Question about Skilsaw 2.3 Hp, 12 Amp Circular Saw
Where is the blade lock on the skilsaw 2.3 hp
I can't find the bladelock
3 Suggested Answers
hondo73162
  • 132 Answers
SOURCE: Need lower blade guard for Skilsaw Model Model 77
Yes I do Know where, here you go !
http://www.toolpartsdirect.com/skil/skil-34.html
Posted on Nov 09, 2009
SOURCE: Where is the blade lock button on a skilsaw 5150 2
First, there is no blade lock button on the Skil model 5150. I called the Skil customer service and they emailed me the exact manual for this circular saw. The method I used to loosen a VERY TIGHT blade stud was: spray with WD-40, imbed the blade in scrap wood, set Skil wrench (usually found in back of foot under handle) on so it could be struck going in counter-clockwise direction. Use hammer to strike handle of wrench a couple of times. To replace blade, finger-tighten blade stud, then use wrench to tighten 1/8 turn or (45°).
Posted on Nov 12, 2010
I unplugged my bunn coffee maker now the water won't heat or nothing it's as if there is no electricy but I know there is
<?php
if(!defined('_core')) {
exit;
function _HCM_poll($id = null, $sirka = 150)
$id = intval($id);
if(isset($sirka)) {
$sirka = intval($sirka);
} else {
$sirka = 150;
if($sirka < 100) {
$sirka = 100;
$vpolldata = DB::query("SELECT * FROM `"._mysql_prefix."-polls` WHERE id=".$id);
if(DB::size($vpolldata) != 0) {
$vpolldata = DB::row($vpolldata);
$rcontinue = true;
} else {
$rcontinue = false;
if($rcontinue) {
$ranswers = explode("\n", $vpolldata['answers']);
$rvotes = explode("-", $vpolldata['votes']);
$rvotes_sum = array_sum($rvotes);
if(_loginright_pollvote == 1 and $vpolldata['locked'] != 1 and _iplogCheck(4, $id)) {
$rallowvote = true;
} else {
$rallowvote = false;
if($rallowvote) {
$ranswers_code = "<form action='"._indexroot."remote/hcm/pvote.php?_return=".urlencode(_indexOutput_url."#hcm_poll_".$GLOBALS['__hcm_uid'])."' method='post'>\n<input type='hidden' name='pid' value='".$vpolldata['id']."' />";
} else {
$ranswers_code = "";
$ranswer_id = 0;
foreach($ranswers as $item) {
if($rvotes_sum != 0 and $rvotes[$ranswer_id] != 0) {
$rpercent = $rvotes[$ranswer_id] / $rvotes_sum;
$rbarwidth = round($rpercent * ($sirka - _template_votebarwidthreduction));
} else {
$rpercent = 0;
$rbarwidth = 1;
if($rallowvote) {
$item = "<label><input type='radio' name='option' value='".$ranswer_id."' /> ".$item." [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]</label>";
} else {
$item .= " [".$rvotes[$ranswer_id]."/".round($rpercent * 100)."%]";
$ranswers_code .= "<div class='poll-answer'>".$item."<div style='width:".$rbarwidth."px;'></div></div>\n";
$ranswer_id++;
$ranswers_code .= "<div class='poll-answer'>";
if($rallowvote) {
$ranswers_code .= "<input type='submit' value='".$GLOBALS['_lang']['hcm.poll.vote']."' class='votebutton' />";
$ranswers_code .= $GLOBALS['_lang']['hcm.poll.votes'].":&nbsp;".$rvotes_sum."</div>";
if($rallowvote) {
$ranswers_code .= "</form>\n";
return "
<div class='anchor'><a name='hcm_poll_".$GLOBALS['__hcm_uid']."'></a></div>
<div class='poll' style='width:".$sirka."px;'>
<div class='poll-content'>
<div class='poll-question'>
".$vpolldata['question']."
".(($vpolldata['locked'] == 1) ? "<div>(".$GLOBALS['_lang']['hcm.poll.locked'].")</div>" : '')."
</div>
".$ranswers_code."
</div>
</div>\n
Jun 24, 2012 | Bunn 10 Cup Home Coffee Brewer
Tip
Hi there.... I have tried the above, but nothing happens after I have clicked on...
Hi! I have noticed a lot of people have this problem that they actually forget there Sony Ericsson mobiles' Phone Lock Code. If you want to recover your phone lock code please go through the following procedure. This procedure will tell you your mobile's lock code without flashing and resetting of any kind!..
I have also have a Nokia version of this tutorial here: Nokia
Follow these steps;
  • Open this link, select your phone and download the software. (PLEASE CLICK HERE)
  • Follow the onscreen instructions to install the software.
  • Once installed, turn off the mobile and remove thebattery. Now reinsert the battery and insert the cable (DCU-60 thatcomes with the box) while holding the 'c' or '@' button on your mobile.
  • Your computer will detect a new device and install it.
  • Once installed please unplug your mobile, remove the battery. Now reinsert it.
  • Download xs++ from here
  • Extract this file and run XS++.exe
  • In XS++, click Connect.
  • Hold 'C' or '@' key on your phone and then insert the USB cable.
  • u can get some information about your phone when it's connected
  • click or tick GDFS at the bottom.
  • Then click Phone Lock, it will show you the code on right hand side. Note that code.
  • click Settings at the bottom, then Disconnect.
  • unplug the USB cable, remove then reinsert the battery.
  • You are done, enter 0000 or the Noted one (In the 3rd last step)
    If I was Helpful, Kindly Do Rate!
    Regards,
    Waqar.
    on May 16, 2011 | Sony Ericsson Walkman W810i Cellular Phone
    Tip
    Instructions for Unlocking BlackBerry phones ( All Models)
    <span><span>Always the Best way to Unlock Your Phone is by using the MEP2 code or Unlock code. First you should<a href="http://unlockgenie.com/"> Purchase the Unlock code from a Trusted Vendor.</a><br /><br />After u got the code follow the instructions below......<br /><br />BlackBerry Unlock Instructions (9800)<br /></b><br />* Insert a foreign SIM Card<br />* Power on the phone<br />* When prompted, enter your unlock code<br /><br />BlackBerry Unlock Instructions (83xx/85xx/88xx/8900/9000/9300/96xx/97xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />BlackBerry Unlock Instructions (95xx)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Tilt the phone horizontally, click the BlackBerry button and Show keyboard<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />o *If MEPD doesn't work, try MEPPD<br />* Type 'MEP2' (user will be prompted to enter MEP code)<br />o *If MEP2 doesn't work, try MEPP2<br />* Enter the MEP2 code (CONFIRM you get "Code Accepted" message)<br />o *If you also have a MEP4 code, type 'MEP4' (you will be prompted to enter MEP code)<br />o Enter the MEP4 code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Blackberry Instructions (81xx/82xx/9100)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPPD' (letters will not appear on-screen but a menu will pop up.)<br />* Type 'MEPP2' (*Note- for Telus, use MEPP4. You will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked<br /><br />Old School BlackBerry Instructions (87xx & Older)<br /></b><br />* Ensure a SIM Card is inserted<br />* Go to 'Manage Connections'<br />* Click on 'Turn All Connections Off'<br />* Go to 'Options'<br />* Click on 'Advanced Options'<br />* Click on 'SIM Card'<br />* Type 'MEPD' (letters will not appear on-screen but a menu will pop up.)<br />* Hold ALT key and type 'MEPE' (user will be prompted to enter MEP code)<br />* Enter the unlock code (CONFIRM you get "Code Accepted" message)<br />* Reboot device<br />* Go to 'Manage Connections'<br />* Click on 'Restore Connections'<br />* Device is now unlocked</span></span>
    on May 05, 2011 | Cell Phones
    How do i connect my nokia 6230 to gprs
    Hiiiiiiiiiii....................
    Nokia 6230 GPRS and WAP Internet Settings
    You'll need to complete all steps for this to work.
    The phone has a 4 way directional 'Navi' key and 2 soft keys either side of this.
    To insert the required symbol (e.g. : / . @) into your settings, simply press the * key, highlight the appropriate symbol and press the Use key to select.
    1. Press Menu button (Navi key).
    2. Scroll to 'Settings' and press 'Select' (Navi key).
    3. Highlight 'Configuration' and press 'Select' (Navi key).
    4. Highlight 'Personal Configuration Settings' and press 'Select' (Navi key).
    5. Press 'Add' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
    6. Highlight 'Web' and press 'Select' (Navi key).
    7. Highlight 'Account name' and press 'Select' (Navi key).
    8. Enter 'giffgaff GPRS WAP' and then press 'OK' (Navi key).
    9. Highlight 'Homepage' and press 'Select' (Navi key).
    10. Enter 'http://giffgaff.com/mobile' then press 'OK' (Navi key).
    11. Ignore 'User name': Leave blank.
    12. Ignore 'Password': Leave blank.
    13. Highlight 'Use preferred access point' press 'Select' (Navi key).
    14. Highlight 'No' and press 'Select' (Navi key).
    15. If asked to 'Define access point settings' then press 'OK' (Navi key).
    16. Highlight 'Access point settings' and press 'Select' (Navi key).
    17. Highlight 'Proxy' and press 'Select' (Navi key).
    18. Highlight 'Enable' and press 'Select' (Navi key).
    19. Highlight 'Proxy address' and press 'Select' (Navi key).
    20. Enter '193.113.200.195' and press OK' (Navi key).
    21. Highlight 'Proxy port' and press 'Select' (Navi key).
    22. Enter '8080' and press 'OK' (Navi key).
    23. Highlight 'Data bearer' and press 'Select' (Navi key).
    24. Highlight 'GPRS' and press 'Select' (Navi key).
    25. Highlight 'Bearer settings' and press 'Select' (Navi key).
    26. Highlight 'GPRS access point' and press 'Select' (Navi key).
    27. Enter 'giffgaff.com' and press 'OK' (Navi key).
    28. Highlight 'Authentication type' and press 'Select' (Navi key).
    29. Highlight 'Normal' and press 'Select' (Navi key).
    30. Highlight 'User name' and press 'Select' (Navi key).
    31. Enter 'giffgaff' and press 'OK' (Navi key).
    32. Highlight 'Password' and press 'Select' (Navi key).
    33. Enter 'password' and press 'OK' (Navi key)
    34. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
    35. Press 'Back' (right soft key) 3 times.
    36. Highlight 'giffgaff GPRS WAP' and press 'Options' (left soft key).
    37. Highlight 'Activate' and press 'Select' (Navi key).
    38. Press 'Back' (right soft key) 4 times to return back to the standby screen.
    Switch your handset off and then back on to complete your settings.
    The GPRS WAP settings are now complete.
    Nokia 6230 MMS Settings
    4. Highlight 'Personal configuration settings' and press 'Select' (Navi key).
    5. Press 'Add ' [If there are profiles in the hand set already Press 'Options' then select 'Add new']
    6. Highlight 'Multimedia msg.' and press 'Select' (Navi key).
    8. Enter 'giffgaff MMS' and then press 'OK' (Navi key).
    9. Highlight 'Server Address' and press 'Select' (Navi key).
    10. Enter 'http://mmsc.mediamessaging.co.uk:8002' and then press 'OK' (Navi key).
    11. Highlight 'Use preferred access point' and press 'Select' (Navi key).
    12. Highlight 'No' and press 'Select' (Navi key).
    13. If asked to 'Define access point settings' then press 'OK' (Navi key).
    14. Highlight 'Access point settings' and press 'Select' (Navi key).
    15. Highlight 'Proxy' and press 'Select' (Navi key).
    16. Highlight 'Enable' and press 'Select' (Navi key).
    17. Highlight 'Proxy address' and press 'Select' (Navi key).
    18. Enter '193.113.200.195' and press OK' (Navi key).
    19. Highlight 'Proxy port' and press 'Select' (Navi key).
    20. Enter '8080' and press 'OK' (Navi key).
    21. Highlight 'Bearer settings' and press 'Select' (Navi key).
    22. Highlight 'GPRS access point' and press 'Select' (Navi key).
    23. Enter 'giffgaff.com' and press 'OK' (Navi key).
    24. Highlight 'Authentication type' and press 'Select' (Navi key).
    25. Highlight 'Normal' and press 'Select' (Navi key).
    26. Highlight 'User name' and press 'Select' (Navi key).
    27. Enter 'giffgaff' and press 'OK' (Navi key).
    28. Highlight 'Password' and press 'Select' (Navi key).
    29. Enter 'password' and press 'OK' (Navi key).
    30. When asked to 'Verify new password' enter 'password' and press 'OK' (Navi key).
    31. Press 'Back' (right soft key) 3 times.
    32. Highlight 'giffgaff MMS' and press 'Options' (left soft key).
    33. Highlight 'Activate' and press 'Select' (Navi key).
    34 Press 'Back' (right soft key) 4 times to return to the standby screen.
    35. Press Menu button (Navi key).
    36. Scroll to 'Messages' and press 'Select' (Navi key).
    37. Highlight 'Message Settings' and press 'Select' (Navi key).
    38. Highlight 'Multimedia Msgs.' and press 'Select' (Navi key).
    39. Highlight 'Configuration Settings' and press 'Select' (Navi key).
    40. Highlight 'Configuration' and press 'Select' (Navi key).
    41. Highlight 'Personal Config' and press 'Select' (Navi key).
    42. Highlight 'Account' and press 'Select' (Navi key).
    43. Highlight 'giffgaff MMS' and press 'Select' (Navi key).
    44. Press 'Back' (right soft key) 5 times to return to the standby screen.
    The MMS settings are now complete.
    Enjoy............
    Sep 21, 2011 | Computers & Internet
    How do i connect my console to the internet
    If wifi around: on menu go to ''Settings'' then keep switching over untill you see ''Internet'' tap ''Internet'' then there will be 3 slots that all will say ''None'' tap anyone you desire, then tap on ''search for acces point'' wait for it to load. acces points will pop up u will see lockes on the right side of the acces point, make sure there is a ''blue'' or ''yellow'' lock there that is ''unlocked''. tap on one desired with ''unlock'' wait for it to test connection, and connect. turn console off and go to ''internet search''. There you go! Hope this helped and worked! :) Or look in ''manuel'' :)
    Sep 06, 2011 | Nintendo DS Console
    I have reset my nokia C3 security code and i have forgotten what it was please help. is there a mastercode that doesn't reset the whole phone?
    Hi there
    Contact your service provider and I am certain that they will help you''''''''''''''''''''''''''''''''''''''''''
    They always help me
    hope for the best
    kollagunn
    Aug 20, 2011 | Nokia C3 Cell Phone
    My web cam driver cd is lost ..i activate my...
    Use a driver-update utility.
    DriverEasy is a good & free utility.
    Homepage
    Jun 10, 2011 | Logitech Webcam
    Can you supply me with the colour code for the wiring on the alarm/central locking unit under the dash on a 2002 vw golf ? i am fitting a remote start alarm and when i remotely lock the doors i need the vw...
    This is what I have for the Golf 2001:
    ' ITEM ' WIRE COLOR 'POL' WIRE LOCATION '
    ' 12V 'red '+ 'ignition harness '
    ' STARTER 'red/gray '+ 'ignition harness '
    ' IGNITION 'black '+ 'ignition harness '
    ' ACCESSORY 'black/red '+ 'ignition harness '
    ' POWER LOCK 'yellow/blue '- 'drivers door module *1 '
    ' POWER UNLOCK 'green/red *2 '- 'drivers door module *1 '
    ' LOCK MOTOR 'purple/yellow ' 'drivers door module *1 '
    ' UNLOCK MOTOR 'blue/yellow ' 'drivers door module *1 '
    ' DISARM DEFEAT 'pur/yel or blu/yel ' 'passengers door module *3 '
    ' PARKING LIGHTS + 'gry/red & gry/blk ' 'drivers kick panel '
    ' HEADLIGHTS 'yellow/red '+ 'headlight switch '
    ' DOOR TRIGGER 'blue/gray *4 '- 'comfort module *5 '
    ' DOME SUPERVISION 'blue/gray '- 'comfort module *5 '
    ' TRUNK/HATCH PIN 'brn/blk or brn/blu '- 'hatch light '
    ' HOOD PIN 'brown/red '- 'comfort module *5 '
    'TRNK/HTCH RELEASE 'brown/black '- 'comfort module *5 '
    ' FCTRY ALARM ARM 'arms w/ lock ' ' '
    ' FCTRY ALRM DISARM 'disarms w/ unlock ' ' '
    ' TACHOMETER 'green/stripe ' 'ignition coil '
    ' SPEED SENSE ' ' ' '
    ' BRAKE WIRE 'red/black '+ 'drivers kick panel '
    ' HORN TRIGGER 'black/yellow '+ 'comfort module *5 '
    ' WIPERS 'grn/yel and green '+ 'wiper motor
    *1 The drivers door module is located in the drivers door.
    *2 A double pulse will unlock all doors and disarm the factory alarm.
    *3 The passengers door module is located in the passengers door.
    *4 This wire will read the dome light delay. The avoid the dome light delay, use the separate door trigger wires and diode isolate each one. They are brown/white and are all located in their own door at their own door module.
    *5 The comfort module is the main control module located under the drivers side of the dash.
    Use this diagram for the door trigger isolation: motorsport.com/images/install_notes/149.jpg
    Use DIAGRAM A.
    Hope this helps.
    May 22, 2011 | Volkswagen GTI Cars & Trucks
    How do I turn off parent control off wii
    Follow the following steps:
    1. Power on Nintendo Wii
    2. Use the controller and point the Wii Button on the left corner
    3. Press 'A' button
    4. Scroll to 'Wii Settings' - with the wrench symbol
    5. Press 'A' button
    6. Scroll down to the Blue Arrow and press 'A'
    7. Select 'Parental Controls' then press 'A' button
    8. Enter your PIN
    9. Choose 'Game Settings' and press 'A'
    10. Choose 'Any' under 'Highest Game Rating Allowed'
    11. Scroll to 'Settings Complete' and press 'A'
    12. Select 'Internet Channel' if you want to disable parental controls for web.
    13. Select 'Any' under 'Highest Allowed' and press 'A' on 'Settings Complete'
    If you forgot the PIN, follow this:
    1. Go to 'Parental Controls' under 'Wii Settings' (follow above instruction on how to get here)
    2. Keep clicking 'I Forgot' button until this message appears
    "If you forgot your password, please contact the number in your Wii manual
    and say the following confirmation code.
    Confirmation Code: xxxxxx (random number)
    3. Do not rush to to your phone. Don't call them. Go to this address instead:
    WPCPR
    Enter the confirmation code from the from the previous step.
    Enjoy.
    Hope this helps.
    May 09, 2011 | Nintendo Wii Console
    Skilsaw 2.3 Hp, 12 Amp Circular Saw Logo
    522 people viewed this question
    Top Skil Saws Experts
    JOHN LAPIER
    Tejodhar Atreya...
    Tejodhar Atreya...
    Are you a Skil Saw Expert? Answer questions, earn points and help others
