Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Frig not cooling
We have a Kenmore Model 596.51672100 about 7 years old. I just recently replace the ice maker and two weeks later, now the frig won't cool. Both the lower rear fan is blowing and the inside fan which I believe is the evaporter fan is blowing. There is no frost on the evaprater and I can hear and feel the compressor humming. I unplugged the frige and everything cam back on. Left it for the day but it still not cooling. Is it some kind of relay? Can you help?
  • 163 Answers
Hi!!! you seem to have a freon leak in your eveporator..You might be in warranty .Good luck..
Posted on Jan 21, 2009
    Genius:
  • 1,269 Answers
It sounds like a freon problem. It might be low on freon, better replace it.
    Sergeant:
  • 378 Answers
Cooling is poor For an overall understanding of how refrigerators should work, read about refrigerators in the How Things Work section of our website. A refrigerator or freezer that is cooling, but cooling poorly, may have a problem in one of several areas:
Evaporator coils
Condenser
Poor cooling is often the result of a heavy frost build-up on the evaporator coils or a condenser that is clogged with dust, lint, and dirt.
Evaporator coils Poor cooling is often the result of a heavy frost build-up on the evaporator coils. You can't see these coils without removing a panel on the inside of your freezer. A sure sign that there is a build-up is the presence of any frost or ice build-up on the inside walls, floor, or ceiling of the freezer. Such a frost build-up usually indicates a problem in the self-defrosting system or damaged door gaskets.
The refrigerator is supposed to self-defrost approximately four times in every 24 hour period. If one of the components in the self-defrosting system fails, the refrigerator continues to try to cool. Eventually, though, so much frost builds up on the evaporator coils that the circulating fan can't draw air over the coils. There may still be a small amount of cooling because the coils are icy, but with no air flow over the coils, cooling in the refrigerator compartment is quite limited.
Here's an inexpensive, though inconvenient, way to determine if the problem is with the self-defrosting system. Remove all of the perishable food from the refrigerator and freezer, turn the thermostat in the refrigerator to Off, and leave the doors open for 24 to 48 hours. (Be sure to have several towels ready in case the melting frost and ice causes the drip pan to overflow). This allows the refrigerator to defrost "manually." When the frost and ice build-up has completely melted away, turn the thermostat back to a normal setting. If the refrigerator then cools properly, it indicates a problem with one of three components in the self-defrosting system:
  • The defrost timer
  • The defrost thermostat (also called the bi-metal switch)
  • The defrost heater
If it still does not cool properly, there may be a problem with the refrigerant level or the compressor. You may need to consult with a qualified appliance repair technician to further diagnose the problem
Kenmore Refrig Model # 75922400 top Freezer. Freezer is freezing really good but frig is around 46 - 48 degrees at coldest setting. We discovered ice on vents in freezer and thawed them out with hair...
Sounds like a defrost failure.
Look on the back wall of the freezer from the inside.
If it is covered in ice your defrost system has failed.
Also check the fan motor in the freezer.
If it is not running it must be replaced.
Feb 24, 2011 | Kenmore 18.9 cu. ft. Top Mount...
Moved frig then plugged in and ran for several days then quit, then two days later started again and then a week later quit again? Frig is a ten year old side by side Kenmore about 21 sq feet, ice maker...
If you didn't give it enough time for the oil to settle back in the compressor that could be the problem. I would try leaving it off for a day to see if it will settle down and run better.
Sep 30, 2009 | Refrigerators
Maytag model MSD2756GE ice maker. Water not getting to ice maker.
Why was there a need to increase the freezer temperature? Are you having temperature problems as well? If so, your ice maker has a built-in thermostat that, unless and until it is satisfied, will not cycle, thereby, making no ice. If temperature seems ok, and the buzzing is only occasional, then that buzzing is most likely the solenoid valve being energized but not passing water. This is a dual solenoid valve (one supplies the ice maker and the other supplies the dispenser) located at the bottom rear of the refrigerator.
Aug 22, 2009 | Refrigerators
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Ice maker not working
the water valve soleniod on the lower back of frig. is bad,get the model number out of the frig. top right and replace,let me know-mike
Sep 21, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kenmore Icemaker
check inside the ice maker are the forks pointing up or down if they are down them the module on front of ice maker is broken it needs to be repl, but you said is 8 years ol d so i would repl the whole ice maker since the mold might be peeling off due to age they only last like 4 years or so
Jun 11, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Relay in kenmore frig
Yes it can. a short in the windings will cause a relay to fail. let me know if you want to make sure it is a compressor
May 26, 2008 | Kenmore Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De GO PATS
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
