Question about Pool & Spa
My dream maker spa model # EZB-UHS-REC-SD-F wont run. It ran when I plugged it in after filling it until it hit the set temp then stopped now it wont do anything. The control panel at the top is on but it does nothing when you push the buttons. The temp buttons will let you go down but wont go back up and the light button is not working. Could this just be a panel issue?
5 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Jandy Aqualink RS4 controller won't turn lights on/off
AquaLink Trouble shooting guide
Posted on Feb 26, 2009
SOURCE: my dream maker spa does not work. there is
I have the same problem with a one week old x400. It was working fine last night but about 8 hours later water temp has dropped 4 degrees and the pump will not turn on, I can hear the relay in the control box make a ticking sound when I press the pump icon on the control center but the pump does not start. Is there a fuse in the control box?
Posted on Nov 01, 2009
  • 12776 Answers
open control panel will see a small glass fuse replace if blown if 220 volt check that getting power on both lines
Posted on Nov 04, 2009
Ian  Hot Tub
  • 77 Answers
SOURCE: Dream Maker spa - does my dream maker spa 4 person
Depending upon the age, the Dream Maker has a digital thermostat which is easy to change but to be honest I don't think that is the cause of your problem.
Check the keypad connection on the PCB (circuit board).
t could be either the keypad or PCB at fault and withou trying one or the other you'll not be able to determine the problem. My advise would be for you to contact your local parts supplier and ask them whether or not they can supply you a keypad to try with the option to send it back for a refund if it doesn't cure the problem.
A keypad can be trial fitted to the PCB, just unplug the old one, plug the new one in and turn on the power. There's no need to install the keypad to the spa, therefore you wont damage it in anyway.
If the keypad doesn't cure the problem, change the PCB.
Regards,
Ian.
http://hottub.synthasite.com
Posted on Apr 01, 2010
Dream maker spaX400. has a green spa control panel keeps flashing SL. I tried setting it to F2can't get it to stay thereIt keeps going back to SL can change the temperature up down temp ofstays at 91
It is in sleep mode. Press your mode button until it says sp again then hit temp up button or whatever button you use to change the f1 f2 f4 messages.. it should change to SD or ST or SN for standard mode...
May 06, 2015 | Pool & Spa
Dream maker spa x-400 won't shut off keeps heating. I have turned it off and let it tottaly cool down the temp max temp is set to 95 and it never shuts off until it gets to 105 and overheats.
I had the same problem last year, I talked to a spa guy and he stated that the temp sensor was probably covered in bio crud. He also stated that the tub should be cleaned with a hot tub flush. After doing that I have not had a problem with the temp settings.
Jan 19, 2013 | Pool & Spa
Just filled my dream maker brand new has been filled for a couple of hours but all the temp says is ice do you know what that means
This spa is heated by waste heat from the pump. The manual says it can take up to 20 hours to get to 100F. I assume that is starting from 60F. Keep the cover on and let it run at least a day and you should have 100F+ water temperature.
Mar 01, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Breaker on the end of spa plug-in trips overnight. I can unplug it and plug back in, tub runs to it's 100 degree default settings. Will stay on and maintain all day, but overnight I will find the tub off...
I have had a few troublesome units over the year that did as you describe due to 'dew' overnight collecting around the tub and the increased moiture sent the motor of the circ pump "over the edge" iinto a grounded state. A leaking pump seal was adding to the problem. Once the seal leak along with the dew got high enough the GFI would sense the grounded condition and trip. Fixing the pump seal and drying/cleaning the motor fixed the problem every time. If you find any other leak sources around the pump you will need to fix them as well.
Oct 12, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
Pool & Spa Logo
797 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
