Question about Lexmark X8350 All-In-One InkJet Printer
How do I clean my Lexmark X8350 printer heads?
Have put in new black ink cartridges. Still printing comes out poor. How do I clean the printer heads on this Lexmark X8350. I do not have the guide.
Was able to download the manual at no charge and found solutions on pages 96-98.
Posted on Jan 21, 2009
Put a new black ink cartridge in now it will not print nothing
In most cases the printer driver software can have errors while being in use or is shut down. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected as a new hardware as it will be installed. Now check the printer properties to see the ink levels.
Activate head cleaning before a test is taken . Sometimes it is possible that the head is not reacting to the need of the PC command or can be an issue with ink drying or poor ink cartridge contacts.
Jul 22, 2011 | Lexmark X2600 InkJet Printer
Cannot get the printer to print red
Even after the printer is reset if there no Red on the print then it can be poor ink in the cartridge or a failure in the head track, possible drying of ink.
have the printer head cleaned ,washed and reset. Otherwise it might need a new head or ink cartridge.
Jan 11, 2011 | Lexmark Office Equipment & Supplies
How do I reset the ink level on my lexmark x8350?
http://support.lexmark.com/index?locale=en&segment=SUPPORT&startover=y&userlocale=EN_US&question=x8350+ink+level&productCode=LEXMARK_X8350&page=answers&detectedProductFacet=CMS-CATEGORY_REF.LEXMARK.PRODUCTS.ALLINONE.LEXMARK_X8350&searchid=1280474419390#1
The above is the description page for you Lexmark printer.
Solution
Some menus on the X8310 and X8350 are repeated in the Copy Mode, Scan Mode, Fax Mode and Photo Card menus.
If you press the Menu button while in any of the above menus, two ancillary menus will be listed, Maintenance and Device Defaults.
To select either of these menus, press the check mark pattlnk_442006_155-selects.gif at the center of the navigation keys on the printer.
Maintenance Menu options View Ink Levels Clean Cartridges Align Cartridges Print Test Page Reset Defaults
Device Defaults Menu options Set Date and Time Language Country Copy Paper Photo Paper Photo Size Button Beep Power Save Timeout Caller ID Pattern
The ink levels should reset when the ink jet cartridge is installed.
Jul 30, 2010 | Lexmark X8350 All-In-One InkJet Printer
I replaced the black ink cartridge, it wanted me to run cleaning cycles which I have done several times. I have also run alignment. Still printing very badly. It is a geniune cartridge.
try to dip the half of the cartridge in a luke-warm water for 3 mins. then dry it and put it back inside the printer then try to print again, this really works for most of the ink cartridges.
Feb 21, 2010 | Lexmark X8350 All-In-One InkJet Printer
Printer is not working new ink
Cartridge World stores have a 100% satisfaction guarantee; they will repair, replace, or refund any cartridge you find unsatisfactory. You need to go to the store you purchased this cartridge from and request a new one.
Sep 29, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Lexmark x1270 poor printing
Try these steps after these if you face the same problem then you need to get the cart exchanged as it may be defective as Lexmark cart comes with 6 months warranty ...
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 27, 2009 | Lexmark X1270 All-In-One InkJet Printer
Installed all new ink cartridges and now poor printing results
Dear louis,
You have done right thing by cleaning the print head. If the print head still clogged after repeatedly cleaning, It seems that the print head need to be replace with new one. Make it sure by printing nozzle check pattern. Is it good or not?.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark X8350 jams (and other problems) after ink cartridge refill
You have a paper jammed in the path or there is something blocking the path, try to look inside carefully.
Apr 29, 2008 | Lexmark X8350 All-In-One InkJet Printer
Help - Black not printing
Try cleaning the contact points of the cartridge itself and the unit that holds the cartridge with alchol. If still not printing try nossle cleaning from your printer properties.
Mar 27, 2008 | Lexmark X1270 All-In-One InkJet Printer
Printer doesn't print even with new ink cartridges.
Take out the Cartridge & get a new one if the problem persists then get the printer software reinstalled & if still it is not printing then clean up the cartridge head with cotton swabs dipped in hot water!
This should clean the head & black will be on paper
DO THIS AS FINAL REFUGE
If still its not working then there's some problem in the copper contact surface in the printer on the cradle so get a new Printer.
Mar 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Lexmark X8350 All-In-One InkJet Printer Logo
387 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
