Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Whirlpool Duet Sport Washing model #WFW8300SW04 No water coming into washer
fridgetech
  • 473 Answers
SOURCE: Code F1 @ Whirlpool Duet Sport Washer
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=WFW8300SW01&productCategoryId=0153200&brandId=1198&modelName=RESIDENTIAL-WASHER&diagramPageId=00003&componentDescription=CONTROL%20PANEL%20PARTS&documentId=W0607261&backToLink=Return%20to%20Sub%20Components%20list.
Posted on Dec 12, 2008
agitateme
  • 88 Answers
SOURCE: 2003 Whirlpool Duet Washer clear water pooling in drum after use.
When the machine is off, there are only two ways water could possibly enter. 1 Check the drain hose install, that it is not installed deep in the standpipe, if the hose is shoved too deep, it can sometimes siphon (rare with front loaders) water back into the machine.
2. Most likely cause, a slow leak from the water valve. Sometimes the water solenoid will not close completely, and you will get a very, very slow leak into the machine.
If not the drain hose, try shutting off the water supply valves when done using the machine, if that takes care of it, you may want to replace the machine's inlet valve.
Posted on Apr 19, 2009
  • 212 Answers
SOURCE: whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Posted on Jun 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport WFW8300SW04 frontload washer
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
How many shock absorbers are there supposed to be on a whirlpool duet sport wfw8300sw04?
You should have 2 in rear of machine and 2 in front of machine. They hook up to bottom of drum. GOOD LUCK FRIEND.
Nov 22, 2014 | Whirlpool Washing Machines
Wfw8300sw04
water should pour in . check the hose inlet for crud in line ,it has a screen , check water is on,
finally check the water solenoid does it clack , does it have power ,for that you might need help
Oct 11, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport F21, F01, SD
Drain pump may be clogged or need to be replaced may run but not pump blade stripped in pump
Apr 28, 2017 | Whirlpool Duet 3.8 cu. ft. Front Load...
How do i run a diagnostic on a Whirlpool Duet Sport WFW8300SW04 frontload washer
what code is it giving. there should be a paper under front bottom kick panel. that has all codes and sequences on it . or you can google code list . i think it was power button 3-5 sec then any cycle button 3-5 seconds 3 times
Mar 04, 2013 | Whirlpool WFW8300SW
Hi, I have model wfw8300sw04. I'm having trouble with it spining & draining. It won't drain and it spins once and stops. I have check the drain for any clogs and nothing.
Open the door and push the bottom front of the boot aside and look to see if an article of clothing as gotten in there. Post back your findings.
Nov 13, 2012 | Washing Machines
Washer model number WFW9400VE error code F20 keeps coming up. Is there a way to reset?
F20 No water detected entering machine, Defective flow meter, clogged water valve inlet screens.
Duet sport service manual
Jan 07, 2011 | Whirlpool Duet WFW9400VE Front Load Washer...
My Whirlpool Duet Sport washer with model #WFW8300SW04 has a bad control board located on the top right side. What is the actual name and part number of that control board?
Hi
The part number for User Interface(part# 3 in image) is PS992556 and part# for Electronic Control (part#6 in image) unit is PS2362897. Please check the image for details--
Hope this helps....
Daniel
Aug 20, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
What does f21 on washer mean?
Hi, this advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F21” error code.
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
  2. Check the drain hose to make sure it is not kinked or clogged.
  3. Check the electrical connections to the pump and ensure the pump is running.
  4. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Take care
May 31, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
