Question about RCA D52W19 52" Rear Projection Television
Antennae & Tuners
My broke off my threaded part that the cable wire screws on to. do i have to buy another one part# 264658. also we tried turning it on and the power button just flashes and then turns off. did the happen from braking off the tunner?
  • 273 Answers
Most likley it took a fuse out on the board and the set will not run with the source voltage missing
as to the tuner some times they can be repaired or if to much damage has occoured you may have to buy a tuner for your set
Posted on Jan 21, 2009
Clutch cable broke at handle lever on 1979 harley davidson sporst
To change the clutch cable on you '79 Sporty, you'll have to take the outer primary cover off. To do this, you'll have to drain the oil from the primary, take the left side foot peg off, and loosen the primary chain adjuster on the bottom side of the primary. Loosen the locknut and use an allen wrench or hex key to screw the adjuster bolt downward.
If you need to know anything else, drop me a line at wd4ity@bellsouth.net
Then, remove the large "plug" towards the rear of the cover. Inside, you'll see something that looks like a nut but with no threads in it held in by a small spring. This the the lock nut, remove it. Below it is what looks like another nut with a slotted adjuster bolt sticking out. Remover the bolts from around the primary cover and break it loose from the engine. While turning the adjuster screw at the rear of the cover inward, remove the cover.
The cable connects to the cluch release mechanism. By turning the "link" downwards, you can disconnect it from the mechanism. Notice which way the "link" in attached to the release mechanism. Take the "link" off the end of the clutch cable.
Break the lock nut loose at the threaded cable adjuster on the outside of the case and screw the adjuster all the way out of the primary cover. Disconnect the cable at the handlebar lever and your cable is out.
Reinstall the new cable in the reverse order. When replacing the outer primary cover, make sure you use a new gasket on the cover as well as on the foot peg boss. The "foot peg boss gasket" is very important. You'll see an aluminum boss with a threaded rod sticking out of it that holds your left foot peg on. There is a round gasket that goes over this threaded rod and seals against the boss. If you leave this off, your bike will leak oil around this threaded rod when your foot peg goes on. Make sure you specifically ask for the "foot peg boss gasket" when you buy the new primary gasket. It's just a round gasket a bit larger than a quarter.
As you put the primary cover back on, there is a spring on the primary chain adjuster. Part of the spring is in the primary cover and the other part is in the engine. You'll see how it goes in. There is a large stud in that area that the outer primary cover slides up on. Adjust the tension on the primary chain by removing the "plug" at the top of the primary cover. You want 3/4" to 7/8" up and down play in the chain with the engine cold.
On the adjuster, as you're installing the outer cover, turn the ajuster screw back into the clutch release mechanism by turning the screw backwards. Once you have the outer primary cover completely installed, you must adjust the release mechanism. Adjust the screw inwards until you feel a resistance, then back the screw off about a 1/4 to 1/2 turn, insert the "lock nut" and spring, and install the "plug". Then, using the cable adjuster on the outside of the cover, adjust the cable. Add oil.
Oct 26, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Lost signal
Tv tuners for laptops and desktop computers require amplifier for cable signal please check you are using uhf or only vhf channels then choose the amplifier as they are very cheap like antennae boosters.. The channels with the weaker signal will become avaliable
Aug 06, 2009 | IBM ThinkPad T20 2647 Notebook
I just need to replace tuner on R.C.A. model D52W15 part # 264658
you can get replacement tuners at the following link. Call or leave a email with what youre needing.
http://servicemanuals.vstore.ca/
Jun 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Saab 9-3 convertable antenna will not go up. there is a clickng sound when the engine is turned off and on at the antenna.
antenna mast is no good.. you can buy a mast and have it installed or buy a used antenna and have it installed im sure Elite foreign auto parts has only saab parts.. tested and used,
Feb 17, 2009 | 2003 Saab 9-3
Artifacting pixels w/ over the air antennae
Most of the time the audio sound output is bad
Jan 29, 2009 | Polaroid FLM-3232 Television
2003 Ford Focus radio antenna broken off.
Should be a dome light in the interior that lines up with antennae on roof if it's same as I remember. Remove interior light and there should be screws in there holding base of antennae to roof. If it's just a broke off mast, try to unscrew stud from base & replace.
Jan 10, 2009 | 2003 Ford Focus
52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Dec 29, 2008 | JVC HD-52G786 52" Rear Projection HDTV
RCA D52W17 ANTENNA/CABLE ANALOG INPUT
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
Antennae,1995 honda accord ex
I will take a look at mine tomorrow. Mine stays up because the nylon cord thingy is stripped. No biggy for me though. I have taken it apart so I know it is stripped I just can't remember how it all goes together.
Jul 07, 2008 | 1995 Honda Accord
Tuner problems
it sound like the tuner to me here is rca part# for the tuner 264658 abour $70.00. good luck
Dec 26, 2006 | RCA D52W19 52" Rear Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
