Question about Sony STR-D990
Str d990 left channel not working - Sony STR-D990
Sony str-de185 left channel very scratchy and poor; not speaker, wire, or connections
Could be an open resistor in the amp for that channel. Might have to have a pro look at it.
Mar 26, 2013 | Sony STR-DE185 Receiver
Sony reciever distortion
it could be an overload in the output tranformer
Jan 17, 2012 | Audio Players & Recorders
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
Str-gx800es sony receiver problem- right channel speaker sound is 'static', low and distorted. I have checked checked all speaker and output/input source cable connections with no luck. All left channel...
If you have checked the speakers and wiring, the right channel has a audio driver or output problem, which explains the low volume, static, and distortion. A service technician will be required to fix the receiver so it will balance the left side.
Jan 10, 2011 | Sony STR-GX800ES Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
No sound out of front left speaker
front left channel power amp needs rpair
Jul 08, 2009 | Sony STR-DG510 Receiver
Optical digital cable connection ?
It only works through DVD setting
Jun 20, 2009 | Sony STR-DE545 Receiver
Only one speaker working on my str-de675 receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
May 03, 2009 | Sony STR-DE675 Receiver
Sony STR-DE525 Left Rear channel not working
Most likely the amp for that channel is defective. If memory serves me correctly, there is a small amp chip mounted on the heatsink that is for both the left and right rear. I would change that first. It should have about 5-7 pins.
Dan
Nov 30, 2008 | Audio Players & Recorders
Left channel is out sony STR-D511
Had the same problem but found simple solution. I just reconnected the speakers which were on "A" connections to the "B" set of connectors immediately below - problem solved!
Hope this works for you.
Stuart
Feb 21, 2008 | Audio Players & Recorders
Sony STR-D990 Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
