Question about Zanussi ZBQ365 Electric Single Oven
Oven door Need to take the oven door off to fit new inner glass panel how do I get the door off
    President:
  • 1,462 Answers
Open door fully. there is a hinge lock - usually a little arm on the hinge which comes up. engage hinge lock, partially close door and lift off
Posted on Jul 04, 2007
How to fit the internal glass oven door which I have broken and bought a replacement
Here is a general website on how to change a door glass. Just for information, this would be the best I could do with out any information on the model you currently have. Good Luck
Inner Oven Door Glass Panel
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Apr 20, 2016 | Ovens
Please tell me if Electrolux EKG5547XN Cooker Main Oven Glass Door would fit my EOB6632U
Glass oven door is not compatible.
First of all, the oven door EKG5547XN has only two glasses, inner and outer, while the oven door EOB6632U has three glasses; inner, middle and outer.
EKG5547XN
Inner glass oven door, part number: 349 00 30-01/6, silkscreened; dimension: 456 x 323 mm, tempered glass.
Front glass oven door, part number: 349 10 45-14 / 6, stainless.
EOB6632U
Inner glass oven door, part number: 899661 92 68-78 / 3,
silkscreened; dimension: 479 x 391 mm, tempered glass.
Middle glass oven door: dimension: 447 x 380 mm.
Front glass oven door: dimension: 589,5 x 466 mm.
Dado
Mar 28, 2015 | Electrolux Ovens
Removal and disassembly of oven door
The panels on the door , specially the glass panels can be removed easily if care is taken to remove the fitting screws.
You can use a good cleaner glass cleaner to remove any dirt that has deposited on the frame and glass panels.
Once the glass is dry it can be refitted , care taken to use gloves so as to avoid hand impressions .
Dec 06, 2011 | Fisher and Paykel Ovens
Glass panel missing on grill (top oven) door?
if there seems to be a hole there and not a solid door then yes there should be glass there. try doing a goggle search on the brand . there might be a pic there to show you what is should look like.
Nov 12, 2011 | Ovens
The inner glass for a Zanussi oven is missing. Is it possible to have this replaced?
Has the inner glass come away from the metal inner door?
If yes, then there are two ways to do this.
The first is to buy a new inner door and fit it to your outer door.
The second is to get a tube of high temperature sealant and repair the existing door.
To repair it you'd have to take the door off the oven and take it apart. Easier than it sounds.
Once the door is off and taken apart, it's a case of take the glass off, clean the glass and the metal, apply the sealant, place the glass on top and then put a weight on it for 24 hours to set.
Then rebuild the door and refit it to the appliance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 04, 2009 | Ovens
Replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Tecnik oven inner glass has fell out. how do i re-fit it
i have never managed to be able to reglue this type of door. you are faced with buying a new part
Sep 30, 2008 | Tecnik TKC8525 Double Oven
The inner glass of my sons built in oven door has fallen out can you please advise how we can fix it thank you it is neff b1420
The inner glass panels are bonded to the frame with a heat proof adhesive.
The chances are you will have to get a complete new door assembly.
Jul 22, 2008 | Neff B1421 Electric Single Oven
Zanussi ZBQ365 Electric Single Oven Logo
361 people viewed this question
Top Zanussi Ovens Experts
John Tripp
John Tripp
gunfai
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
