Question about Kenmore Elite HE4 Electric Dryer
Kenmore Dryer I have a Kenmore 110-765-12695 that works but doesn't heat up. Any ides? The ignition light won't stay lit for more than 4 minutes.
  • 163 Answers
Hi!! you have a problem with your coil boosters shown here change them and you should be fine..they are located above the gas valve good luck..Kenmore Dryer - e10b2d9.jpg
Posted on Jan 21, 2009
  • 2 more comments
  • horace_abrah Aug 25, 2010
    Cannot see the drawing to and I don't see coil boosters. However I see the ignitor on the circuit. I have the same problem "no heat". Drawing# 3406688 Rev REL.
    1-868-678-7027
    1-868-678-7027
    Cannot see the coil boosters on the drawing. However I see the ignitor on the circuit. I have the same problem "no heat". Drawing# 3406688 Rev REL. Is the coil boosters different from the ignitor?
    1-868-678-7027
    1-868-678-7027
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
No dryer heat
If the coils are bad the unit will light with flame for 4 - 8 times then all of a sudden the ignitor will glow, kick off with no gas coming threw valve. it sounds like the high limit thermostat is short cycling the flame. This is the thermostat that sits on top of the burner chamber. remove 1 screw from the thermostat and blend it upwards away from the heat. Then plug unit back in and test to see if the flame stays on longer. Click here to see maytag dryer no heat posts. Contact me anytime here. Hope this helps..
May 20, 2013 | Maytag Neptune MDG6700A Gas Dryer
Lights but dosint stay lit
If the dryer ignites but goes out immediately, the issue is a heat sensor. if the dryer ignites electromagnetic solenoid coils which are mounted on the gas valve assembly are weak and need to be replaced. you can buy these at an appliance store. be sure to call before you take the trip and have your model number handy.
Jan 06, 2013 | Kenmore Dryers
The igniter heats and the flame lights, but it shuts off after just a minute or two. It won't go back on until the dryer has cooled down completely. Could it be the high-limit thermostat? With the...
What your describing sounds pretty much like the sympthons of weak coils that open the gas valve. It is a fairly common thing that happens with gas dryers so i have written a tip that explains in detail what happens when gas valve coils are weak.
http://www1.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_while
I hope i have helped you to fix your dryer,
GENE
Oct 09, 2011 | Maytag Neptune MDG5500AW Gas Dryer
The unit just stopped heating and drying the clothes.The burner on my LP Kenmore dryer won't light, otherwise everything else works just fine. I've have taken everything apart and cleaned out all...
Generally, with a gas dryer, there is an ignition device that heats to a specific temperature and this causes the gas to ignite. When this electric ignition fails to work, the gas will not ignite and there will be no heat. I had this happen and had to call a professional. It was a simple matter of installing a new ignition device and it worked perfectly for years. I hope this helps! If it is a new dryer, check to see if this part might be covered under warranty
Jul 28, 2011 | Kenmore Dryers
Pilot won`t stay lit
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Kenmore Dryers
Maytag neptune dryer will not stay lit. It starts up, lights, stays lit for about 1 minute and then goes out
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 09, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
Kenmore Gas Dryer ignites then stops heating after ten minutes.
If the glow bar comes back on and the gas does not light,replace the gas valve coils. If the ignitor does not come back on,replace the flame sensor.
Sep 01, 2009 | Kenmore Dryers
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
Kenmore Elite HE4 Electric Dryer Logo
144 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
