Question about Home
Oasis whirlpool tub switch removal
The tub motor won't turn off so I want to remove the switch to clean and inspect the air tube.
brainyass
  • 242 Answers
SOURCE: How can I unclog plumbing in whirlpool tub used to clean dogs?
Depending on how mechanically inclined you are, take apart the tub and clean everything out. No easy task, I know, but who want old dog hair floating around? That will be your best bet.
Posted on Oct 24, 2008
PartsCenter
  • 125 Answers
SOURCE: Kohler bathtub spa does not work at all
If the air tube is still connected to the air button on the side of the tub and you are pushing it with no results then either the motor is no good, the air button is no good or the air switch in the box is no good.
process of elimination, start with the pump. take the switch off the motor or out of the box and make sure you can get the motor to come on. If the motor comes on then move to the air switch and hook it back up and see if you can blow into the air switch with a new air button or a straw and see if the switch will activate the pump. if it does then you most likely have a bad air button ($12). If you cannot get it to activate the pump then the air switch is bad ($21).
Posted on Feb 24, 2009
  • 80 Answers
SOURCE: Jacuzzi whirlpool, air on/off button on tub
If it is a air button that pushes in and comes back up, there is a good chance that the switch (which is mounted on the pump/motor) is bad. If the switch is a touch button on a key pad, the problem is in the control box for the pump/motor.
Posted on Sep 05, 2009
  • 80 Answers
SOURCE: I have a 16 year old Aker whirlpool tub. Recently
If it is an air switch, the switch itself is located on the pump.Locate the air line that goes from the button and follow it to the pump. It is possible to replace the switch with the pump in a accessible location. If not remove the pump and replace the switch on a work bench. The switch is inside the black or blue box located on the pump motor. Hope this helps.
SOURCE: pump will not turn off. Have removed tub face.
If the Pump will NOT turn OFF, then the switch, must have failed, in the ON position, I suspect you will need to replace it.
Posted on Apr 28, 2010
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool does not turn on. Kohler Model K-1474-V
The chances that is problem you are experiencing is related to the suction cover is extremely remote. The suction assembly doesn't have anything to do with the tub motor operating.
The issue is most likely with the motor not working or the air switch in the motor malfunctioning.
What does the control look like that you use to turn the pump on/off?
Is it an air button or an electronic switch?
Jan 29, 2013 | Kohler Home
The air switch on my Kohler whirlpool tub, when depressed will not start the motor. However, if I take the plastic hose off the switch and blow into it, the motor starts fine. I've replaced the ai
There are Air Switches (at the motor or control box) and Air buttons (on the spa/bath side). The vinyl tube between them is the only other component to the 'switching' on/off a hole in the tube may cause this problem.
The air switch has a diaphragm which is activated by the air in the tube when the button is pressed. If the air pressure is not sufficient the switch will not operate.
As you've replaced your Air button, you might want to change the tubing and either adjust the Air Switch or replace it. The switch only needs 1-5psi to activate so the pressure from you blowing into the tube can damage the diaphragm in the switch.
Jul 04, 2012 | Home
My tub motor does not come on when i press the air switch to turn it on. I did not see any leaks in the tubing, and there is power to the GFI outlet. The system hasn't much use so i do not think that...
Either the button is bad or the air switch in the back of the motor is bad. Blow into the switch on the back of the motor and if it comes on then you know the button on the tub is bad. If it doesn't come on then you know it is that switch.
US Parts Center
Aug 31, 2011 | Jacuzzi - Whirlpool - Corner - Gallery...
Whirlpool top loading washer, LXR9245EQ2, quit agitating, spinning and makes a clacking noise, pump looks like it's still holding the water in the tub though and won't pump out?
There are two clips that hold the pump to the motor, remove it and inspect, turn pump axle in either direction. If not replace the pump. However if you remove it you may find a sock or something in which case you can remove item and put back into service. If jammed you need to replace with a new pump. Good luck, masta tech
P.s.if water remains in tub it has something blocking it, be ready to capture any water in tub when removing hose clamps. If it a small amount you may be able to just lean it backward to hold water.
Aug 21, 2011 | Whirlpool LSR5132PQ Top Load Washer
My washer wont fill with water what seems to be the problem
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 10, 2011 | Samsung WF210AN Washer
What problems will the water level switch cause.
Most times these never fail. The problem is with the tubing going down to the base of the tub. The switch has 3 wires. A live wire and a wire to the water works and another to the motor works. So this switch is either going to allow for fill OR run the motor once the desired water level is met. It works on air pressure. So if sediment is in the base of the tub the air pressure won't build and the switch won't activate causing the tub to overfill. Sometimes a hole gets chewed into the tube. The case gets jammed up against the tubing after a repair. Or the tube simply vibrates off. Swing up the controls and give it a look see. Remove the tub from the switch and clear the sediment by giving it a good blow. Re-attach it and if any water is in the tub pump it out so that pressure can once again build in the tub.
If your switch turns out to be broken it would be rare indeed. themobilian_2772.jpgthemobilian_2773.jpgthemobilian_2774.jpg
Aug 07, 2011 | Whirlpool LSQ8000LQ Top Load Washer
Water fill level switch stops at Med and will not fill to Large or Super. Now it won't work at all and keeps filling, and will not agitate. Help! It's a whirlpool LSR7010PQ2
https://www.whirlpool.com/digitalassets/MLPDF/Repair%20Part%20List%20-%208180895.pdf
hello chris, my name is Mike. You're in luck because this should be a fairly easy fix. Above is a link from the whirlpool website that shows the parts for your washer. If you scroll down to about page 3, you'll see a horizontal rectangular piece that is part of the console. Part number 12 is your water level switch.
This switch is easy to see if you remove the console of your washer, it has a clear plastic tube connected to it. This tube has air in it, and is connected to the lower portion of your outer tube. As the water fills, more air enters the tube (increasing pressure), and tells the washer when to quit filling per say.
You need to inspect the tubing from top to bottom to make sure there are no kinks, or a lot of the times it has just come loose from the switch, or tub. If it has you can reconnect it and retest the washer.
A defective pressure switch can interfere with the cycles that depend upon the switch to indicate when water has filled or emptied from the tub. Can also cause overfilling.
If everything is connected, there's no water in the tube, then the switch is more than likely just bad and needs to be replaced.
Chris, if you are unsure and you want to test it to be sure, just contact me anytime. My email is michael_lee596@yahoo.com
You will need a Volt ohm meter or a continuity tester to actually test the switch to MAKE SURE that it's bad. I can almost tell you with certainty that it is though.
Feel free to contact me anytime, and I'll be more than happy to help you out.
thanks
Mike
Jul 19, 2011 | Washing Machines
My american standard jacuzzi tub doesnt work. It's plugged in, but the push button doesn't engage anything. It worked before I removed it to install ceramic tile around and under it.
check the air tubing coming off the back of the motor. that tubing should connect from the air switch on the motor to the bottom of the air button on the top of your tub.
if it is not connected then it will never turn on.
Feb 03, 2011 | American Standard Home
Home Logo
106 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
