Question about Nautilus T516 Treadmill
Nautilus T516 E7 error - Nautilus T516 Treadmill
2 Suggested Answers
Daniel S
  • 4323 Answers
SOURCE: Our Nautilus T514 treadmill stops
Hi
Try clearing the error by unplugging the treadmil. if it doesn't clear then try and press stop button for 10 seconds. Insure cable is connected securely to Console. All wires in cable should be intact. If any are cut or crimped, replace cable. If error doesn't go then lubricate the treadmill as given in this manual---
Nautilus Treadmill 514 Manual
Hope this helps... If it does please do not forget to accept the solution or post back for assistance.
Daniel
Posted on Sep 04, 2010
My sharp copier AR-5316, is showing error message E7. How do I clear it and solve the problem. Please I need urgent assistance.
For proper understanding of the error meainig it is necessary to obtain a Subcode of the error by pressing START at the moment of displaying error. E7-02 and E7-16 means Laser unit problems, E7-01 problem with memory, E7-10,11,12 Scanner problems Posted on Aug 16, 2016 -2017
Jul 29, 2016 | Sharp Ar 5316
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
I have E7 and machine won't work????
E7 sounds like an error code. First step is to look it up in your owner's manual.
Aug 26, 2014 | Singer Sewing Machines
Nautilus T515/T516 treadmill stopped suddenly while I was running on it. I heard a snap right before it happened, so that made me check the belt, but that was fine. The screen reads E1 when I turn it on....
see the video and lube the deck belt. Use silicone or wax see your owner manual.
ERR 1 - Motor Movement
ERR1 indicates a speed issue. In this case, the motor speed as reported from the optic sensor differs
from the speed setting.
Analysis: Optic sensor signal issue -- Either the optic sensor signal is not right, or it is read incorrectly, or
the signal is not reaching the display.
God bless you
May 30, 2013 | Exercise & Fitness
I have an E7 on my treadmill its brand new whats wrong lubricated it
1= this errro means 2 alternatives:
a= display board is erratic: adjust the reed switch see the diagram attached, tight the wires connector, +ribbon cables from keypads and clean it, unplugged the mahine
b) the elevation motor : lube the elevation motor gear+shift adjust the POT for better improve, test the motor voltage for defective.
see the diagram
God bless you
7_20_2012_9_42_10_am.gif7_20_2012_9_42_28_am.gif7_20_2012_9_42_46_am.jpg7_20_2012_9_43_07_am.jpg
Jul 19, 2012 | Nautilus Exercise & Fitness
The machine stopped suddenly while it was in operation, i found the fuse in the power cable burnt, i replace the cable and tried to operate it again it worked for less than one sencond and it stopped...
Dear Sir:
You have a Short Circuit:
The short circuit only you can eliminate by usin VOM,
a) Isolate the power cable b) The main motor c) The power supply d) The main motor board e) The transformer.
You can also view my personal TIPS for helps.
sincerely. God bless you
ernesto cuadra
managua, nicaragua. c.a.
Mar 08, 2012 | Nautilus T516 Treadmill
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
E7 problem
E7 codes deal with the optical scanner unit and or the laser unit. It could also be the lamp in the scanner unit. The E7 is the main code. There is a sub code associated with it. To view the sub code hold down the start button. Below is a list of specific codes and their meanings:
E7-02: LSU trouble
E7-10: Shading trouble (Black Correction)
E7-11: Shading trouble (White Correction)
E7-12: Shading Trouble
E7-16: Abnormal laser output
If it is a laser (LSU) issue then the LSU may need replacing.
If it is a shading error the first step is to remove the platen glass carefully (with the power off because the inverter board). There is a thin white strip on the bottom side of the platen next to the slit glass. Clean this white strip with a soft cloth and a small amout of isopropyl alcohol.
Dust on the optics can also cause shading reference errors so gently blow off the mirrors with canned air.
Perform the following key procedure to reset error:
"#" key, Interrupt key, "C" key, Interrupt key
"1" key, "4"key
Start key, "CA" key.
See if unit cycles and comes back up. If not turn off and then back on the main power.
If error reappears on site technical service may be required.
Jan 06, 2008 | Sharp AR-5316 Advanced Digital Imager...
Nautilus T516 Treadmill Logo
57 people viewed this question
Top Nautilus Exercise & Fitness Experts
David Payne
David Payne
Electro Med Services...
Techmotionusa.com
Techmotionusa.com
Are you a Nautilus Exercise and Fitnes Expert? Answer questions, earn points and help others
