Question about Epson LX-300 Matrix Printer
Epson LX-300 can't print
Please asssist, I have got problem, my computer win xp can't print at all, i have try install at another computer win xp it was worked. Last action i reinstall win xp but i still got same problem. need your help ... jensu
  • 98 Answers
Check your parallel port settings on the XP computer. Compare these setting with the settings on the computer where the printer works. If you are using serial port for printing, then check the serial port settings.
Posted on Jul 27, 2007
SOURCE:
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Epson lx 300 dot matrix printer not printing properly
Make sure you installed correct printer driver and choose the correct model .and remove the pending print job if it is there.
To clear all pending job
In run window type services.msc and the go to print spooler option just stop and restart the service. And switch off and switch on the printer.
Have a nice day and do not forget to rate please...!
Feb 15, 2010 | Epson LX-300 Matrix Printer
Draft Printing with EPSON LX-300 with custom page 10x6 inch in windows xp sp2
You have to install the printer through it installer, it that way the advanced features of the printer will be activated and can be manually configured to what you want.
Click the link to get your driver. download here
Don't forget to rate me, "Fixya"... thanks.
Jan 27, 2008 | Epson LX-300 Matrix Printer
Lx 300+ detected by xp but test page fails
hello,
please go to bios setting and change parallel port type spp+epp or epp or normal try to change type and try again.
Oct 14, 2007 | Epson LX-300 Matrix Printer
Windows xp printer install
Hi, Have you tried the Epson driver "ep10759.exe"? It is available at http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=14250&prodoid=8192&infoType=Downloads&platform=Windows It this still doesn't workout for you, pls post back as to how you connect the 810 to your PC (USB or LPT/Parallel), Good luck and kind regards.
Oct 08, 2007 | Epson LX-300 Matrix Printer
Driver problem
You may have to come to a happy medium on this printer, or, perhaps there is a dip-switch setting (on the printer) needing to be changed. You could also try one of the other Epson printer drivers. Perhaps you can find one which will get the desired results
May 01, 2007 | Epson LX-300 Matrix Printer
Problems installing a printer
You can follow the steps below to install a resident printer driver which is part of your operating system.
NOTE: Windows should detect and automatically install devices attached via the Parallel or USB ports on the computer. You should be able to attach the printer, and the "Plug and Play" feature will install the appropriate driver.
If the driver does not automatically install, please contact your Computer vendor. The "Plug and Play" feature may be disabled within your computer.
The resident driver installation should only be used if the printer is not detected and installed.
1. Start by opening the "Printers and Faxes" window. Click on "Add Printer" on the left hand side of the screen.
2. The "Add Printer Wizard" screen will come up. Click on "Next".
3. At the "Local or Network Printer" screen, select "Local Printer" and place a check on "Automatically Detect and Install my Plug and Play Printer". Click on "Next".
4. Windows should report it will check for Plug and Play hardware. It should also detect and install the appropriate resident printer driver.
5. A window will appear and tell you when the process is completed.
*NOTE: If Windows does not detect your printer automatically, you can manually install the printer. Simply select EPSON under manufacturer and select your appropriate model under PRINTERS.
6. When the printer is installed, it will ask you if you would like to print a test page. Check "Yes", then click on "Next".
7. The next screen will display the settings for the printer. Click on "Finish" to complete the installation and print the test page.
May 27, 2006 | Epson LX-300 Matrix Printer
Epson LX-300 Matrix Printer Logo
587 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
