Question about Samsung LN55B640 LCD TV
I seems that the tv received power because it has red light on but it won't turn on please help me
  • 8457 Answers
SOURCE: TV won't turn on, red
Tv have a power supply board problems.That the board where the tv power a/c cord plug into it.Must take the aparts to troubleshoot and repair or replace a whole refurbish tv power supply board.U have all the tools and understanding basic electronic also can do basic soldering work?Yes?Take the tv aparts and check the tv power supply board carefully looking for any dying and leaking capacitors components parts.These dying and leaking soon to be dead capacitors parts are alway bulges up or puffing up onto it tops.These dying capacitors components are the causes and the problems for tv power LED indication light flashes and clicking noises.U must replaces all these dying and leakages capacitors components parts to fixed ur tv power supply board.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Aug 31, 2011
caroldon
  • 17130 Answers
SOURCE: TV won't turn on red lite is on
In most cases the standby light might blink with different rapidity to indicate a fault relevant to the processor. It is possible that most of these indicate that there are errors in the processing section . Since there is a possible short or leak in the circuit the output driver section can take in huge current to trip the SMPS or from advice from the micro processor. Remove the power plugs and make sure that high voltage sections are discharged of the potential stored in capacitors. Look for visible signs of leak or of busted capacitors. Look for bulged capacitors or damaged components- burnt or busted. Use a multimeter to check the continuity or shorting in components, if so detach from circuit and test . If the voltage builds up and the set power ON and then shuts up then the suspected section must be checked in detail.
The processor must have the +5 voltage to the function properly , the +B and secondary voltages also must be checked to infer the fault. Trace with caution and in running through the signal path , circuit trail.
In some cases the fault can be related to faulty connections or poor soldering joints. Here are some tips to check out weak solder or heat related faults:
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance.
The best way to check for loose connections is to tap lightly when the set is powered on , If there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, use a good soldering iron to solder all suspected points.
Sometimes the fault occurs when the set warms up, if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault.
Based on the above method you must be able to locate the area of fault and solder the sections. Sometimes large IC's- ones with more pins- tend to have drying in some pins and so cause faults related to the IC's protocol. Have a rough idea of looking into the areas to reduce the time of probing.
Check for tips to look into the SMPS unit with some of my tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Thank you for using Fixya.
Posted on Sep 15, 2011
  • 302 Answers
SOURCE: My Samsung LN40A650A tv won't
if you have no lights at all i would check the power supply.
You can get get parts for this tv at www.interliquidparts.com
Posted on Nov 26, 2011
  • 1684 Answers
SOURCE: Samsung TV won't turn on. Red light is solid, won't blink when pressed. All capacitors seem fine (none swollen or vented).
That model is covered under a class actions lawsuit settlement over bad power supply boards. You need to contact Samsung about this and get a warranty claim started, even if the original warranty is over the settlement terms will cover parts and labor. You can get additional information about this along with contact information here: http://www.ccl-la.com/blog/index.php/samsung-has-reached-a-settlement-in-class-action-lawsuit-over-faulty-tv-power-supplies/
Posted on Sep 25, 2012
  • 35599 Answers
SOURCE: PN50B550T2FXZA won't power up
The continous red light merely means power is getting to your TV. From your description, it is likely the internal power supply has failed
Posted on Dec 31, 2012
Phillips plasma led lights tv won't power on
What you describe is symptomatic of power supply trouble. A capacitor that isn't bulging or showing signs of leakage could still be defective electrically. Troubleshooting using suitable test equipment will be necessary
Jun 10, 2013 | Televison & Video
Tv won't turn on
Replace the power supply board the blinking power indicator is usually indicating the power supply needs replacement or repair. You can get the replacement power supply boards from www.tvcircuitboards.com
Oct 20, 2012 | Samsung LN-S3241D 32 in.LCD HDTV
Proscan 40LC45S screen flickers, red light flickers, won't turn on
check bad component parts at the power supply board as will as burnt parts.
Sep 07, 2012 | Proscan 40LC45S 40 in. LCD TV
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
My LG TV red light won't turn on. although the plug fuse and the remote OK
Try manually pressing the power/standby button on the tv (side or bottom) the red light should appear, most modern tv's will turn on simply by pressing the channel up or down on the tv itself.. But unfortunately in most cases, this seems to be an internal surge and needs a professional to inspect..
May 14, 2012 | LG 42PG20 42 in. Plasma HDTV
** TV won't turn on.** No picture or sound. Please Help !
If the red light won't come on it is not getting power.First,try plugging it in to a different outlet,or unplug one of the gadgets you know is working and plug the tv in there.You are simply switching.If you know that there is power coming from the outlet and it still won't come on then you'll have to check the cord;don't go much farther than that without expert help.
Apr 04, 2012 | Televison & Video
Red light comes on but power button won't turn it on
Please confirm actual brand and model as it is not clear what set you have
Mar 11, 2012 | Televison & Video
The infrared receiver light just keeps blinking red and TV won't power on. Tried unplugging for a little while but didn't help.
kindly count the blinking led to diagnose where the fault came from..
also try the initial check....open the back cover and inspect the power supply board for any bulged capacitors inside..
Jan 18, 2012 | Polaroid 4241-TLXB 42 in. LCD Television
My remote will not cut on my Bose Cinemate system. I have changed the batteries in my remote and the red light on the receiver is illuminated, so I know the system is operational, . I've also unplugged...
It seems to be a common misconception that the remote is necessary to turn a device on. All devices have hard-wired power controls. Does THAT work? It is unclear which device (remote or the Cinemate) is malfunctioning. If the Cinemate won't turn on by its own power switch the remote won't magically bypass whatever the problem is.
The Cinemate Manual offers some steps to take if it won't turn on, as well as other guidance.
Bose.com
Jul 31, 2011 | Audio Players & Recorders
Samsung LN55B640 LCD TV Logo
52 people viewed this question
Henry  Thomas
Henry Thomas
