Question about Maytag PGR5710 Performa Gas Kitchen Range
Maytag range stove top works but both. Roil and bake don't light. Igniters do glow though
Model number Pgr5710bdw
jyackle5
  • 8197 Answers
SOURCE: Maytag Gas Oven top burner does not turn on when in bake mode
That is the way it works. If you have an convection oven then they both work in bake mode but they alternate between the two.
Posted on Dec 17, 2008
heatman101
  • 43501 Answers
SOURCE: Maytag oven doesn't fire, but stovetop burners work fine
This will sound crazy but I had to work through it on my own stove a few years ago. The ignitor (glow tube) was getting hot but the oven would not owrk. When investigating the problem I found that the gas valve will only open when the ignitor pulls a specific amperage or draw of current. As the ignitor ages it pu;;s a reduced draw of current. This causes you to be fooled by the glow nut no gas. Replace your ignitor and your oven will begin to work again!
You can get ignitors easily online by doing a search for "appliance parts" and then entering the model number of your stove. Look for ignitor and you will be good to go. Also check out a few different sites as the prices of the parts can vary quite a bit.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help. I was looking for a thermocouple but that must be old school. I couldn't figure out what told gas to flow."
  • 54 Answers
SOURCE: Maytag oven will not ignite
If its a square glow bar it must pull 3.5 apms to open the gas valve. Round ones pull 2.5 apms. even though the glow bar is on it must be real bright. Has it been taken over 45 second to light the oven. You will need some way to check the amps. If its getting enough amps the safety valve is bad.
Posted on Apr 27, 2010
allbrands
  • 600 Answers
SOURCE: I have a Maytag gas
Hello, Thank You for using FixYa. I will be helping you today.Just because the ignitor glows does not mean its good..switch the two around and see if the oven comes on. They still glow even when they start to go bad.
Thank You and please rate my answer if it was helpful..
Posted on Jun 17, 2011
  • 910 Answers
SOURCE: Unable to use either the oven or the broiler of
Can you smell or hear gas when you try and ignite the oven or broiler?
Posted on Jul 09, 2011
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
How do you ignite pilot light on maytag gemini range
There is no pilot on most modern appliances that use a gas source for ignition. The burner manifolds in the oven each use a glow bar or electrode type igniter with a gas safety valve to ignite. Both oven manifolds are controlled by the Electronic Oven Control (EOC) board, which is your clock/timer on the control panel. you can isolate the problem by following these tips:
1. If the surface igniters work, but the oven does not, the problem is NOT a gas related issue as the surface burners and oven are commonly fed from the same source.
2. If BOTH oven igniters are not working, you more than likely, have a control board problem, or two weak or failed oven igniters (not common).
3. If one of the igniters is still working (there's one for broil and one for bake), then the problem is probably NOT the control board, but an igniter issue.
Igniters grow weak with age and occasionally need to be replaced. Just because an igniter glows, does not mean it is good. If you are experiencing longer ignition times, or no ignition, this is most likely the case. The following link explains a little theory about these igniters and how to replace one:
http://www.fixya.com/support/r3575727-replacing_an_oven_igniter_on_a_gas_range
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between these sites, so shop and compare. The first three sites listed also offer helpful exploded view diagrams to help you locate and properly identify the parts you need. The part number(s) for the model you have listed are as follows:
Bake Igniter (series 10)* - 74007399 Bake Igniter (series 11)* - 7432P143-60 Broil Igniter (series 10 and 11)* - 74007966
* The series is determined by the first two digits in the SERIAL NUMBER. If the number begins in "10", but is less than "11" it is a series 10. If the numbers is "11" or greater, then it is a series 11.
If you have any questions please post back and let me know. I hope this helps you.
Aug 15, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
Gas broiler and bake over do not work, top burners work.
Could be a board problem or the safety valve. Hard to diagnosis without being there. I'm leaning towards the board if both both burners won't light...hope this helps...
Nov 30, 2009 | Kitchen Ranges
Oven wont work after disconnecting the power
clock going out. need to check to see if your igniter is glowing. it could be glowing but still be to weak to open valve
Jun 22, 2009 | Maytag MGR5751AD Gas Kitchen Range
Oven/Broiler Igniters for KitchenAid range KGST307
Oven bake ignites usually have lifetime 5-7 years. If igniter glows but gas not came in - replace igniter. Same with broil igniter.
Dec 09, 2008 | Ovens
Maytag dual oven upper oven not heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerryrigging a bridge to wire the BAKE igniter to the BROILER controls.(Push/click plugs accessible by opening up the stove back) Testing thebroiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.)The parts and wiring are pretty simple and visual once you get thecovers off. Opening up the stove back is just a matter of removingseveral screws. UNPLUG the stove before you work. If you test as Idescribed, make all connections while UNPLUGGED and then plug it inonly for the brief test. Unplug again while disconnecting/reconnecting.Hope this helps.
Nov 25, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
Maytag Gemini gas top oven does not work.
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Jul 17, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
BAKE MODE NOT WORKING ON MAYTAG STOVE
the gas valve has gone bad change the gas valve and the glow bar (igniter) at the same time.or you WILL have problems in the future
Dec 17, 2007 | Maytag MGR5750 Gas Kitchen Range
Maytag PGR5710 Performa Gas Kitchen Range Logo
22 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
