Question about Price Pfister Plumbing
Remove aerator in recessed Pfister faucet
Old Classic 2.2 gpm aerator
SOURCE: Replacing Cartridge Valve in Kitchen Faucet
A little WD-40 was all it took, although it was quite difficult to remove using lock wrench pliars.
Posted on Sep 15, 2009
  • 122 Answers
SOURCE: How do I remove the aerator on a moen pull out
It should just unscrew. You might need some needle nose pliers as the aerator may be slightly recessed.
Posted on Jan 28, 2010
  • 129 Answers
SOURCE: How do you remove aerator from franke pullout
A small crescent wrench should do just fine. Just be careful not to cross thread when putting it back on.
Posted on Jan 31, 2010
  • 41 Answers
SOURCE: New Price Pfister Ashfield Bath Faucet - Hot H20 pressure is weak
check if any valves are not fully open first. if its a replacement of one that was working fine then the taps are most likely duff
Posted on Mar 03, 2010
  • 409 Answers
SOURCE: I installed a Price Pfister kitchen faucet model low water pressu
yes it should have a flow restrictor in the end of the spout. You might need to clean it out
Posted on Mar 11, 2010
How do you remove the aerator housing from the Price Pfister hanover double handle bathroom sink faucet
most aerators are screwed into the faucet
IF you use a pair of multigrips with clothe folded in the jaws , you can apply gentle pressure and turn it out
too much pressure and you will distort the aerator so be gentle with it
Jun 01, 2016 | Price Pfister Plumbing
Is there a water restricter in this faucet
without manufacturer name and model, the best answer is a guess. most faucets have aerators which can limit the GPM (gallons per minute flow rate)of a faucet. with relative ease an aerator can be removed, disabled, and reinstalled to permit free flow from the faucet without making too much of a mess.
Aug 24, 2014 | Plumbing
Price pfister faucet repair classic cupc
hand sprayers are often designed to aerate
Oct 17, 2013 | Plumbing
We have a new Price Pfister 49 Series bathroom faucet set with two handles. Even with the hot water tap open full the water just dribbles out
If you have full pressure on the cold water side and low pressure on the hot side then you well need to remove and clean or replace the cartridge for the hot side. If you have low water pressure on both sides try removing the aerator and cleaning it.
If you need to replace the cartridge on the hot side do both sides while you at it.
Whenever you work on any faucet before you turn the water on remove the aerator and run the water for a few seconds then replace the aerator.
Mar 07, 2011 | Price Pfister Two Handle Lavatory Faucet -...
Water just trickles out of tap
The problem most likely is a clogged aerator. That is the part that sticks out of the faucet that the water comes out of. You need to unscrew it, take it apart, and then remove any particles that are inside. Sometimes the easiest solution is to buy a new aerator at a hardware store. Take the old one in to make sure you get one that will fit.
Before replacing the aerator, run the faucet without it for a minute or so to clear out any remaining debris.
Unscrewing the aerator: Looking down on the faucet from above the sink, turn the aerator (which will be on the far side of the faucet) clockwise to remove it. You may have to grab it (carefully) with a pair of pliers. Close the drain before you do this so you don't loose any parts down the drain.
Jan 16, 2011 | Price Pfister Plumbing
I installed Series 26 Avalon faucet. The water flow rate is very slow. All fittings to the faucet are new. Could the problem be a faulty valve ?
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Aug 28, 2010 | Price Pfister Plumbing
How do I remove the aerator on a moen pull out kitchen faucet?
Jan 27, 2010 | Blanco Classic Single Handle Faucet with...
Flow is very weak - less than 1 gpm. Ewplaced
There are little rubber restrictors in the stainless supply hoses you can pry them out with a small screw driver
Nov 10, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
87 people viewed this question
Top Price Pfister Plumbing Experts
bwbconstruct
Level 1 Expert
john h
TED
Level 1 Expert
Are you a Price Pfister Plumbing Expert? Answer questions, earn points and help others
