Question about Jl Audio 1000/1 Car Audio Amplifier
I have a jl 100/1 how many subs can i run and at what ohm
I have 2 dual 4ohms wired at 8ohm i would like to run two more
5 Suggested Answers
  • 631 Answers
SOURCE: jl audio 500-5
Assuming that you've confirmed that the speaker is in good working order and that the wiring isn't shorted in any way...
There are separate power supplies for the high and low amplifiers. It's possible that the one for the sub output has failed. If that's the case, the output transistors probably failed and that's what damaged the supply.
Generally, I'm willing to help people repair their amps but this is a large, complex amplifier and it should be repaired by a qualified technician.
Posted on Apr 19, 2008
tech48
  • 624 Answers
SOURCE: Can i wire 3 jbl gto1204d subs into 1 jl audio 500/1 amp
You can connect them in a series/parallel configuration. Put two of them in series and then connect the last one in parallel across the two in series. This would give you an impeadance of around 2.7 ohms. Only do this if your amp is stable at 3 ohms or less. I am not familiar with the specs of your amp. If your amp is only 4 ohm stable you can not do this.
This would also give you half the power on the two subs in series as the power for the one that is parallel. The two in series would be sharing the total output signal, where-as the one in parallel would get the entire output signal from the amp.
if you were to connect a fourth sub woofer in this configuration it could give you a 4 ohm load, by adding the fourth sub in series with the single sub that is in parallel. or in other words, yu have two sets of 2 sub woofers each in series. That gives you two 8 ohm loads (two 4 ohm subs in series is 8 ohms). Then you take the two sets of subs and parallel them (two 8 ohm loads in parallel equals 4 ohms).
If i had a picture to show you it would make sense, two subs in series that are in parallel with two subs in series.
Posted on Jun 16, 2008
uge44
  • 226 Answers
SOURCE: 500/1 settings to run jl13w6 v2 d-4
Just had a look at both amp and sub on the JL Audio website. The amp runs from 1.5-4ohms. 4ohms at 14.5V. The sub is running dual 4 ohms coils. That's what the D-4 means. So should be an easy set up. The amp has two mono outputs, so one for each coil. It looks like the perfect wattage to run the sub real nice.
Web page for amp: http://mobile.jlaudio.com/products_amps.php?amp_id=439
Web page for sub: http://mobile.jlaudio.com/products_subs.php?series_id=18
Posted on Nov 19, 2008
  • 55 Answers
SOURCE: wire three 10" jl subs to jl e1200
what is the impedance of your woofers it will be a number with an Omega symbol. Looks like a horseshoe next to your woofer . Like this JL Audio 10W1v3 8ohm. Please, Please tell me you bought 8 ohm woofers JR?? Because if not, it ain't gunna happen.. If you did buy 8 ohm woofers than wire them in parrellel which means all the +'s together and all the -'s together giving you a final impedance of 2 ohms and your amp will think your a car audio GOD... But if not be ready to smell plastic burning where your amp used to be.... let me know i can walk you thru the wiring but let me know what you have. ok. mark
Posted on Aug 14, 2009
I have 2 12 inch kicker rt dual 2 ohm subs. On a kicker cx1200.1 i want to kno how to hook it up to 2ohm to the amp. And if i can add another 10 inch kicker rt 2ohm sub in the future.
Do to the impedance Of your sub u can't run it @2ohms its going to either be @1ohm or 4ohms and your amp isn't 1ohm stable and u will risk damaging your amp. So your only option is to run it @4ohms and on a good note your sub is 100-600 watts RMS and your amp will push 400-500 watts RMS @4ohms. Now if you want to run 2 sub's in the future That amp will work perfect because it pushes 1,200watts RMS @2ohms and to wire your 2 sub's @1ohm just follow the steps in the image below. Hope this helped.25345194-v0hbouy2nvquqteoroa5j5rq-3-0.png
Dec 30, 2014 | Car Audio & Video
I have 2 different subs in one box, a 12" MTX thunder and a 12" Kicker CVR. the kicker is a dual voice coil while the MTX I dont believe is. Can I use one amp for this set up? And how would it be wired?
im guessing both speakers are 4 ohms ..mtx 4ohms and kicker dual 4ohms..now if your amp can go down to 1 ohm wiring the kicker dual coils in parallel (2ohms) and the mtx connected together (4ohms) should leave you with a final impedance between 1 and 2 ohms ...i suggest you use one or get another
Oct 08, 2013 | MTX Car Audio & Video
Wiring a crossfire vr602 at 4ohm
OK what you are saying now is that your speakers are dual voice coil; models? 4 Ohms per Coil? I have always used single 4 Ohm Voice ciol speakers since amps are mostly based on 4 Ohm outputs. but you can get 8 Ohm dual voice coil subs also. With 8 Ohms per coil you can get 4 Ohms if you parallel the wires. What is best for you and will get you the most stable power and still will be in the specs of that amp is to run the amp in BRIDGED MODE running each subs voice coils in series with each other then run those 2 subs in parallel to the amplifier giving it a 4 Ohm load. So, your will have two sets of wires from your amp 1 for each speaker. Then you will take a short piece of wire that will connect the + to the - of each voice coil then hook up the wires from your amp to each sub What it will be is 4 Ohms + 4 Ohms = 8 Ohms per speaker the 8 Ohms in parallel each speaker to the Bridged amp output using just the + from one channel and the - from the other will give you a total of 4 ohms and power out put of 600 Watts so that ends up being 150 watts per voice coil or 300 watts each speaker
Apr 04, 2013 | Crossfire VR602 Car Audio Amplifier
Amp goes into protection mode when i turn up volume
Sounds like you are running your subs at to low of ohm. Amps are rated differently on the levels of ohms or resistance that they can get to. If you have a dual 4ohm sub and run it in pairrell it will drop to 2ohm and if you run the same sub in series it will be 8ohm. Your amp will go into protection if the ohm is to low.
-david
Nov 07, 2010 | Jl Audio 12W6 Car Subwoofer
Need help.. I have two 12 inch dual voice coil kicker comp vrs.. they are 4 ohm subs..how do i wire them to get a final ohm load between 1.5 to 4ohms in a dual enclosed box...Im hooking them up to a jl 500...
To do this they MUST be wired in parallel, IE: Plus to Plus, Negative to Negative. 2 4 OHMS in parallel is about 2 OHMS in series it would be 8 OHMS... series is positive to negative. Are you using a crossover network?
Mar 05, 2010 | Kicker CVR12 Car Subwoofer
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
Nov 29, 2009 | Kicker CVR10 Car Subwoofer
I have a PHOENIX GOLD RYVAL V1502 amplifier and trying to hook it up at 2 ohms as it describes it can be 450watts x2 at 2 ohms running wires from bridged positive and negative to the first sub then two...
Hello mgonzalez390,
It sounds like the amp/subs impedance is not matched. According to the published specifications for the V1502 amp, it is only stable in bridged mode down to 4ohms, not 2ohms. You need to get the final impedance that the amp sees up to at least 4ohms or it will continue to shut down and eventually fail completely.
If your subs are dual voice coil and can be rewired so that each sub has an impedance of 8ohms, then you can safely parallel them to the amp like you have described. If they are single 4ohm voice coils, then you have 2 choices. Connect one sub to each channel or if you want to bridge the channels, then wire the subs in series, not in parallel. Wire the positive bridged terminal from the amp to the first sub positive, connect a jumper from the negative of that sub to positive on the other sub, and then the negative from that sub back to the negative bridged terminal on the amp. This wiring results in an 8ohm load to the amp and it should work OK without shutting down. But the power to each sub will actually be less than if you wire them separately to each channel.
Hope this helps.
Jul 08, 2009 | Car Audio & Video
Jl audio 10w6 x zapco350
These subwoofers are dual 4 ohm voicecoils.
Parallel wiring the 2 voicecoils would net a 2 ohm mono load.
Connect both + on the sub to the + on the amp.
Connect both - on the sub to the - on the amp.
Many professionals simply jumper the 2 + and 2- on the sub.... then run 1 set of wires from one of the terminals to the amplifier.
Thank you for using FixYa - a FixYa rating is appreciated!!
Jan 27, 2009 | Jl Audio 12W6v2 Car Subwoofer
Nov 19, 2008 | Jl Audio 1000/1 Car Audio Amplifier
Unsureness of wiring configurations.
Mamola,
Get an amp with at least 200 Watts RMS. The RMS value is what is important about driving Subs. This could be proclaimed to be a 1000 Watt amp. REad the RMS value.
Wiring. It is better to series your Speakers to give them and your amp more reliability,
Get a Mono or Bridgeable amp. If it si bridgeable, BRidge the output as described in the manual you get. Some Amps have a diagram right on the output..
AMP+ to Sub1 +
Sub1 - to Sub2 +
Sub2 - to Amp -
Get a 4 Guage wring kit. Run your power wiring down the Drivers side, and Audio signal wiring down the Passenger side, keep the two separate.
Nov 26, 2007 | Kenwood 12" 4-Ohm Single-Voice-Coil...
Jl Audio 1000/1 Car Audio Amplifier Logo
23 people viewed this question
Top Jl Audio Car Audio & Video Experts
Mark Skinner
Tygh Duval
Tygh Duval
Matthew Spark
Matthew Spark
Are you a Jl Audio Car Audio and Video Expert? Answer questions, earn points and help others
