Question about Poulan Pro PP338PT Pole Pruner - Trimmer Combo
Replacing starter rope on Poulan pole saw
My starter rope broke and I can't get to it. I need to take off the clutch assembly to do this but I don't know how to remove the clutch assembly.
4 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: I need to change the pull rope on my poulan pole saw 446t
Check out the video at the link I am providing and see if it is what you're looking for. Sure hope so and best wishes.
http://www.youtube.com/watch?v=Zs91D_wln2Q
Posted on Sep 01, 2009
bbreton
  • 437 Answers
SOURCE: Need to change pull rope on Poulan Pro Weedeater
sounds like you are trying to remove the drum assembly; try a torx driver or a phillips screwdriver. There is a srew that hold that drum on and the bolt is in that black hole.
Posted on Sep 29, 2009
Testimonial: "read suggetions & took another look. Found a small flat blade screw driver would work. Appreciate the help"
  • 3 Answers
SOURCE: Trying to fix my poulan 446t rope return. I have
how to remove the starter pull cord on a palen 100 weed wacker
Posted on Jun 27, 2011
How do i remove clutch assembly on a poulan 445 pole saw ?
First you need to remove clutch drum. Inside the center is a trox that need to be loosen to remove it. Then you will to remove the spark plug so you block the piston movement using a piston stop or fill the cylinder with rope. The itself is left handed threaded and there will an indicating arrow on it as which way is off.
Jul 29, 2014 | Poulan Garden
How do I replace starter rope on a poulan 445 pole saw?
I have pulled out the spark plug and stuffed some rope into the cylinder. The piston will then not be able to travel the full distance and will keep the clutch from turning. Use rope that will not shed particles. This will let you remove the clutch bell.
How do I replace the pull cord to my Poulan 446T PRO. It's a combination of a pole chain saw (8 inch) and a trimmer.
You will take the recoil assembly off the saw. You shoud see where the knot broke off the cord in the pulley. Put the cord through the case and the small hole in the pulley and tie a new knot. Count the number of turns it takes to take up the rope. There should be a small notch in the edge of the pulley you place the rope in to wind up the spring and not take up the rope.Add one or two turns more than you counted so the rope is coiled up snug then pull out the rope from the notch and let the spring retract it.
Aug 02, 2013 | Garden
How to remove clutch on poulan pro
One way is air operated impact wrench. If you don't have access to that particular tool, you can take the sparkplug out and slip in enough rope so engine will not turn past top dead center. It will lock the crank shaft enabling you to loosen clutch nut without harming anything on the engine. When done, pull rope out, reinsert sparkplug and you're ready to go.
Nov 26, 2011 | Poulan Pro Chain Saw 46cc 20"
My Poulan Pro 150E pull cord will not engage to start the weed eater. The rope comes out adn retracts back with no problem, but there is no pressure on the clutch to cause the motor to start. There is...
Sounds like the starter dogs are broken. They are little plastic teeth that engage to turn the engine when you pull the cord. You'll need to replace the whole starter assembly to fix this.
Aug 26, 2011 | Poulan/Weed Eater No. Te475 952711797 17"...
NEED TO KNOW HOW TO DISASSEMBLE SPROCKET FROM POULAN PRO (replacing a worn sprocket)
I think it is an inboard clutch, use this as a guide to remove what you can:
R² Drive Link Inboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=YUbSIHMSSP8
The C-clips tend to fly when being removed. Please wear eye protection and exercise care.
Use this as a guide to remove what remains. Remove the rope/cord piston stop before installing new clutch; rotate the opposite direction and reinstall after piston again above the exhaust port.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check the IPL for your saw to see if any special tools are needed.
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of starter cord or nylon rope be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
Lou
If all you are doing is replacing the drive sprocket ignore outboard clutch instruction. If replacing the centrifugal clutch it is helpful.
Nov 07, 2009 | Poulan Pro Chain Saw 46cc 20"
Sep 29, 2009 | Poulan Garden
PULL ROPE WON'T RECOIL AND IS FULLY OUT
Possible broken return spring or excess junk in starter mechanism. Remove starter assembly to check out.
Jun 27, 2009 | Poulan Pro Chain Saw 46cc 20"
Chain saw starter rope won't recoil
recoil spring is broke. homedepot has a new one
May 23, 2009 | Garden
Poulan Pro PP338PT Pole Pruner - Trimmer Combo Logo
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
