Question about Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091
The water continue to run for a long time
I have a Troubleshooting Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet that the water runs for a long time, also seems like they maybe more water in bowel than usual. After stops flushes fine but takes about 5 mintes to stops running. I'm unfamiliar wiht these pressured wc, on a regular wc would just think the flapper is not sealing correctly.
Thanks fo helping.
MJM
  • 334 Answers
You are probably going to have to replace the fill valve.
There is a chance that adjusting it may work, but it has most likely become worn and partially clogged with hard watrer deposits, dirt, etc.
This will cause it to fill slower, and cause the fill level valve to close slower resulting in higher water level. Eventually it would simply overflow the flush valve tube.
Try adjusting the fill level, but plan on the likelyhood of replacing the fill valve.
Posted on Jan 21, 2009
Elijer Diplomat toilet flushes perfectly, but after the water in the bowl takes forever to fill up again. You have to wait 10-15 min. before the water is up to normal level and it will then flush...
Pressure assisted toilets have a stainless steel tank that refills under lid,if your refilling bowl it only needs to fill trap for smell,the pressure assist does the rest,thats part of the water saving of the toilet,you don't have a lot of water in the bowl
Jan 28, 2011 | Eljer Aqua-Saver 12" Two-Piece...
A small jet of water is released up through the seat onto the person seated
You have a bidet:
http://www.amazon.com/Luxe-MB110-Non-Electric-Mechanical-Attachment/sim/B001KKRCFA/2
Google search for 'toilet seat bidet'
As general rule, men do not use this feature.
Change toilet seats to remove bidet.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on toilets or any do-it-yourself project.
Jan 12, 2011 | Eljer Aqua-Saver 12" Two-Piece...
Trickle leak refill 1-2 minutes city water 40 PSI
the flapper valve is a common piece to obtain and easy enough to replace..
Aug 02, 2010 | Eljer Aqua-Saver 12" Two-Piece...
Doesn't hold water in the tank
sounds like the flapper is not seating properly
Jun 21, 2010 | Eljer Aqua-Saver 12" Two-Piece...
We have a new eljer toilet and the water level in the bowl is very low and we can't seem to be able to adjust it
The Elger design has many small passages inside that harbor fly larve and even spiders! We just broke one in half to see where the larve were hiding. There are areas that cannot be cleaned!
Return that piece of s*** and get an American Standard.
Dec 30, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Eljer pressure assist handle will not move. If water valve is on, water will conitnuously run with no shut off
If you take the lid off the toilet there is a cartridge in the middle of the tank. if you take the handle mechanism off the toilet and get some plyers you can take the cartridge out of the tank by twisting it out. make sure the water is off and that you have pressed it down ( the part that stick out of the middle of the cartridge)to relieve the pressure. it should come right out and take it to a local plumbing supply shop and they should be able to get you a replacement part for it.
Jul 28, 2009 | Eljer Aqua-Saver 12" Two-Piece...
No water at flush
sound like the water shut-off needs to be replaced.
if you turn on/off the shut-off, the tank get enough water to flush, then you get less water every time you use the toilet. that is the shut-off valve problem.
you may able to to just change the rubber seal.
I have not found change the seal will last as long as a new valve. better off, just change one.
Feb 11, 2009 | Eljer Aqua-Saver 12" Two-Piece...
Toilet doen't stop flushing
Sounds like the flapper is stuck in the open position.
They sometimes get hung on the flush tube or the chain hanging from the handle.
Is the water level overflowing the tube?
If so, try adjusting the level down, you may need a new fill valve if that doesnt work.
Nov 18, 2008 | Eljer Aqua-Saver 12" Two-Piece...
No back flush pressure
increase the tank water level half inch at a time till you have the back flush pressure.
seems like the water in the bowl is too low to create any wirlpool.
Oct 30, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091 Logo
486 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
