Question about LEVITON 109-05225-WSP SWITCH SP W/GD OUTLET WHITE
How to wire leviton 109-05225-wsp switch - LEVITON 109-05225-WSP SWITCH SP W/GD OUTLET WHITE
3 Suggested Answers
  • 2841 Answers
SOURCE: I have just installed 2 Leviton decora switch with
This is a single pole light switch and should be wired as any other SP switch. The only difference is that is has a pilot light. All the white neutral wires are tied together and then pushed back in the box with none connected to the switch. The grounds are tied together with a jumper wire connected to the green screw on the switch. That will leave you with 2 or more black wires. If you have just two normally you can connect them to the two screws on the switch and it does not matter which screws. However it may be that with the pilot light you need to connect the wire going to the light to the top screw and the power wire to the bottom or vice versa. Try both ways. If you have more than 2 black wires you need to connect the incoming power black wire and outgoing power black wires together and then jump to one of the screws on the switch. The black wire left over is the black wire going to the light itself. If none of this works then it is obvious the pilot light in the switch is burnt out.
Posted on Jan 06, 2010
Testimonial: "Thanks a million. I will recheck the wiring tomorrow. Chas"
  • 351 Answers
SOURCE: how to install leviton 5225 wsp wall
For this combo , the white wires connect to the two silver screws on one side of the combo .The black power wire connects to the screw next to the switch. IF you want to have the receptacle hot all the time then jumper the hot black from the switch screw to the receptacle screw. The screw in the center is for the black wire from any lihghts that you want to control. IF it is the receptacle that you wish to control with this switch .. then the power connects to the screw next to the switch and the center screw jump a wire to the screw next to the receptacle
Posted on May 04, 2010
How to wire a leviton 5634 for agarbage disposal
If you are replacing an existing switch, either replace one wire at a time, or write down the wire colors from the old switch.
or look here: http://www.leviton.com/OA_HTML/LevitonSearchResults.jsp?kw=5634+wiring+diagram&tbon=D
May 16, 2014 | Leviton R03-5634-A Two Single-pole...
Fan speed control on 2 way circuit
1) Guessing you have 3-way switch where 2 different switches control same Load (light, fan, motor). Unknown wiring, and unknown if fan and light are wired separately.
2) Google search for 3-way fan switch shows Leviton IPF05 with simple straight-forward wiring. Link below has instruction manual, and Live chat button located to right of LEVITON
http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=IPF05-1LX&section=47082&minisite=10251
3) It appears that the Leviton device must replace Line side switch.
http://waterheatertimer.org/images/GE-15312-3-way-circuit-600.jpg
4) Uncertain if this device also controls fan since the wiring is so simple.
Feb 22, 2013 | AMS Lutron SFSQ-F-HO Skylark Single-Pole...
What model Leviton GFCL should I use? My wire is a 600 volt 12/2 with ground. Said wire feeds other GFCL outlets.
Any off-the-shelf GFCI sold today with work on 12-2 wire:
By code, 12-2 wire should be connected to 20 amp circuit breaker, but typically most switches and outlets wired to that circuit are rated 15 amp. Amp rating is printed on electrical devices.
Leviton 15 amp 7599-W:
http://www.amazon.com/Leviton-7599-W-Receptacle-Feed-Through-SmartlockPro/dp/B000VYO9MU/ref=pd_cp_hi_3
Leviton 20 amp 7899-W
http://www.amazon.com/Leviton-7899-W-SmartlockPro-Indicator-Wallplate/dp/B000N663PM/ref=pd_cp_hi_0
Wiring:
http://waterheatertimer.org/How-to-wire-GFCI.html
Jun 17, 2011 | Leviton R01-7299-0NI Switch And GFCI...
I replaced my old 3way toggle switches with the LEviton 5613 3way lighted rocker switches. Wired exactly the way the older toggle switches were wired. Switches work fine just like the older ones but one...
http://www.leviton.com/OA_HTML/ibeCCtpItmDspRte.jsp?item=4044§ion=10103&minisite=10025
The Leviton page for Leviton 5613 does not have a troubleshoot.
Manual shows simple wiring diagram.
3-way switches will not operate lights if switches are wired incorrectly.
Check your ground wire is connected.
Leviton 5613 series is illuminated.
Check that both switches have 5613 number.
Swap switches and see if problem is inside switch.
Nov 13, 2010 | Leviton 5613-2WSP Grounded Switch
I am trying to replace a two wire light switch(both white) with a leviton photoelectric 3 wire motion activated light control(red, black and green). I am trying to determine which wire goes to which?
one of the white wires has power on it constantly....that wire connects to the black wire of the leviton.......the other white wire which has no power to it is going to whatever needs power so that wire connects to the red wire of the leviton....the green wire connects to the metal box where your mounting the leviton.
Feb 08, 2010 | Leviton Decora Light Dimmer Switch
How to install leviton 5225 wsp wall switch/receptacle with three wires wilsoncarey@att.net the old switch has a pilot light /switch /receptacle
Jan 15, 2010 | Leviton 5225WSP Switch and Outlet
Leviton Dimmer Switch wiring and ceiling wiring for new kitchen table light fixture
I recently purchased a Leviton Dimmer switch which has a brown lead. This switch is to replace 1 of 2, 3 way switches that control the ceiling light in my kitchen. My problem is the new dimmer switch has 4 leads including a brown one which has me confused. I have installed and replaced numerous dimmer switches without difficulty. Please help.
Oct 10, 2009 | Leviton Decora Light Dimmer Switch
I have a black and white wire to hook to. leviton has black, blue and white. green also but thats a ground. what do i do with the blue wire? this is a single switch to a gfci then to outside lighting....
The blue wire is the switched hot wire coming from the leviton.
So:
black hot/source to black leviton -- blue leviton to black for light fixture or black "line" on GFI -- all whites connected together.
Charlie
P.S. If the GFI is only powering a light fixture, it is not needed.
Sep 23, 2009 | Leviton 6124H-A 6124H-A Decora LCD Timer...
Leviton 8299 Combination Switch / Smart lock GFCI Outlet Leviton-
power coming in from the breaker box: black wire will go to line-hot screw, and the white wire will go to the line-white screw. the switch wires coming out of the back of the gfci- 1 will go to the load-hot screw & the other black wire will wire nut to the black wire going to the light. the white wire going to the light must go to the load-white screw.
Apr 12, 2009 | Leviton 8299 Combination Switch / Smart...
LEVITON 109-05225-WSP SWITCH SP W/GD OUTLET WHITE Logo
Top Leviton Electrical Supplies Experts
 Kenneth
Kenneth
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
