal missing, so I found it and replaced it. However I have not been able to restart the machine or cycle. I have tried powering off, and starting a new wash. I can select a cycle but then it just beeps and does not start.
  • LG Master
  • 909 Answers
POSSIBLY REMOVE THE SEAL AGAIN THEN RETRY. IF UNIT STARTS THEN YOU KNOW DOOR LIMIT WAS NOT CORRECTLY ACTIVATED. THEN REINSTALL RUBBER AND RETRY.
Posted on Aug 22, 2007
    President:
  • 1,462 Answers
Possible you have not pushed seal in far enough hence door not closing fully. press fairly hard and see if it then starts
Posted on Jul 09, 2007
Model No. LD-12AW2: control panel flashin PE and not allowing machine to be set or start
The PE error code indicates that the machine has a water pressure sensing error.
Check and clean the filters on both sides of the inlet water line.
Mar 28, 2011 | LG Dishwashers
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
My LG dishwasher - model LD-12AW2 has 'E1' alert & won't work
This sounds like a anti flood activation due to water leak / spill detection. This device (polystireen float and micro switch) at the base of the washer detects any water leak and stops the washing cycle once water leak activates the switch via the float. Check if any water at the base of washer is cuasing the float to activate the switch. Rectify any leak / spill (normally a pipe / clamp) and this should solve the problem.
Mar 26, 2010 | Dishwashers
I keep getting an E1 error on my LG LD-2120W model dishwasher, can you advise what this means so l can either fix it or get it fixed. Thank you
leakage Error E1
  • The excessive RPM of Washing Motor happened during Washcycle due to water leakage.
  • Water leakage in Hose connections.
  • Water is leaked by damages.
  • The Motor Water Seal leakage of Sump assembly.
  • The height of Drain Hose connection
  • (sink-Drain Hose) is not over 20 .
  • Impeller of the Washing Pump is worn away.
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
fix it to the recommended Height. Replace the Impeller of the Washing Pump.
Sep 27, 2009 | LG Dishwashers
LG DISHWASHER LD-12AW2
ae unknown code,,,but ie that means uinit is taking to long to fill,,your inlet screens are clogged or the water pressure is to low...kinked hose...onthejob
Jan 19, 2009 | LG LDF6810ST Stainless Steel Built-in...
LG DISHWASHER WORKS BUT VERY NOISY MODLE:LD-2040WH
The main water pump on this model does not last long. The water seal between pump and motor starts to leak that result in the adjacent motor bearing corroding and eventually failing, resulting in excessive noise. Later the water leak becomes so bad that it triggers the "E I" water leakage display and prevents it from completing the program. The pump and motor is sold as one unit and the whole unit must be replaced. I have tried to replace the faulty bearing and repacked the rubber seal with silicon grease but with no success. If anyone have repaired the water seal successfully please let us know.
Jun 15, 2008 | LG 24 in. LD-12BW5 Free-standing...
Water leaking out of bottom of door
There is a rubber seal that runs along the bottom of the door. If you carefully run your hand along there just to see if it is all even. Sometimes they get out of place and you can push it back and then closing the door it realigns itself and all is good. If the seal is damaged, you have to replace the door liner as the seal is attached.
Sgt 48
Oct 24, 2007 | LG 24 in. LD-12BS6 Stainless Steel...
HE error code on an LD-12AW2 dishwasher
also check the back of the pcb and see if the plastic case is melting.
Sep 21, 2007 | LG 24 in. LD-12BW5 Free-standing...
Lg dishwasher LD-12aw2
IE is a INLET ERROR. Possible causes ¥ The Water Tap not opened.
¥ The Inlet Hose is kinked.
¥ The Filter of inlet valve clogged by
impure water.
¥ The Inlet Water Valve is normal ?
¥ The water pressure is very low.
( below 0.3 kgf/ )
Possible solutions ¥ Open the Water Tap.
¥ Repair the Inlet Hose.
¥ a) Close the Water Tap.
b) Unscrew the Inlet Hose (Inlet
Valve side)
c) Clean the Filter of Inlet Valve.
¥ Replace or repair the Inlet Valve.
Feb 28, 2007 | LG 24 in. LD-12BW5 Free-standing...
Ie problem on lg dishwasher
take off the water inlet valve and clean the little plastic filter. Hard water builds up a white scum type of substance.
Oct 21, 2006 | LG 24 in. LD-12BW5 Free-standing...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
176 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
