Question about RTO Atwood Water Heater - 6 Gal LP
Atwood water heater problems
I have have a atwood water heater and when i light it it stays on for a few seconds then shuts off also the ignitor doesnt shut off it keeps trying to light the heater when it is on for those few seconds could this be the modual?
  • Anonymous Mar 18, 2014
    Atwood 6 gallon water heater lights but the sparker keeps sparking even though it is lit and then it shuts off after 4-5 seconds
  • Anonymous Mar 28, 2014
    Atwood propane water heater mod 93756 lights but shuts off in a few seconds electronic ignition
  • 700 Answers
Probly the sensor on the modul. Take and clean it off with emery cloth and then reinstall it.
Posted on Jan 21, 2009
Atwood water heater g6a8e lights but flame goes out after 5 to 10 seconds. I replaced igniter / thermocouple and it worked for a while but problem is back. So I need to replace circuit board?
Make sure you pull connector off and clean it and contacts on board. Be sure igniter is in flame good too. Does it have the thermal cut off in-line? Its the little resistor looking piece inside the plastic cover. If it does, and still running a few seconds and going out, remove it from the circuit, and connect wire end to where you removed cut out from, thus eliminating it from the circuit, and test it. If that cures it, replace that cut-out, as it is a safety device in case of flame up, it cuts gas off to prevent fire. Just leave it out long enough to test it.
Oct 19, 2013 | Atwood Mobile Products Atwood Water Heater...
!990 Bounder By Fleetwood Water Heater is not lighting the propane
Check the gas line orifice for a spider web. Its possible the gas is not able to get past the web.
Nov 30, 2012 | Atwood Mobile Products Llc Water Heaters...
I have an Atwood waterheater model # G6A-8E. I am having issues with no spark from the ignitor , I have used a long stem lighter to light the burner. It lights and burns well for a couple second seconds...
When you turn it on and hear the ignitor clicking, test for 12 volts at power wire to gas valve. If your not getting 12 VDC to gas valve when ignitor is sparking, replace module.
Jul 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
My atwood 6 gal water heater gas with electric light comes on and runs for a few seconds then goes out,if i turn the switch on several times it will stay on.can you help with this problem? thanks
Try cleaning the electrode that sits in front of the flame, as well as adjusting it,if necessary to make sure it is in front or at least in position that it senses the flame well.
Feb 16, 2010 | RTO Atwood Water Heater - 6 Gal LP
Atwood GC6AA-9E water heater isnt working properly
The ignitor is also a flame sensor. If it's not working to ignite, good chance it's not sensing flame to keep gas flowing as well. Could also be board.
Sep 09, 2009 | RTO Atwood Water Heater - 6 Gal LP
After a few minutes of burner heating the water, gas shuts off.
A couple of things to check:
If possible, remove the pilot gas assembly and clean the gas jet and thermocouple - they can get carboned up and stop working properly. Make sure the pilot flame and deflector is aimed properly and making the thermocouple glow red hot. If the problem persists, you may want to replace the thermocouple and also check the propane regulator.
Apr 20, 2009 | RTO Atwood Water Heater - 6 Gal LP
RTO Atwood Water Heater - 6 Gal LP Logo
919 people viewed this question
Top RTO Water Heaters Experts
Jim Goldsmith
Jim Goldsmith
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
