Question about HP Mini 2140 Notebook
Am clicking the desktop or inside icons it should automatically shown a delete dialog box
    New Friend:
Try to scan ur computer... with ur computer anti virus. make sure ur anti virus is totally updated. if found an virus inside. try to repair/ clean/ move or delete the virus. 2nd try to disk check ur computer to make sure to repair some errors on the hard disk.
Posted on Jan 09, 2013
How to delete Page breaks in Excel
Move a page break Important To enable dragging of page breaks to another location in a worksheet, make sure that the cell drag-and-drop feature is enabled. If this feature is not enabled, you may not be able to move any page breaks.
To verify that drag-and-drop is enabled, do the following:
Click the File tab.
  1. Under Help, click Options.
  2. In the Advanced category, under Editing options, select the Enable fill handle and cell drag-and-drop check box, and then click OK.
  3. Select the worksheet that you want to modify.
  4. On the View tab, in the Workbook Views group, click Page Break Preview.
    2. Tip You can also click Page Break Preview za010181030.gif on the status bar.
    3. Note If you get the Welcome to Page Break Perview dialog box, click OK. To not see this dialog box every time you go to Page Break Preview view, select the Do not show this dialog again check box before you click OK.
  5. To move a page break, drag the page break to a new location.
Note: Moving an automatic page break changes it to a manual page break.
Delete a manually-inserted page break Note You cannot delete page breaks that Excel has added automatically. Adding manual page breaks, changing the page orientation, or adjusting column widths and row heights may affect automatically-inserted page breaks.
To delete a manually-inserted page break, do the following:
  1. Select the worksheet that you want to modify.
  2. On the View tab, in the Workbook Views group, click Page Break Preview.
  1. Do one of the following:
    • To delete a vertical page break, select the column to the right of the page break that you want to delete.
    • To delete a horizontal page break, select the row below the page break that you want to delete.
Note You cannot delete an automatic page break.
Jul 20, 2014 | Microsoft Excel 2010
Wireless printer X4550 has stopped printing. An XL would not print and won't delete from the print queue thus nothing else can be printed. Status is "deleting"
Starting the Installation Log on to the PC as Local Administrator.
Windows 2000: Double-click on the My Computer icon on the desktop. Double-click to open the Control Panel window and then double-click on the icon labelled Printers. Double-click on Add Printer to start the Add Printer Wizard. The dialog below will be displayed.
Windows XP: From the Start menu, select the option Printers and Faxes. Click on the task Add a Printer to start the Add Printer Wizard. The dialog below will be displayed.
pwiz1.jpg Click on the Next button to display the dialog shown below. Ignore the instructions in this particular dialog box because they are incorrect.
pwiz2.jpg The Wizard provides installation options for local and network printers. Select the option Local printer if you are installing drivers for a personal printer (using a USB, serial or parallel connection). If the option Automatically detect my printer is selected, you will see the warning message below.
pwiz2a.jpg If you are installing drivers for a TCP/IP LAN printer, you should also select the option Local printer. For a LAN printer, always ensure that the Automatically detect my printer option is not selected.
The Add Printer Wizard will display the dialog below so that you can specify which port (connector) the printer uses.
pwiz3.jpg For a personal printer, ensure that the button for Use the following port is selected. From the list, select the Local Port to be used -- this is normally the parallel port, LPT1. If you are unsure, please refer to the documentation supplied with your printer or check which type of cable is being used.
thanking u for using fixya
Jul 07, 2008 | Lexmark Office Equipment & Supplies
How can i retrieve my mail icon
The use of desktop icons has served to simplify opening and using programs in Microsoft Windows.
With a simple click of the mouse, an entire program can be opened.
Unfortunately those desktop icons can also be deleted, sometimes accidentally or sometimes by the desktop cleaning utility that runs in Windows, but there is a simple process to recover desktop icons.
Just follow these steps.
Click it without a ticket.
To restore lost desktop icons, first place your mouse anywhere in a blank area on your desktop. Once you have placed your cursor in an unused area of the desktop, right click.
Check the pop up.
Once you have right-clicked your mouse in the unused area of your desktop you will receive a pop up menu or prompt.
Choose "Properties" by left clicking it with your mouse.
Grab that tab. Once you have clicked on "Properties" you will receive a dialog box.
Click on the tab labeled "Desktop."
Customize it.
Once you have clicked the "Desktop" tab choose "Customize Desktop" which will prompt another dialog box to open.
From there click on the "General" tab.
Restore order.
After you have clicked the "General" tab you will see a list of icons.
Simply choose the icons you want restored or placed on the desktop and then click "OK."
That's it.
You have now successfully restored your desktop icons.
May 04, 2014 | E-Machines eMachines Desktop PC
Lost all icons from desktop
Check the pop up.
Customize it.
Restore order.
That's it.
Aug 26, 2013 | Computers & Internet
My icns are disappeared
Check the pop up.
Customize it.
Restore order.
That's it.
Aug 14, 2013 | Computers & Internet
Can't remove wrong password from email
Which default browser ?...
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar.
This will add to your screen toolbar File Edit View Favorites Tools and Help
Click tools internet options from the drop down list tick the box and locate the section titled "Browsing History."
Read the description under browsing history to be sure it includes the option to delete temporary files, browsing history, cookies, saved passwords and web form information.
Delete browsing history on exit.
Delete Saved Passwords From a Computer
Your operating system and programs store your passwords for all of the various sites and services you use.
This approach can save time as it can minimize the need to manually type in every unique password for each site you visit.
Although convenient, it does have its downsides.
For privacy concerns, in certain instances, you may want to delete your saved passwords to prevent users from accessing confidential data.
Windows Log In
Click "Start." Type "Credential Manager" in the search field and press "Enter."
This opens a new window.
Locate the "Generic Credentials" section.
This area contains saved log-in information for various programs and services installed on your computer.
Click the down arrow to expand the items you want to delete, and then click the blue "Remove from Vault" link.
Internet Explorer
Click the "Start" button. Type "Internet Options" in the search field and then press "Enter."
Select the "General" tab, and click the "Delete..." button located in the "Browsing History" area. This runs a "Delete Browsing History" dialog on the screen.
Click to check the selection box next to "Passwords," and then click "Delete."
This deletes your saved passwords automatically and closes the second dialog.
Click "OK" on the "Internet Properties" dialog to close the Internet Options component.
Google Chrome
Open Chrome. Press and hold the "CTRL," "Shift" and "Delete" keys simultaneously.
This shortcut opens a "Clear Browsing Data" dialog.
Click to select the "Clear Saved Passwords" box.
Click the "Obliterate the Following..." drop-down menu, and select the "The Beginning of Time" option.
Click "Clear Browsing Data," and then close Google Chrome.
Mozilla Firefox
Open a Run dialog by holding your "Windows" and "R" keys simultaneously.
Type "Firefox --preferences" and press "Enter." This opens "Options."
Click the "Security" icon on the "Options" dialog box.
Click the "Saved Passwords..." button.
This opens a dialog box containing a list of saved passwords.
Click the "Remove All" button, and then click "Close."
This returns you to "Options." Click "OK" to close the dialog box.
Aug 13, 2013 | Computers & Internet
Hitachi How To
Check the pop up.
Customize it.
Restore order.
That's it.
May 13, 2013 | Computers & Internet
My desktop is running very slow
to speed up your desktop you should perform following operations :-
  • go to your start button, and click on the option accessory. Then go to system tools in the accessory option and then click on disk clean up option.
  • the second method to speed up your desktop is- press windows button+r to open the run window.
  • then type %temp% in the run window dialog box and then press enter.
  • whole temporary files of your desktop will appear in a window. then press ctrl+A to select all files and the press Shift+delete to delete those files permanently.
  • deletion of these temporary files does not harm your desktop.
  • Another way to speed up your desktop is to clear prefetch files from your desktop.
  • press window key+r and then type prefetch keyword in the dialog box and press enter.
  • then a window will appear.select all the files shown in the window and delete them by pressing shift+delete
Jun 01, 2011 | Microsoft Windows XP Professional for PC
I have sony vaio S. but the wirelees is not working no wireless host shown. how can i fix it?
Selecting the wireless function Follow the steps below to select the wireless function to be activated when you set the WIRELESS switch on your computer to on. Double-click (wireless switch icon) on the Notification area at the bottom right of the desktop.The Wireless Device Switch dialog box appears. Hints The appearance of the wireless switch icon changes depending on the selected wireless function. Point to the wireless switch icon to display the selected wireless function. Alternatively, you can right-click the wireless switch icon and select "show Wireless Device Switch settings" to display the Wireless Device Switch dialog box. Select the desired wireless function from "Wireless LAN" or "Bluetooth Device". Notes 5 GHz Wireless LAN is available on certain models only. You must select at least one wireless function to perform wireless communications. The 2.4 GHz and 5 GHz Wireless LAN functions employ different frequency bandwidths, thus are not compatible with each other. Checking the check box for both "Enable 2.4 GHz Wireless LAN" and "Enable Bluetooth Device" may cause poor communication performance or a connection loss due to electromagnetic interference. Click OK. The message "Setting up the wireless devices. Process may take several minutes. Please wait." appears first, then the Wireless Device Switch dialog box is closed, and finally the dialog box that describes what to do with the icon on the Notification area appears. Note While the message "Setting up the Wireless Devices. Process may take several minutes. Please wait." is displayed, do not: place your computer into power saving mode. turn off Windows or log off from the current user. turn on and off the WIRELESS switch. Confirm the settings and click OK. The dialog box about the icon on the Notification area closes. Hint If you check the "Don't show this dialog in the future" check box, the dialog box will not appear next time you close the Wireless Device Switch dialog. To analyze the network condition You can analyze the network condition if you select either or both of the wireless functions under "Wireless LAN" in step 2 above. Click the "Diagnose" button to start Windows Network Diagnostics. When the network analysis is complete, the result is displayed. If any problems are found, follow the on-screen instructions. Hint Windows Network Diagnostics is the function to identify problems the network has and present solutions to them.
Mar 01, 2011 | Sony Computers & Internet
My computer displays the normal windows with its desktop icons but automatically shuts down. there's a dialog box that appears but i cant read the content because it disappears in a flash, what do you...
when your desktop loads, click on start menu, run, and wright: cmd
then wright: shutdown -a (in the command promp)
and hitt enter.
the dialog should disappear, restart the pc and check if it comes again that u need to make the same prosses again plus, going to msconfig (righting it in run), and then to the bookmark saying start up and uncheck any suspisious programe, locate its files,delete them,apply and restart again.
May 12, 2010 | Samsung 80GB INTERNAL 3.5- IN SATA HDD...
HP Mini 2140 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
