Question about GE Eterna EGR2000EMBB Gas Kitchen Range
GE Eterna Series oven doesn't heat up
XL44...it also has SPECTRA ON THE FRONT WHERE YOU TURN THE OVEN TEMP ON. there is no heat at all after setting oven temp
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
  • 57 Answers
SOURCE: Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
Posted on Dec 02, 2008
  • 126 Answers
SOURCE: ge spectra xl44 heats up but doesn't maintain heat
Turn oven to 350"look for ignition glow .within 30-60 seconds the burner should fire .if it takes too long ignitor is weak (not drawing 3.5+ amps and should be replaced).Sometimes the ignitor will work for the first couple of cycles and then die down. bad sensor would usually show f- code.
Posted on Jun 27, 2009
  • 12 Answers
SOURCE: ge gas oven not working
thermocoupler needs to be replaced...
Posted on Dec 12, 2009
  • 382 Answers
SOURCE: GE Profile Spectra Electric Oven.
call a appliance and parts store give them the tear and model number from stove it is inside the door or on back it5 mkay also be on the top under the fuse panel access door
Posted on Dec 27, 2009
Xl44 spectra oven temp very low
Fixya does not sell parts and cannot recommend sources.
Jul 18, 2017 | GE Spectra JGBP35 Gas Kitchen Range
Unable to locate where o re-light the bake burner on this spectra xl44 oven
Your oven does not use a pilot light it has a electric igniter that comes on when the oven is turned on and that is the most common thing thats wrong with a gas oven when it doesn't heat ..that the electric igniter is defective
GENE
Sep 16, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a GE xl44 Gas stove. Oven will light, but not maintain temp. Broiler works fine. Ideas?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 19, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra eterna series gas stove broiler will not fire up. The glow plug gets hot, but the broiler fails to start.
I have an GE Spectra Eterna Series where the oven comes on and only gets warms no matter what setting the oven is set at. Can some one solve this problem?
Mar 07, 2010 | GE Eterna EGR2000EMBB Gas Kitchen Range
Ge gas oven not working
Dec 12, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra oven xl44 model # JGBP85WEB5WW oven will not heat
heatman101
Nov 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL44 oes not heat to desired setting
The oven sensor ( WB21X5301) is suppose to tell the oven control when to turn on and off to reach and maintain oven temp, but before you go replacing it, try to observe how long it takes from the time you turn the oven on to the time the oven ignites. Ignition should be 30 seconds to about 90 seconds. If it is taking a very long time, replace the igniter (
WB2X9154
). Ignitors get weaker over time, and this should be looked at first, as both parts are not real cheap, so you don't want to just start throwing parts at it. Here is a trick you can try: On the JGBP90 (model you posted under) the broil ignitor is the same part number as the oven ignitor, so if the broiler, which is generally used much less than the oven, is working fine you can interchange the two ignitors to see if that solves your oven temp problem without having to buy a oven temp sensor first.
Nov 10, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge xl44
GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Eterna EGR2000EMBB Gas Kitchen Range Logo
18 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
