Question about HP PHOTOSMART 7520 E-ALL-IN-ONE
Brand new hp photosmart 7520 e cartridge access door will not open!
Silan
  • 54 Answers
SOURCE: HP Photosmart C6100 All-In-One Printer stopped printing black ink
Please clean the print heads :
Press Setup up - Tools - Clean Print heads on the All-in-One.
If this does not resolve the issue , Reset the All-in-One.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
If issue stil persists. Contact HP.
Posted on Dec 24, 2007
  • 214 Answers
SOURCE: hp 2610 will not print black even with new cartridge. HELP
Try cleaning the gold contacts on cart first, with distilled water. Let dry and try again.
If not, try this one
1.Try placing sheet of black text on copy board, and run many copies black only. I ran 25x12 times still no black. Run head clean after about each 50 sheets. Persevered and finally BLACK ink OK
Inkypete
Posted on May 24, 2009
SOURCE: Had a problem with HP Photosmart C5180 All in One
Introductory cartridges come with the printer and carry special ink formulations intended for printer initialization. During initialization, inks in the introductory cartridges mix with inks in the printer to create a normal ink formulation. After initialization, introductory cartridges can be used in any compatible printer. However, if introductory cartridges that have not been through initialization are installed in a printer that has already been initialized, the printer cannot print
If the issue persists, perform these steps
try the cleaning steps advised in this link...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00709715&cc=us&lc=en&dlc=en&product=1153481
Remvoe all Cartridges, disconnect the printer from the computer and connect it to the direct wall outlet and Reset your Printer to initial factory default settings:-
* Remove the power cord from the back of the product.
* Press and hold down the OK and Help buttons at the same time.
* While still holding the buttons down, plug the power cord into the back of the product.
If the issue persists, perform these steps.
1. With machine powered on, unplug power cord from back of printer and wait for 30 seconds.
2. While holding down the "ok" and "?" buttons, plug the power cord back into the printer.
3. Let the Printer power up again and give it time to go through all of its process.
Posted on Sep 22, 2009
  • 4 Answers
SOURCE: Access door to Photosmart 3210 is stuck open and won't close
I had the same problem. This is how I solved: I just spray WD-40 on the hinges and that's it, back in bussiness. Hope works for you too
Posted on Feb 05, 2010
SOURCE: My HP Photosmart 3210xi cartridge door is also locked in open
There's no sensor, it's just a spring and a plastic wedge thing.
Using a #10 torx driver, remove two screws holding the right-hand side panel from the printer. (one in the back, one on top underneath the ink access door.) Unsnap it and set it aside.
Disconnect 3 small ribbon cables and one 5-pin connector that lead from the printer to the access door/scanner.
Remove the lid from the flatbed, then remove the access door from it's hinges. Use the torx driver and unscrew the hinges from the main scanner body.
Lift the hinge assembly from the scanner and push the steel pin out, seperating the two parts of the hinge.
From there you should be able to loosen them up, remove the springs, lubricate them, or find whatever the problem is.
Reassemble and you're done.
Posted on Feb 21, 2010
I put in a black ink cartridge and my hp photosmart 7520 printed a few copies and then I couldn't print after the first few copies - what should i do to check my hp 7520 ?
Is that a compatible cartridge!
Pay attention! if the printer won't print change the cartridge, don't try to print pages with a finished cartridge or you'll burn your printhead!
If the cartridge is HP genuine do a cleaning cycle, if it helps, great, if it won't give the cartridge back for "defective", HP Cartridges always have a warranty
Hope you found it useful!
Dec 17, 2015 | HP PhotoSmart Office Equipment & Supplies
The printer won't start up after inserting new HP cartridges. It says the print head is misinstalled,
Guess your prineter is defective. If you don't know how to repait it, you should take it to anauthorized HP service
Aug 10, 2015 | HP Photosmart 7520 All-in-One Color Inkjet...
Missing or failed printhead on first time installation
Install old cartridge,& chk..
Same error? : Problem with the printer.
Low ink error? : New cartridge faulty, claim it for replacement
Mar 18, 2013 | HP PHOTOSMART 7520 E-ALL-IN-ONE
Ink door open meassage
Open cartridge access door, observe left side door switch located, manually operate it feel weather its working or not, close door & check.. not rectified, insert peace of paper in it. check...
Feb 02, 2012 | HP Photosmart C6180 All-In-One InkJet...
How do i replace a colored and blank ink cartridge in my hp photosmart 8150?
The Open the front access door and the Carriage ( which holds the cartridges should move in center )
Push down the Cartridge ( which is in the cartridge slot ) and pull it out.
To install a new cartridge, Slide the cartridge from downwards and push up and it should get snapped.
Regards,
Ron
Feb 15, 2011 | HP Photosmart 8150 InkJet Printer
Jul 16, 2009 | HP Photosmart 3210 Printer
HP PHOTOSMART 7520 E-ALL-IN-ONE Logo
144 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
