Question about Miele CVA4070 Coffee Maker
Cva4070 milk need to be warm to steam..
When i want to steam my milk it needs to be warm if it's the temperature of the fridge i need to put it 2 or 3 time before it steam. can somebody help me ! ;)
Francois
  • Miele Master
  • 19,396 Answers
|I|f the machine is taking too long to steam an dfroth milk, and machine is not new, that is often cauised by scale on the heating element.
This can make heating time longer.
Check the manual here.
And follow procedure at page 44 on how to do descaling.
Posted on Jan 21, 2009
  • 8,197 Answers
Acording to the manual it says it will take 2-3 times to get it to your liking. I would try some skim milk to see if that makes a defrence. Here is the manual if you do not have yours. On page 16 it will tll you.
http://www.miele.com/manuals_pdf/Residential/Coffee_System/CVA4070_us.pdf
Good Luck
    Sergeant:
    Novelist:
  • 326 Answers
Change the settings manually as per required and then set it to work on the applied mode
    Genius:
  • 1,269 Answers
What you can try initially is unplug the power cable of the unit for few hours and let it reset the timer settings. Then plug it back in, check if it warms up normally.
Delonghi EC702
Even semi skimmed milk with froth if hot enough. Check the steam temperature, you may need to blow steam through the milk for longer.
Mar 06, 2014 | Coffee Makers & Espresso Machines
Miele CVA4070 Steam flow through heater blocked
when you remove the cappucinotore, ( the piece that sticks down with the chrome tube and rubber pick up tube) from the door, do you still get no steam? that piece should be removed and cleaned daily. if you dont, I would imagine that it is completely blocked with old milk and would block off the steam.
Apr 06, 2012 | Miele CVA4070 Coffee Maker
Despite having thoroughly cleaned the cappucinator and descaling the system recently, we just don't seem to get real steamed foam. It appears to be just hot milk with a few bubbles on the top.
when you remove the cappucinotore, there is a little clear plastic tube sticking up from the top of it. this is an air entrance oriface. this is where the air is brought into the steamed milk in order to froth it. the hole is very small, like the size of a hair. You need to clean this, or if you cant get it clean, your machine came with a spare one. It was in the cardboard box with the cleaning tablets, o rings, and descale tabs. Once this is clean, air bubbles can get into the milk and you should have nice foam. let me know if that doesnt work.
May 15, 2011 | Miele CVA4070 Coffee Maker
I put milk inside the fridge and before expiration date it smells very bad and is not OK ,please give me soloution .it happened more than 20 times,thanks
If your milk is not keeping then the frdge is too warm....
Turn the control on the fridge a little bit colder each day, till you just start to freeze things...
Then make it just a bit warmer and you will be at he best temperature to keep food the longest...
heatman101
Nov 18, 2010 | Refrigerators
Change milk temperature (milk not warm enough)
It all depends in the Cappuccinotore(milk frotting part) Change a new one or
Think of a way to reduce the suction tube diameter smaller... to get milk and steam mixture correct.
Jul 08, 2009 | Saeco Primea Cappuccino Touch Plus Coffee...
Steamer is not getting hot enough.
Try using the milk clamp on the tube going into the milk.Tightening it will make your milk hotter.
Your steam wand however, is a different problem.
First, check in the programming that the steam temp. is 125 celcius.
If it is, and none of the tubes from the steam wand to the boiler valve are blocked, your boiler temp. sensor may be faulty, in which case, you will need to replace that.
Mar 13, 2009 | Nuova Simonelli Microbar Espresso Machine
Cappuccinatore Milk Temperature on Saeco Royal Pro Machine
Hi
First open it up and run it without any milk attached until just mostly steam is coming thru. Turn off - then drop the tube into a jug of milk which is locted below the outlet. If its steaming, the milk will be heated up ok - it may need flow adjusting - lift the thin 'plug' near the tube up and down to adjust flow. You can add to the froth by lifting the tube out of the milk for a moment then back in again a few times.
To clean the unit just run clean water tru as tho it was milk until it comes out totally clear (about 1/4 cup). For hygiene sake make sure the tube is wiped clean on the outside with a clean paper each and every time when finished.
You can flush your main coffee lines out by making out its doing a large preground coffee - but don't put any preground in.
Select preground - select large coffee and go. Pays also to remove the brew unit and wash in warm water once a week - saves coffee goo building up and causing it to stick.
Feb 21, 2009 | Saeco Royal Professional Espresso Machine
Steam and froth malfunction
The milk can not be room temperature.  It needs to be cool, does not have to be fridge temperature but can not be warmer than room temperature
Feb 18, 2008 | Jura Capresso Impressa Z5 Espresso/Coffee...
Miele CVA4070 Coffee Maker Logo
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
