Question about Samsung HT-DS610 System
No video through s video when using aux ports
When I connect my WII or another auxiliary component to my samsung i do not get any video to my projector. the internal DVD works fine but not from any auxilliary components.
    Problem Solver:
  • 15 Answers
When using aux video inputs we cant get it through s-video output. we can get it normally with RCA cables....
kanny_amancha@yahoo.com
kanny-sounds.blogspot.com
Posted on Jan 27, 2009
Car radio wont work
First make sure that the AUX option is not set to off. Press A.Menu and then Initial Menu. Then select Aux1 or Aux2. Set this to match the type of device connected to the Auxiliary port, (The options are video, audio and OFF.) (When not in use, these should be set to OFF.)
Then press the Source button and try to set the Source to AUX1 or Aux2. If it still doesn't work, make sure that your device is connected to the jack. If that doesn't help, try a different device cable to connect to the Aux jack.
I hope this helps.
Sep 21, 2013 | Car Audio & Video
Where is the auxiliary port in a 2000 Jimmy? It has an aux button but I don't know where the jack is??
hi,
If the car audio player have AUX input selction then there will be a port (stereo RCA) behind the player. Will be named as AUX IN.
ok
Sep 11, 2011 | Car Audio & Video
What channel does my tv need to be on? and what button do i press on my dish network remote to get me to the wii screen
Usually it depends on how you connected to the TV/satellite box- for instance, I have mine set on channel AUX 1 since I have connected my Wii to the TV using the component cables (the red yellow and white cables) to the port AUX 1. If you've hooked it to the Dish box, then it would be whichever accessory you connected is the channel to select in the dish system, but on the channel that your dish is hooked up (it's situational!)
Jun 25, 2011 | Nintendo Wii Console
I have a Samsung 7100, how do I connect my Wii?
Samsung HDTVs of late have a combo component/composite video input. You can connect your Wii using the green/yellow video RCA input on the rear of the TV. For the sound, connect the white and red RCA cables to the corresponding audio inputs on the TV. Make sure not to have any cables connected to the blue and red component video inputs next to the green input. Now press SOURCE using your HDTV remote and select the AV source, navigating down or up to hilight the AV selection. Power up Wii and you should see on your HDTV.
Jan 18, 2011 | Samsung Televison & Video
No video when connecting wii to Onkyo TX-sr507 AUX
Did resolve the issue? I 'm pkanning to buy wii @ my home. Please suggest me.
I do use the Onkyo 507.
Jul 25, 2010 | Onkyo Tx-sr507 A/V Receiver
Can the wii be connected with hdmi cable
As was said, there is no HDMI cable for the Wii. An HDMI cable would be a waste on the Wii, considering the Wii can't ouput 5.1 sound, and can't output 1080P (those are the main benefits with an HDMI cable).
The highest qaulity cable for the Wii is a component cable, which will allow you to output the Wii in 480p (progressive scan) vs 480i (integrated scan). All HDTV's have component inputs, so this is a non issue. Component cables actually can output 720p/1080i, but the Wii can only output 480p max.
Here is a link to the cable I am taking about. You should be able to get it from somewhere for the $20 range.
Nov 13, 2009 | Nintendo Wii Console
Connecting a wii system to a sanyo DP26648 tv
It has to do with the type of input - Video2 and 3 are Component video inputs, requiring a 3- wire component video cable (Red,blue,green for video, red/white below for audio). Video 1 is for analog equipment (Yellow for the video, red and white for the audio). Unless your Wii comes with a component video out cable and jacks (same red blue green), you'll have to use video 1 for the Wii, and use Video 2 for the dvd. You'll need a component video (3-wire) cable for your dvd, which should have the jacks for it. You can use the present cable you're using for the dvd, but you'll have to change the connections on the back of the dvd to component video out, and you'll still need another 2-wire cable to connect the audio out on the dvd to the audio in on Video 2 on the tv.
Here's the manual for your tv - look on page 8 for these connections. the Wii will be an analog connnection, the dvd will be a digital connection.
http://www.sanyotv.com/DP26_32648%20Owners%20Manual.pdf
Hope this helps!
Mar 13, 2009 | Sanyo DP26648-R 26 in. LCD TV
I have the Rx-V661 and I just got the WII. I input the WII into the Video AUX on the front panel and pressed the aux button on the remote and nothign happened.
Just a thought, but, how do you have your TV/Monitor hooked up to the Yamaha unit? If your only connection between the receiver the and the TV/Monitor is an HDMI cable, and you are plugging your WII into the front v-aux jack using composite video, the receiver will have no way to send the video signal to the TV/Monitor. The receiver upconverts all composite video and S-video signals to component video signals. This means that if you only have an HDMI connection between the receiver and the TV/Monitor, you will also need to establish a second, component video connection between the receiver and TV/Monitor to handle the upconverted WII video signal. You will probably also need to switch your TV/Monitor to use that input when you are using the WII.
Of course, if you already knew this and have it set up that way, this answer won't help you at all!
Dec 25, 2008 | Yamaha RX-V661 Receiver
Using Aux Input in a Pioneer AVH-5700DVD
I'm not sure what aux input you're using - but be advised that if you've plugged your mp4 player directly into the RCAs in the back that won't work - those are outputs, not inputs.
You need to use a Pioneer CD-RB10 (or CD-RB20 if you're running a cd changer, XM tuner, or any other IP-bus component) in order to get an auxiliary input.
If you've done that - you need to go to the initial settings menu and set aux input to 'on'. Instructions are in this link, page 89.
Feb 27, 2008 | Pioneer AVH-5700DVD Car DVD Player
Component Video input not working for Video game consoles
Well, as far as I can tell, the WII does work, BUT...is it possible that your choice of INPUTS on the Denon unit may only process 720 or 1080 resolutions and not 480P which is the LIKELY output of Wii ! Can you swap your Xbox to the intended input on your Denon and see if you can set it up with that? If so, that's your problem. IF NOT, then dig into the Video Setup on the DENON a little deeper. We know for a fact the Wii does work correctly, we just need to know if Denon made ALL video Inputs capable of ALL Resolutions
Aug 23, 2007 | Denon AVR-987 Receiver
Samsung HT-DS610 System Logo
121 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
