Question about Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter
Fortress 1700 DT scooter does not move and beep signal starts when ever a signal or horn is activated
4 Suggested Answers
SOURCE: We have a Fortress Scientific 2000 electric
Your break release shifter is in the push the scooter mode. Put it back in gear and the horn doesn' beep and it should run..
The horn beeping is the alarm to tell you the break release is on.
It is usually located under the seat on the body of the top of the battery housing. Looks like a stick with a ball on it.
Posted on Dec 18, 2010
wcdoc1953
  • 280 Answers
SOURCE: I have a gogo three wheeler and some times when i
The go go controller has a controller which will give you a specific beep code to indicate the problem with your scooter. From what you are describing, it seems that the throttle potentiometer is out of neutral at start-up. The controller needs to electrically sense the throttle pot is in neutral (center of left and right) to start. By turning the scooter on and off you are jiggling the pot enough to get it to zero out(go to neutral).
Please get back to me with the exact model of the go go and with the exact number of beeps in the error code and I will be able to diagnose the problem in a more definitive way.
The most common error codes involve the throttle pot out of neutral at start-up and the brake freewheel lever is in freewheel.
You can see if the throttle pot is out of neutral by moving it slightly in either direction with one hand and turning the scooter off and on with the other hand. If the scooter works by this slight adjustment of the pot, then this part needs to be replaced. Hope this helps.
Posted on Jan 31, 2011
  • 11800 Answers
SOURCE: When I turn on the vehicle the battery light
The beeping indicates a failure of the motor.This is caused by either the brakes are seized or the controller for the motor has failed.
In the first case just remove the rear cover and , using a big flat screwdriver, just push the brake pads away from the disk. In the second case there is nothing you can do, you will have to contact the manufacturer - Handicare - or the dealer from which you have purchased it and find out which is the closest location that can service your scooter.
Posted on Jun 06, 2011
On the power bar first 2 bars flash and the scooter stops it is fortress 1700 ta.
Do you have the owner's manual to interpret the flash code?
It could be the batteries need replacing..the most common
problem with scooters.
Jan 24, 2015 | Health & Beauty
Why does my fortress scooter beel when key is in
I had an old 3 wheel Fortress 2000 a couple years ago.
On mine, iIf the lever at the back (go-nogo) is in the neutral position
(drive not engaged) the buzzer would beep. Go to the back
and move the lever, so the drive is engaged.
Nov 02, 2014 | Health & Beauty
Fortress scooter 1700
i need my stc sim pin number nuber is 0534298898
Jan 14, 2014 | Health & Beauty
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
Jan 12, 2013 | Electric Mobility Health & Beauty
When I turn on the vehicle the battery light indicates a full charge but the beeping sound will not stop and the vehicle will not go! It is a Fortress 1700.
Jun 06, 2011 | Electric Mobility 4 Wheel Power Electric...
We have a Fortress Scientific 2000 electric scooter that hasn't been used for several years. We put in new batteries, it shows fully charged, comes on and has a steady beep, but won't go forward or...
Oct 03, 2010 | Electric Mobility Mobility Electric Power...
1700 Fortress Scooter won't go forward or backwards. The beeping is continual and the driving light comes on if you turn it on. The brake is in brake release mode. The battery is charged up? What is the...
Hi. Has the machine been in regular use before the fault occured? You say that the brake is in brake release mode, this mode is only ever used if you need to push the scooter by hand. It releases the brake on the motor, and also operates a switch to disable the controller from driving the motor. It does this because it would be to dangerous to drive the scooter with the brake disabled.
Move the lever back to its correct position. If it still does not work, then the disable switch might be faulty, or it might be a different fault such as a stuck brush in the motor.
Is this machine produced by shoprider ( Phisang ) of Taiwan.
Please let me know how you get on. Neil.
Jun 07, 2010 | Electric Strider Maxi 4 Wheel Mobility...
Electric Mobility 4 Wheel Power Electric Motorized Wheelchair Scooter Logo
673 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
