Question about Dishwashers
I am doing the electric connection for the dishwasher and the green wire goes where. I see a green wire located on the bottom of the motor area and was wondering if that whewre it goes.
  • 61 Answers
In the conection box the is a green screw that you should attach the green wire to should be in the front right hand corner
Posted on Jan 21, 2009
Our dishwasher has two grey and one green wire but the instructions say there should be a white, black, and green one. How do we figure out which wire is which?
The green is the earth. If the other two are the same colour, I guess the polarity positive and negative doesn't matter. What does the Bosch installation instructions say?
http://www.doityourself.com/stry/220-wiring-color-code-interpretation
Dishwasher GFCI Requirement ' Electrical Construction ...
ecmweb.com > Forums > Electrical 101 > National Electrical Code (NEC) Mar 4, 2014 - 18 posts - ‎13 authors Sounds like I have to install a GFCI breaker to protect the entire branch ... National Electrical Code (NEC) > Dishwasher GFCI Requirement ...
Dishwasher: Hard Wiring Vs. Plug-In ' Home Guides ' SF Gate
homeguides.sfgate.com > ... > Other Types of Mortgages When you install a pigtail on your dishwasher, you must plug it into a three-prong receptacle. The electrical code does not require the receptacle to be a ground ...
Installing a dishwasher- Does it really need a dedicated ...
forum.mrmoneymustache.com/.../installing-a-dishwasher-does-it-really-n... Mar 12, 2014 - 15 posts - ‎12 authors Installing a dishwasher- Does it really need a dedicated circuit? ... "If your local code requires it on a separate breaker, then put it on a separate ...
electrical - What is code for installing a dishwasher in the ...
diy.stackexchange.com/.../what-is-code-for-installing-a-dishwasher-in-th... Mar 14, 2013 - Current code suggests a dedicated line run to the breaker box for use with the dishwasher. 2008 NEC indicates that the kitchen should have ...
What is the typical dishwasher/disposer electrical connection?
diy.stackexchange.com/.../what-is-the-typical-dishwasher-disposer-electri... Dec 11, 2013 - Checking the wiring for the disposal, might give you some clues as to ... Code that allows Garburators and dishwashers to be cord-and-plug- ...
Dishwasher Connection And Wiring, Oh Boy! - Electrical ...
www.diychatroom.com/.../dishwasher-connection-wiring-oh-boy-10656... Jun 4, 2011 - 15 posts - ‎9 authors Q: should I hard wire the dishwasher or install a receptacle and wire the machine with an appropriate cord and plug? The code says you can do ...
Feb 28, 2016 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
How to wire capacitors on a 26 gal. model 671049 air compressor?
Well, got to local hardware store, pick up 12/3 soow/soo wire, new plug, LOTS of electrical tape (lol one rollwould work 3M type 88 is best), 3 12ga wire nuts. splice in the wire( white-white, black-black, green-green) near the motor. Cover the spliced area with enough tape to well cover the splice area; more than just one layer of tape (do not be afraid to pull on tape; it holds better when tape is pulled and stretched). Connect the plug; white to silver, black to gold/brass, green to grounding lug/green. place a slight loop (4-6" dia) with spiced area opposite of where cable passes its self. either tape and/or zip-tie so no strain is placed on the splice. At this point compressor should be working.
Oct 23, 2014 | Husky Air Compressor. 26 Gallon Portable...
LG Dishwasher Wiring issue
Yes the green goes to your bare copper wire, it is the ground. Black to black and white to white.
Jul 17, 2012 | LG LDF6920ST Stainless Steel 24 in....
I have a goodman furnance there is a loose green wire coming from the motor where does it go? Please help me.
Hi, W/D here.
A short green wire usually indicates a ground wire, and can sometimes have a terminal attached to the end of it. This wire would go to the frame of the furnace, as a ground wire for the motor, bonding the motor to the frame electrically. Usually, it is attached to the frame at the nearest point of contact, which usually is a motor attachment screw, or a green colored screw in the panel near the motor, and will sometimes have the grounding symbol near it. Before making any connections, check your wiring diagram first. It will be either in your paperwork with the furnace or attached to one of the panels near the motor. It can also be located inside the furnace electrical panel on the furnace, so make sure that the power is turned OFF (trip the breaker, and test it) before opening the electrical connection panel. Once you locate the schematic with the motor on it, find the green coded wire on the schematic and see where it goes. My experience has been that it will be a ground wire, but you have to check.
Best regards, --W/D--
Oct 20, 2011 | Goodman GMS90703BXA Heater
How do you connect the electric to wire bathroom lights on one switch, and the fan on the other switch, The power comes in through the switch, Both switches are located in the same box
In the box, connect all white wires together, that is the incoming power, the lights and the fan.
Then take the black supply wire and connect it to the bottom terminal of one of the switches and cut and install a jumper from that terminal to the bottom terminal of the other switch.
Next connect a black wire that goes to the light(s) to the top terminal of one of the switches. When this switch is turned on, power should flow from the supply thru the switch to the light.
Finally, connect another black wire that goes to the fan to the top terminal of the other switch. This will turn on the fan.
All ground or green wires connect together and the green terminal on each switch should have a piece of green wire to connect to all the other green ground wires.
Mar 16, 2011 | Dryers
How to remove the pump from the motor on a Kenmore dish washer model 363.14572000
Steps:
1)Shut off power to the dishwasher at the circuit breaker and turn off the water line to the dishwasher by locating the shut-off valve, which is typically inside the cabinet beneath the kitchen sink.
2)Remove the four screws that hold the dishwasher kick plate in place.
3)Locate the motor,which is typically centered beneath the bottom spray arm.
4)Lower the dishwasher door and take out the bottom dish rack.
5)Remove the spray tower and spray arm assembly by unscrewing the bolt through its center.
6)Take out the filter immediately beneath the spray tower.
7)Disconnect the motor wires from the wiring harness,making a note of which wire connects to which terminal.
8)Disconnect the pump assembly and drain hose from the motor.
9)Remove the motor from the base of the dishwasher by unscrewing the four bolts holding it in place.
10)Repair or replace the motor and reinstall,taking care to reconnect the wires the same was as they were attached to the old motor.
11)Attach the pump and drain hose to the motor.
12)Replace the filter,spray tower and lower spray arm assembly.Reattach the center bolt in the spray tower.
13)Restore electrical power and turn on the water supply valve.
14)Run a test cycle to check for leaks underneath the appliance.
15)Replace the kick panel in front of the dishwasher.
Jul 31, 2010 | Kenmore Dishwashers
I am installing a new pump on my asko dishwasher pump but not sure which wire goes where
there should only be two or three wires main wires brown & blue or red & black. green or green with yellow stripes is earth wire main wires connect to pump motor earth connects to earth point hope this helps
Nov 14, 2009 | Asko 1385 Dishwasher
How do i get to the pump on a big green carpet machine
Here is how to disassemble the top motor unit. Don't pry up on the very top disk, which is an air outlet. It will only break off and won't allow access to anything. If you do break it off, drill holes through the four posts and use stainless steel screws to re-attach the disk to the plastic posts it sits on.
Now, beneath the air outlet is the rest of the motor unit. The motor unit consists of three pieces. The bottom piece is the lid to the waste water receptacle. It is concave pointing down (lid shaped). The top piece is the domed lid for the motor unit. The middle piece is a flat plate between the other two pieces. The top of the flat plate (inside the unit) has mountings for the suction fan and the pump.
The flat plate is bolted to the bottom piece and the top piece (domed lid) is simply snapped down to the flat plate. If you take a flashlight and look inside the area where the AC cord is stored, you can see that the domed lid is a distinct piece from the flat plate. The model 1672 and 1680 (or 1680-3 if you wish) are nearly identilcal.
To access the internal parts in the motor unit, you cannot pry between bottom piece and the the flat plate because they are bolted together. But you can remove the top domed lid. To remove the domed lid, position the motor unit in front of you with the switches at 9 o-clock. Three snap-downs which attach the domed lid to the flat plate are at 1 o'clock, 2:30, and 7 o'clock. Wedge a flat bladed screwdriver or pocketknife between the edge of the domed lid and the flat plate at those locations and the lever the domed lid out and then up. The domed lid will separate from the bolted-together flat plate and bottom piece.
Wiring from the switches remain attached to to the electrical components. You will see that the AC cord has white, black, and green wires. The green ground wire connects to the fan ground at the 9 o'clock position. The white power connects to upper connector on the pump and also to the fan at the 7:30 position. Black feeds both switches on model 1672 and then a black wire runs from the correct switch to the bottom connector on the pump or to the connector on the fan at the 1:30 position.
Model 1680 has a third switch which feeds power to the floor sweeper. It has its own connection to the green ground and white power and goes through the third switch to connect to black.
If you need to replace the pump or the fan, shop around carefully. The pump, for example, can be found for $30 plus shipping2_bing.gif, but some will want to charge you $80.
Jun 28, 2009 | Bissell 1672 BIGgreen Wet/Dry Vacuum
Rinse and dry
You probably don't have enough pressure from the pump. That's most likely caused by a clogged filter. So start by checking the filters- the easy one to get to is located behind the chopper in the base of the dishwasher. Grab the whiteish tube going from the bottom of the dishwasher towards the back of the dishwasher and get it to spin about 1/8th turn clockwise and then pull up. If that part works out for you, you'll see four torx screws. Don't loose any of these, they cost $6 each. Take out all four and pull the round white thing up and set it aside. You'll see gray plastic now. Towards the front, down inside, you'll find two more torx screws that are smaller than the first four. Take those out and get the two gray pieces they hold down out of your way. The flat one will come out easily, the other one will take some persistence. Once you get that out, you can see the smaller filter behind the chopper. It sits inside a thin groove, pay attention to this groove, as you'll want to put it back in the wrong place if you don't look it over before you take it out. Remove the filter and chopper assembly and clean it off if it's a mess. Then put the thing back together the same way you took it apart.
If this fixes your dishwasher, then you know pressure was your problem. If the problem reappears and you follow these steps again only to find the filter full of food again, then your chopper isn't chopping anymore. This is probably because the end of your impeller is broken off and isn't engaging the chopper anymore. If that's the case, replace the impeller (about $20 new).
To replace the impeller:
SHUT OFF THE ELECTRICITY to the dishwasher and unhook the wires in the electrical connection box. Notice that (hopefully) the white wire connects to a white wire and the black wire connects to the black wire and the green or bare wire wraps around a screw. You'll need to reconnect this back properly when you're finished with everything else.
Disconnect the drain line, either at your garbage disposal or at the dishwasher if you can get to that connection. Watch out for water, it'll go everywhere when you pull this loose.
Turn off the source of water, if you don't have a valve under your sink for this (you'll wish you did) then you'll need to shut off the water to your house. Disconnect the water supply line from the dishwasher, this connection is underneath the dishwasher opposite the electrical connection box.
Pull the dishwasher out and flip it over 45 or 90 degrees, your choice.
Unscrew the capacitor from the motor assembly (it's the round looking thing with two wires mounted to the motor), but leave the wires connected to it. Put the nut back on the bolt so you don't loose it. This makes getting the thing out easier.
Find the drain pump, it has a plastic tube connected to it. There is one torx screw holding that in. Take the screw off, pull the tube and the white thing with wires out, leave its wires attached. Your model may not have wires here.
Pull the wire connector off the motor. Remember where it went. Pull the two wires off the thermistor, they should be Yellow (with a black stripe) and white. Make a note that these two wires go on the thermistor so you get them back in the right place. Pull the Blue and gray wires off the drain pump. Make a note that these go on the drain pump so you get them back in the right place.
Next, there are three tabs that you need to find and pull out. They are little L-shaped wedges that hold the round gray assembly to the dishwasher. They are located about 1/3rd of the way around the circle, so once you find one, the other two are pretty easy to locate. Do not loose these parts.
Once you get those pulled out, the entire gray assembly can come out.
Look behind the motor for a bolt. Get your socket set out and find a 3/8ths socket. Put that on an extension, and the extension on your ratchet. Slide the socket between the white plastic protector and the grey plastic (it's a tight fit) and take out the bolt. Do not loose the bolt. Leave it in the plastic so you'll remember to put the plastic back. Grab the motor and turn it about 1/8 to 1/4 turn (it will only turn one direction) and then pull it out of its housing.
From here you can access the second filter, the one that isn't so easy to get to. It's probably fine. And now you can see the impeller, it's white and black and attached to the end of the motor shaft.
To remove the impeller, stick a screwdriver into the back of the motor, being careful not to damage the windings. Hold the screwdriver with one hand, grab the impeller with the other hand and unscrew it from the motor shaft.
Install new impeller on the end of the motor shaft, make sure it's tight.
Reverse instructions to put it all back together. Make sure you get the thermistor and drain pump wires connected correctly. White/Yellow to thermistor (little round dodad) and blue/gray to the pump (big thing on the gray part that drains water from the tub.)
Don't forget to re-attach the drain and supply lines, turn on water and check for leaks. Fix leaks. You may need Teflon tape, depending on the type of supply connection you had to undo. If you use plex tubing and connectors, you don't need Teflon.
Do NOT turn back on the electricity until the dishwasher is completely wired back up, closed, secure, and don't forget the ground (bare or green) wire around that screw.
I'm not responsible if you follow these instructions and end up shocking or killing yourself or your dishwasher. This is what worked for me.
Dec 15, 2007 | Whirlpool GU1100XTLB / GU1100XTLQ /...
Dishwashers Logo
60 people viewed this question
Top Dishwashers Experts
