Question about Asko Washing Machines
Remove top on Asko wl6532 washing machine
Drum suspension spring off and trying to remove top of washing machine to repair same
  • 1294 Answers
SOURCE: Asko washing machine door not closing
Changing the door lock is one of the easiest things to do in a washing machine. Just note which wires go where & get a new door switch.
Posted on Jun 11, 2007
  • 113 Answers
SOURCE: How do I remove the top of a Maytag PAVT234AWW
Between the front panel and the top there is a seam. On each side of the seam there is a clip. Take a putty knife and push on the clip. One is on the left and one on the right. Than just pull the top of the panel straight back and unhinge from the bottom. Hope that helps, Dave www.washermd.com
Posted on Dec 17, 2008
BUDDY08
  • 128 Answers
SOURCE: washing machine
hope this helps, don't forget to rate me thanks
Try leveling the washer. Check for play along the diagonal corners of the washer cabinet by applying downward pressure. If there is any play at all, the washer will shake during spin and the legs must be leveled.
You have br put your heavy washer on a floor that would be condemned for structural weakness if a building inspector saw it. Try placing reinforcing pads or pieces of plywood on the floor under the washer.
On Maytag top loaders: worn damper pads.
On Whirlpool/Kenmore direct-drive machines: worn snubber pad
Posted on Dec 28, 2008
  • 2920 Answers
SOURCE: washing machine spring who do i attach it to the drum
if you have a screwdriver you can put in on the drum first the use the screwdriver to pull it up yo hook to the tub like a kind of prybar effect.
Posted on Jan 12, 2009
SOURCE: asko 10625 will not spin
it is probably the belt, take off the back of the machine and look at the black rubber belt that spins the cleaning drum. The belts break after about 5 years, you can get a replacement belt at you local Asko dealer, I recall that is was pretty easy to change, like doing a bike chain, Talk to you Asko dealer about how to change it.
Posted on Jul 13, 2009
Asko w6444 front loader drum vibrating quite loudly. Feet are level. Any suggestions.
Check the 3 transit bolts on the backside of the machine. Should be removed. Could also be a problem with the balancing spring on the top of the drum, so the drum tilts a bit forward, and cause noise
Aug 11, 2013 | Asko W6761 Front Load Washer
Drum suspension failure
The suspension spring of the drum has come off and this means that the drum is hanging off the center.
The drum is hung with spring and shock absorbers and if one side has come off it will be off balanced. The springs are hung from the corners of the BODY FRAME. Check this out, replace spring if the end had broken or also you can use a good plier to extend the spring head to be clipped.( if broken)
Dec 30, 2012 | Asko WL6532XXL Washer
Samsung WF218ANW drum tilted off track
It may be a suspension spring has come off or leg has broken if it is both drums off track.
If it's just the inner drum then the bearings may have failed or the spider that the shaft is connected to may have broken.
Start with the springs at the top and suspension first.
Dec 29, 2012 | Samsung WF218ANW 4.0 cu. ft. High...
ASKO w6884 Eco vibrate violently when spins
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
May 31, 2012 | Asko Washing Machines
Replace drum bearing ... in a ASKO W6551 step by step
you need to remove the drum start at the front remove front panel,four screws 2 under front,1 behind soap drawer and the one near the filter,next take door off 4 spring clips on the next panel plus screw on door lock,remove door lock,then undo clamp band,bolt at bottom and remove counter weight panel (heavy).remove stainless steel inner panel,use a screwdriver to loosen,from the back remove drum pulley.the drum will then pull out.replace vseal and bearings.hope this helps
Jun 05, 2010 | Asko WL6511W Front Load Washer
I have a WM2010 wash machine. The front of the drum has fallen down and the rubber gasket is all twisted up. I can't straighten up the gasket. What happened?
Sounds like drum suspension gone or top spring/ springs broken check this 1st refit if just fallen off, quite tight to do...heavy....
Apr 28, 2010 | LG WM2016C
It seems that the drum is spinning off its axis
When a front load washer does not spin properly, the problem can be caused by failed axle that connects the pulley to the wash drum, or failed shock or (possibly) broken suspension springs.
Remove washer top, inspect the two or four springs holding the washer drum up. The whole drum should be able to "bounce" a little, when you press down on it.
Remove the lower front panel and with a flashlight, inspect the two shock absorbers. Both should attach up to the wash drum, but it is common for them to break, especially if the front load washer has been moved from one house to another without re-installing the lower brackets and the long bolts that secure the drum during the move.
If the springs and shocks are not damaged, with the top removed look down into the rear area. You will see a large pulley with a belt on it. If you see brown/black grease marks all over or obvious problem when you try to turn the pulley, you have found the major problem.
Please get back to me with what you find. OK?
Jan 03, 2010 | Hotpoint WMA58 Front Load Washer
How do you remove drum springs on a hotpoint WMA washing machine
working from the front using mole grips get hold of the suspension peg now feel round the back you should feel a raised part of the peg this has to be depressed now pull the peg out if it gets stuck push back 5mm and try again repeat on other side life the springs out with the drum
hope that helps
May 13, 2009 | Hotpoint WMA64 Front Load Washer
Hotpoint washing machine drum suspension springs
that's a really intense operation..you'll need to remove the tub to do this. quite a job, actually..
Mar 09, 2008 | AEG Lavamat 74640 Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
