Question about Exercise & Fitness
Treadmill marquee mt8.12, e6 error. looking for owners manual
4 Suggested Answers
  • 246 Answers
SOURCE: I have a healthstream treadmill model LS3T and it
if you take the motor shroud off the front of the treadmill, you'll find wiring and connectors. check them and make sure none are loose, cracked, corroded, pinched, rubbing, or frayed and touching metal. also check under the display, there should be an access panel you can unscrew and remove to check the connections in there as well.
Posted on Feb 17, 2010
maxtreadmill
  • 832 Answers
SOURCE: I am looking for the Owners Manual for a Weslo Cad...
go to iconservie.com click on manual input this info CADENCE 200CS (WLTL1901)
Posted on Jun 01, 2010
ercupa190
  • 12223 Answers
SOURCE: error6 on my treadmill
please see the problem and fix it. see the block diagram
circuit diagram attached.
Happy new year. God bless you
skfsyaaaaaelftksuqmcc
Posted on Jan 01, 2013
How do I clear the E6 code in a Xterra 3.0 treadmill?
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. This screen will display the potentiometer value of the incline motor. Different models will have different values. Check to see if the running deck is raised to high incline level or if it is at the low level. If the running deck is at a low position press the incline up button. This will cause the incline motor to raise the running deck up. When the deck gets to a mid-level position, press the incline up button a second time to stop the deck. If the running deck is in a high incline position, use the incline down button to adjust the deck to a mid-level position.
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
  5. Once the treadmill starts the running deck will move to the level 0 position. If this does not resolve the issue or it will not adjust please contact customer service.
Also note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service.
Apr 05, 2017 | Exercise & Fitness
E6 error message
It appears that your elevation system is where the fault lies. This could be as simple as recalibrating the lift mechanism, or possibly correcting faulty wiring from the lower controller to the lift motor. Be sure to check the condition of the lift motor as well as the wires entering the lift motor. Sometimes the wires will pull away from the plastic connector causing a lift motor error
Mar 11, 2014 | Dmm Vision Fitness T9500 Treadmill
MY AF 843M AEROFIT TREAD MILL IS SHOWING AN ERROR E1 AND SOMETIMES E6. KINDLY GIVE US THE SOLUTION
You have to check the Speed sensor and its position.Normally you will find the speed sensor near motor pulley. In almost all treadmills E1 Error is related to speed sensor.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jan 04, 2014 | Exercise & Fitness
go and download free www.fitnessmanualsonline.com
causes: key safety+ elevation motor connection+screw binding.
solution: repair or replace s. key + test the connection e.motor + clean and lube the screw e.motor.
God bless you
Jan 08, 2013 | Exercise & Fitness
Error E6 on Healthstream treadmill
If you wish to get some details about treadmill error codes ; check the site linked here. Pull up older posts.
Mar 16, 2012 | Exercise & Fitness
My lifespan treadmill has error code e6, what does this mean?
hello,kindly download the below file... it explains ur error and how to rectify it
http://www.body-solid.co.uk/body-solidUK_download/pdf_docs/tr-20(1)E6+E7(XT-27_33_56_57_7600).PDF
thank you for using FixYa,Thanks,Reymond
Oct 19, 2011 | Exercise & Fitness
I have an Insight DK614 Tredmill that will not run. It displays an error message "E6" and the running deck will not lower. The motor is still running albeit at a much lower rate. No movement...
E6 or E7 An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
  1. Turn the power OFF, wait for 5-seconds and turn back ON.
Also, note that not all models will have the ability to adjust the incline motor. If the adjustment procedure is not found in the Owner's Manual then contact customer service. Treadmill Error Codes Troubleshooting
Oct 26, 2017 | Exercise & Fitness
Error E6
thank you have a nice day
May 04, 2009 | Exercise & Fitness
Exercise & Fitness Logo
55 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
