Question about Canon PowerShot SX20 IS Digital Camera
Canon SX 20 suddenly died
Hi, I picked up camera, turned it on and a message telling me to change batteries came up. I knew they should be good, but I replaced anyway. And I'm sure the battery door is securely shut, despite the difficulty in doing so. I wondered if there is a reset method? Or? I bought it in 2010 and used just last week. Thank you for any help.
  • Linda L Mann Jan 15, 2013
    Hi Mohamed, Thanks. I did insert NiMH batteries but still dead. I'm going to try some other options I've read about when I have time. Appreciate your reply.
    Sergeant:
  • 321 Answers
Use NiMH batt
Posted on Jan 10, 2013
t00nz
  • 4738 Answers
SOURCE: Brand New Canon Powershot A1000 IS battery power always low
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pictures in a digital camera. Some may also have reached their shelf life, and though right out of the package may even have problems just powering startup of the camera. Digital cameras that use AA's for the most part should only be used with rechargeable NiMH batteries. If you read the camera's instruction manual concerning batteries, you may see the same recommendation.
Keep in mind rechargeable NiMH batteries will save you money in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may be angry with yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
Posted on Jun 23, 2009
t00nz
  • 4738 Answers
SOURCE: My canon powershot a570 is not powering on despite changing the batteries. Any suggestions?
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
http://camerarepair.blogspot.com/2007/11/simple-fix-for-dead-cameras-that-wont.html
Posted on May 23, 2009
SOURCE: I have a Canon SD1000 battery pack issue.
I have a Canondigital ixusi which had the same problem and I purchased three new batteries, but found that all of them showed the "replace battery pack" message when fully charged. I have solved this problem by cleaning all the terminals on the batteries and in the camera very thoroughly with alcohol and Q-tips. Even though the terminals look completely clean, there must be a slight film which is preventing good contact. The contacts in the camera are spring loaded and I suspect they are not making a very good conection to the battery so any contamination is making a high resistance to the flow of electricity. Hope this helps - it worked for me.
Posted on Nov 27, 2009
SOURCE: Canon 5D won't turn on
my 5D have same problem 2......how much$ if i sent my 5D to canon and replace the power supply unit?
thx
Posted on Jan 05, 2010
1joester2
  • 74 Answers
SOURCE: battery door replacement
Does this mean you have a replacement door already?
If so, you will need to figure out how the camera comes apart. This is not always easy to do. I suspect there will be screws or snaps hidden. Improper dis-assembly will cause damage to the case and/or finish.
I would contact Canon and ask if there are any repair shops near you that they could recommend.
Joe
Posted on Mar 09, 2010
When I switch it on, it keeps saying "Change Batteries". Can only view previous pics and get to the menu. Cannot take pictures
hi, use alkaline, lithium batteries or high capacity nimh batteries
this should we have tried and it works , hope it works for you also
Jul 04, 2016 | Canon Powershot Sx150 Is 14.1 Mp black...
How do i fix low battery problem, I get about 5 o 6 photos before it shuts down to low battery and i want to change the batteries.
Some batteries, although the correct nominal voltage for the camera, are not powerful enough for continued use. I have found the best solution is to use rechargeable NiMH batteries of at least 2100 MaH, preferably 2500 MaH.
Jun 07, 2016 | Canon PowerShot SX 160 IS Red 16.0...
My computer can suddenly not detect my camera anymore. Canon sx 200 is. What do I do ? I allready deinstalled all canon software but nothing helps???
Welcome to FixYa
Dear User
Try in another Port[If you are Using USB port]...Check your 'Connectivity Cable'[If need Change it]...
Uninstall Driver and Reinstall it after a Restart..
Try in Different Computer to Confirm still Working .....
Hope this Helped you...Thanks for Connecting FixYa..
Sep 07, 2010 | Canon PowerShot SX 200 IS Digital Camera
Sir, I have a CANON SX 120IS POWER SHOT DIGITEL CAMERA it is having a problem.after putting BATTERY in to the camera after ewitching on after sometime (2MINIUTES)it is showing battery low change the...
Please use recharrgabel battery with above 1000mA rating and your camera will work for amny shots before a recharge is needed. use good branded battery with the respective chargers. This is important. Chek on the side of the battery to find this rating ,ordinary battery has only about 150mA and will not click even one shot. I hope this helps you decide. Good Day
Aug 16, 2010 | Canon Cameras
I have a digital camera powersot SX 200 lswith 10
Here is the address of the Canon service Center (Ahmedabad):
101, SHIVALIK-10, OPP. SBI ZONAL OFFICE, NR. GRAND MALL, S.M. ROAD, AMBAWADI,
AHMEDABAD
GUJARAT
Tel : 26306293, 26306294, 26306295
Fax : 98242 63285
Thanks for using FixYa
Jun 28, 2010 | Canon PowerShot SX 200 IS Digital Camera
Canon A400
Having using standard LR6 batteries in a Canon before you will only get 3 or 4 pics max before it drains the batteries. You really need high power AA's like 2300mAH+ rechargeables for any good performance or Lithium AA's
Aug 28, 2008 | Canon PowerShot A400 Digital Camera
Canon Powershot SX 100 digital camera
the lens is broken and will need to be replaced, there are many camera shops on line that fix digital cameras...just pick one and get a quote.
Jul 22, 2008 | Canon PowerShot SX100 IS Digital Camera
Canon powershot A510 all of a sudden no power??
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try. Recommend trying first the one listed that describes removing the memory card before powering on the camera:
May 11, 2008 | Canon PowerShot A510 Digital Camera
Canon A95 "Change Batteries" problem!
I have this problem as well. I thought it was a problem with my NiMH batteries. So, I bought a volt meter to make sure the batteries worked. I have 8 AA NiMH batteries. I charged them all up and tested them with the volt meter. They were all good to go. However, no matter what I put in the camera one of two things happens:
1. I get the "change batteries" message.
2. I don't get the message, but the next time I check the camera (a few days later), one of them is totally drained.
Something is very wrong and I plan on contacting Canon.
Nov 30, 2007 | Canon PowerShot A520 Digital Camera
Canon PowerShot SX20 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
