Question about Food Mixers
Bowl lift handle is stuck on Hobart 140 qt mixer. Have to hit with hammer to go up or down
2 Suggested Answers
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
Why wont my mixer speed up to full gear, why is all the tork in the mixer gone, what is the common part that breaks or wears out thus causes this
why are you over loading the machine against the user manual advice
contact hobart for spares or advice on the problem
cut back on the quantity of ingredients in use and make the mixture to the right consistency according to the recipe
if you still have a problem .take it to a hobart authorized repair shop and have it fixed
Dec 13, 2016 | Hobart Food Mixers
HOW DO I MANUALLY LOWER BOWL IF MIXER WILL NOT START?
Trina you might be better off to contact Hobart or an authorised Hobart service agent about this. The lack of answers probably indicates resident hobart experts are absent.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
RESET A HOBART 140 QT MIXER
The V-1401 has a power bowl lift that is belt driven by the same motor that is used to mix. Remove top cover to check the belt. If belt is good and not slipping, is the operator handle working on /in the bowl lift gear box? If not, could be broken shear pin on handle or worn out parts in gear box. Next thing to check is the output shaft of the bowl lift gear box. If it is turning when the operator handle is engaged and the bowl lift jack shaft is not turning there is a broken shear pin between the output shaft and jack shaft. If everything is good to this point the bowl lift yoke has a large brass nut on back side of it that the jack shaft goes through. If the nut is worn the bowl lift yoke will slip, fall and/or jam. to unstick and lower the bowl , one can turn the jack shaft by hand. WARNNING : if the nut is worn enough the yoke can drop suddenly and it is very heavy.
D300t hobart floor mixer
best contact Hobart we have not fixed on here
Oct 09, 2017 | Food Mixers
Was just givin a hobart a200 was in a school warehouse for at least 1o years attach.shaft and seals replaced by hobart 6 month before put in storage runs great smooth no gear noise BUT fromm sitting bowel...
Ogrin56,
The problem is in your lift handle cams, you need to take the pedistal apart and clean and grease all the cams. I take them apart and wire brush them and use white lithium grease to keep them from freezing up.
Feb 26, 2011 | Hobart A200 Stand Mixer
The lever to adjust bowl height will not move.
most of the times it is because of build up between lift handle and pedestle case use wd-40 and even some heat from a torch to help loosen up stuck handle. also wd-40 the ways on the mixer ped. where the bowl yoke is
Dec 15, 2009 | Hobart A200 Stand Mixer
Hobart HZ (h600?) Raising handle is acting up
You will need to confirm the model number. An H600 or L800 have a wheel to manually turn to raise and lower the bowl. The M802 and V1401 hav a belt driven bowl lift clutch, operated by a lever. When you push the lever up or down, you are engaging a small transmission between the motor and main housing. You would need to remove the top cover and see what's happenning. It may be there is something other than the proper spiral pin joining the lift lever to the clutch input shaft, giving alot of backlash and insufficient selector movement.
Aug 18, 2009 | Hobart H600 Stand Mixer
Food Mixers Logo
56 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
