Question about Master Heaters 160-IF
Master 160,000 btu will not stay lit
I have an older master kerosene salomander style heater, Model #B160 serial #CKO789, plug in, turn on, set thermostat, fan comes on, 10-15 secs. later it lights, burns for 15-20 secs then flame goes out and it blows smoke for 20 secs. then it relights and does the same thing over and over ???
  • 3 Answers
Pull out flame sensor and sand. Re install and call for heat
Posted on Jan 21, 2009
Older torpedo style kerosene 50,000 btu smokes
clean out the fuel nozzle and if it wont burn cleanly, replace it.
Jan 03, 2010 | Heating & Cooling
Reddy Heater won't stay running
Dear travelinman4, 02-21-2009 18:24 EST (USA)
Re: Reddy Heater "Won't Stay Running"
Model R150A
Old Fuel? Added a Can of Fuel Booster? Used Starter Fluid?
Spark Plug or Igniter?
Gas, Propane, or Kerosene?
jack
Feb 21, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Kerosene heater won't stay lit
check to see if the photo cell is clean.to check it open the side compartment and look for the blue and white wire comming from photo cell,on the reset switch there is a white wire and a blue wire.hook these two wires to gether at the switch and try to refire the unit.if the unit keeps running the photo cell is bad and NEEDS to be changed.if the unit shuts off the safety switch is bad.
Feb 19, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Dyna glo heater
The first thing you need to do is put some kerosene in it, it's a simple step that a lot of people tend to forget. After that make sure it's plugged in and turned on and it should fire right up. Hope this was helpfull poolmistress. You could also have your husband look at it, i hear he is pretty good with stuff like that.
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
We arelloking for parts for our All Pro 60,000 BTU heater. The part # is 0634-3 the model of the heater is WP060X0FP
You may want to try Master Parts at 800-446-1446 or online at www.masterparts.net. You would need the correct model number. The only you gave is a serial number. You should be able to find the model number located on the heater near the serial number.
Jan 03, 2009 | All-Pro Kerosene Garage Shop Heaters - All...
New heater will not stay lit
you have had dirty fuel or water in your fuel can.you need to replace the fuel filter behind the thermostat.
Dec 09, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Won't stay on , not very consistent
You don't state whether this heater has the old style spark plug technology or the newer Hot Surface Ignitor technology. Troubleshooting will be different, depending on the style of heater, because the electronics are different.
You ask "what are the two adjustments screw heads on the back of heater". As stated by tros1 these are A. an air pump adjustment screw, and B. a pressure relief valve.
Both technologies require correct pump pressure in order to deliver the fuel at the proper rate. For a pressure setting video
http://youtube.com/watch?v=NeM3Yi9Y1oE
Reply with the model number and/or the specific ignition technology and maybe we can help.
Mar 06, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Master Heaters 160-IF Logo
300 people viewed this question
Top Master Heaters Heating & Cooling Experts
T bone 1963
Gil Shultz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Master Heaters Heating and Cooling Expert? Answer questions, earn points and help others
