Question about Dwin TransVision 3 Plus Multimedia Projector
Dwin Trans3 Plus will not lite
One of the fans will not start without making a noise, the noise lasts about a minute then stops, now the lite won't come on.
Have not been able to get a response from Dwin are there other ways to repair?My Dwin Transvision 3 will power up but nothing comes out the lens. The bulb is good, the filament is not broke. It's 4 years old with the original bulb and we use it often. There is a blinking red light on the front of the projector and a blinking green light on the front of the processor. What is the issue and can it be fixed?
    Sergeant:
  • 378 Answers
It can be the board error
or check out this links 1 by 1
how to replace the colour wheel with diagram and procedure
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
how to replace the lamp in 5 minutes with diagram and procedure
http://www.jangro.com/a/2006/08/03/how-to-change-your-samsung-dlp-lamp-in-5-minutes
Posted on Jan 21, 2009
    Sergeant:
    Scholar:
  • 199 Answers
Check out the colour wheel of the unit.
I have a Dwin TransVision 4 that is not working. It started out with us being able to watch a movie for about an hour and the bulb shutting down. I finally ordered a bulb from Dwin (at 458.00!!) and...
honestly it sounds as if a capasitor is overheating and once it overheats the machine is shutting off.... I myself would be able to look at it and see if this was correct or not. i am not sure how familliar you are with these types of things, probably best to take it in and tell them exactly what is wrong...
Feb 26, 2011 | Dwin TransVision 3 Plus Multimedia...
Plays for couple minutes or hours, then goes
Have you considered checking the lamp? It could be going bad.
Nov 15, 2009 | Dwin TransVision 3 Plus Multimedia...
No video is coming out of my Trans3 projector what can it be?
Not sure. I am looking for parts for mine. Please help if you can. Will buy dead projector. dgrayid@yahoo.com
Oct 05, 2009 | Dwin TransVision 3 Plus Multimedia...
Making virbrating nose
believe it or not, most noises that start and end and start again are sometimes very easy to fix. next time you hear it open the refrigerator doorand see if your ears can pick up the sound. usually it is two bottles in the panel of the door vibrating against each other. if not thencheck your fans especially the condenser fan next to th compressor, something may be caught in the fan blade. unplug unit if you find noise and give the coils a good cleaning while you are down there anyway. let us knowhow you did
May 01, 2009 | Refrigerators
Loud whirring noise that stops when freezer door is open.
It is most likely your circulation fan in the freezer. Normally the fan stops when you open the door. It is a normal operation. Check to make sure that the fan is not blocked by frozen items or that the fan doesn't have an ice build up. On some models the fans stops when you open the door and starts a few minutes later after you close the door.
Mar 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
I had a similar problem and it turned out to just need a good clean. The fans can pull in a lot of dust and eventually this causes intermittant starting problems/noise. I attacked mine with compressed air and a vacuum cleaner and this completely fixed the problem. Try to control where the dust goes you want to avoid just blasting it inside the unit and on the lense, bulb, etc
Dec 31, 2008 | Dwin TransVision 3 Plus Multimedia...
Picture becomes unstable after turning it on (lack of color,
The problem is with overheating!. after a few years the fans accumulate dust and "stuff" and don't work as well. Get a can of compressed air and blow out all the ports and fans. I take the cover off and with everything cool, I blow out all the internal fans also. The 3 big fans on the back are easy to remove and clean and get spinning again. Usually this fixes the issue for several months but eventually, professional cleaning may be needed at DWIN.
Dec 23, 2008 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Dwin lamp turns off
I design and implement switching power supplies for the commercial lighting industry. I also own a DWiN Transvision and have opened it and worked on it several times. I believe I can answer this question.
The DWIN projectors use a proprietary switching power supply to strike the lamp and keep it burning. The power supply is extremely sophisticated and maintains tight voltage and current tolerances. This is important because the halides in the lamp are damaged by power supply fluctuations. The halides can often be seen in an unfired lamp, they appear as small specks of dirt or tiny beads inside the lamp envelope. When a metal halide lamp is struck, the halides (which are rare earth elements) vaporize and cling to the inner wall of the lamp envelope. The mixture of halide gas in the lamp is what determines the color temperature of the lamp, as well as the accuracy of the lamp across the entire color spectrum.
One of the ways that DWIN is able to deliver such great color is because they use a lamp which delivers this great color across the spectrum, but, as I pointed out earlier, can be damaged by fluctuations.
The power supply contains three switching sections and five references for such things as input and output voltage for each psu section, as well as overcurrent demands from the lamp.
From my experience, your lamp(s) are all exhibiting issues that require replacement.
Sep 25, 2007 | Dwin TransVision 3 Plus Multimedia...
Video then Black
the colorwheel is going bad and needs replacing.
Jul 27, 2007 | Dwin TransVision 3 Plus Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
53 people viewed this question
Top Dwin Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
