Question about Pioneer DEH-1500 CD Player
Wire by color for pioneer deh-150mp
Just need to know what the colors are.
  • 4 Answers
SOURCE: pioneer deh-p3500 memory wire color
12V Battery, Memory/Constant wire Yellow
FYI:
12V Accessory Wire Red
Ground/Chassis Wire Black
Left Front Speaker, Positive (+) White
Left Front Speaker, Negative (-) White w/Black Stripe
Right Front Speaker, Positive (+) Grey
Right Front Speaker, Negative (-) Grey w/Black Stripe
Left Rear Speaker, Positive (+) Green
Left Rear Speaker, Negative (-) Green w/Black Stripe
Right Rear Speaker, Positive (+) Purple
Right Rear Speaker, Negative (-) Purple w/Black Stripe
Remote Out, Power Antenna Blue
Remote Out, Power Amplifier Blue w/White Stripe
Posted on May 31, 2008
  • 15 Answers
SOURCE: pioneer deh-p6800mp wiring
You can find the wiring diagram online in a PDF of the installation manual, which is at this location
Hope that helps!
Posted on Jan 14, 2008
SOURCE: wiring diagram
where do you hook up power wires to
Shdak
  • 23 Answers
SOURCE: what is the speaker wire color code for pioneer
Crutchfield has allot of information on Pioneer receivers. They also have a number you can call for support. The wiring diagram can be found here: PDF File
Posted on Apr 06, 2009
lostinfamily
  • 149 Answers
SOURCE: need wiring diagram for pioneer deh-p4000ub
http://akamaipix.crutchfield.com/Manuals/130/130DEHP4UB.PDF
Here is the PDF file for your radio. On page 63 is the start of the wiring diagram. I hope this helps. Please Rate this solution
Posted on May 20, 2009
Need a wiring diagram for a DEH-X6600BT. IT'S GOING IN A 1993 CHEVY ASTRO VAN. I KNOW KNOW THE WIRES OF THE VAN. I NEED TO KNOW WHAT TO CONNECT TO ON THE RADIO. THAY ARE DIFFERENT COLORS.
I hope someone comes along who can help; in the meantime, you might try the following. Naturally the power wires will be 12V and usually red(+) and black(-), if they're not, you can examine the other colors, to determine if their are separate ground wires for each speaker. If it uses a remote, and you want to hook that up; I can't help. sorry. But, if the speakers have a common ground, there will only be 1 wire for each speaker, the other connects to the ground of the car. If there are two wires for each speaker, they will be 4 different colors, with a 2nd wire which has the same color for all 4 speakers, so each speaker has a colored wire, and a common colored wire. This will leave the power connections, unless you have other controllers (see above).
One you know which are the power wires, you can connect them to a spare 12 V battery, and then comes the fun part. While adjusting the radio for front back, left and right, using the colored and a common wire for each speaker, this will be the same as the ground wire for the power even if not the same color, you can connect it to ground for the test. Then connect the colored wire and common wire to a speaker, by adjusting the controls you can find out if that colored wire is for front or back, left or right. Then you'll have your color code.
Although prolonged use of only one speaker or only two could cause damage to the radio, short use to troubleshoot at low volume shouldn't be an issue. Just don't use it that way.for a long time!
I hope this helps. Let me know.by rating up my answer! :-)
Sep 03, 2015 | Cars & Trucks
My bike is 2004 vstar 1100 classic its red and champane color I need to know what colors was that for that bike
That year it was called Beach Sand Tan / Raspberry Metallic and it was a $200 paint option for that model.
Apr 29, 2014 | 2004 Yamaha V Star 1100 Classic
I WANT TO KNOW THE COLOR S CODE OF MY BLACK & GRAY 2006 HAYABUSA
try on this site
http://www.cyclechaos.com/4um/f44/stock-hayabusa-paint-codes-color-names-29177/
Feb 18, 2013 | 2007 Suzuki GSF 1250 Bandit S
I need to know what color wire goes to what
Unless some one has replaced the wires in the harness everything is color coded blk to blk,green to green,brown to brown etc.
May 09, 2010 | 2003 Yamaha YZF-R1
Need correct paint color code.
When you go to the paint store, they look up the vin and that number has the paint number in it. They know what it is and how much you need, just bring your check book. You might find the code on the door post, it usually has all that info. Hope this helps. Oh yeah, the rattle can has GM colors too, You could check them out.
Apr 08, 2010 | 2000 GMC Sonoma Extended Cab
I want to know the perfect color settings for the th-42px80u
The Settings are :-
-Picture menu Picture mode: Custom
Picture: +80
Brightness: +60
Color: +44
Tint: -8
Sharpness: 0
Color temp: Warm
Color management: On
x.v.Color: Off
Zoom adjust: [grayed out]
-Advanced picture submenu
Video NR: On
3D Y/C filter: [grayed out]
Color matrix: [grayed out]
MPEG NR: [grayed out]
Black level: Light
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 10, 2010 | Panasonic Viera TH-42PX80U Plasma TV
Hi i need to know the color code to assemble a new 3 prong stereo 1/4 inch jack for a shure sm 58 microphone. i need to know the order and color to reassemble the mic cable to a new 1/4 inch guitar type...
Unfortunately, different cables use different colors of wires. Thus, you'll have to see what colors are connect to both ends of the cables. Here is the wiring:
XLR -> 1/4 inch
Pin 1 -> Sleeve
Pin 2 -> Tip
Pin 3 -> Sleeve
Dec 24, 2009 | Audio Players & Recorders
Stereo wireing color codes for 2004 suzuki forenza
you are a ******* idiot you+this answer= you are ******* stupid we don't want to know what our best bet is you damn inbred **** we want color codes!!!!! God you are dumb what color means what its like putting the caps back on the right markers in your coloring box with your little books that you cant even color inside the lines cause you are so stupid!!!!!!
Dec 09, 2008 | 2004 Suzuki Forenza
Printer won't print in color
You should not need to program it to print color, it should just print.
How old is the machine and are you sure the color ink cartridge is good (not empty)?
Dec 02, 2007 | Canon PIXMA iP2000 InkJet Printer
Pioneer DEH-1500 CD Player Logo
8,336 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
