Question about Xtreme Sound WMS230 Cassette Player
Burned the in line fuse on my expedition.
I let my teenager try to replace the battery in my expedition and he hooked put the battery leads on the wrong terminals long enough to burn out 2 wires that are protected by a cover that says in line fuse and now my radio doesnt power up at. Every thing else in the truck still works just need to know how to replace that in line fuse. Can I just cut open and splice a new fuce in or what. If there is manual please let me know the name or if I can just cut and splice that would be col. Or if they sell a in line fuse at like auto zone or some thing. Thanks
  • Dan Cole
    Dan Cole Jan 21, 2009
    Just got done looking at in line fuses on the net and none of them look like what is in my truck. I can nt just by the fuse straight or bladed and replace it. Mine just looks like 2 separate wire with a long snap together plastic cover. Wires look to be hard wired from positive battery lead and run off some where into the fire wall I assume the radio since it is the only component that does not work any more. It is a stock radio but I do have a after market alarm installed but the alarm still works. Thanks
  • Dan Cole
    Thanks but its not that kind of fuse. Its just a bunch of wires with a plastic clip together case over them. Thanks
  • 333 Answers
The cover of the fuse shouhd twist off so you can replace the fuse.
Posted on Jan 21, 2009
How do I hook up my subwoofer and amp to my ford f150?
to hook up the amp. drill a hole in the firewall, run an 8 or greater gauge cable (greater, depending on the wattage of the subwoofer amplifier) from the battery positive lead, thru the firewall, to the amp power +, and be sure to place an in line fuse within the engine compartment, within a foot of the battery. hook the speaker up, and then run the amplifier negative lead to a bare metal part of the cars chasss, and, finally, hook the amplifier remote power lead to the acc circuit of the interior fusebox (i usually just take the acc fuse out, stick the wire in the acc fuse receptacle, then re-insert the fuse to complete the circuit).
to run the radio signal to the amp, you can use a speaker to line level converter (if stock stereo). just splice them into the stock stereo speaker leads
Apr 15, 2016 | Car Audio & Video
1997 Ford Expedition 4 wheel drive 5.4 Triton hook up the battery wrong and tried to start it now it does nothing no clicks nothing
you burned up alot of something,now you need to get a voltage tester and check all wires,replace the solenoid first and then find the fusable links and replace them.
May 28, 2015 | 1997 Ford Expedition
Blowing 20a fuse
Broken or shorted line or relay
Apr 16, 2014 | 2010 kawasaki Super Sherpa
Changed battery cables now subwoofer isn't working in my 1997 ford expedition
Check the fuse for the power wire for the amp. Up somewhere by the battery in line of a red cable leading to the battery post.
Apr 10, 2013 | Cars & Trucks
No electrical power
you might have burned out the new switch
Mar 30, 2012 | Garden
Battery not getting charged although the alterator is putting out.truck will run but kills battery after its been charged with a charger....gosport1@hotmail.com is my email.
Does it die while running? Check the voltage at the battery with the truck running to see if it is getting the same voltage that the alternator is putting out. Will it not start after sitting for a bit? It could just be a bad battery not taking a charge because the lead plates or the terminal inside the battery is broken. You may also have a drain on the battery that is discharging it. You can check for a drain by disconnecting the negative cable and hooking a test light in line between th negative battery terminal and the cable. If the test light lights up bright, there is a drain and you can start pulling fuses one at a time to see what kills the light.
Apr 08, 2011 | 1999 Ford Expedition
Battery was going bad so my son tried to help me jump start it but he connected the leads the wrong way(positive to negative) and the horn was blaring and took me a few seconds to figure out what he had...
It can be worse if the fuse at the main link is not blown out. so check to trace into the main line, the ignition circuit. check the main fuse box and the inside compartment fuse box.
You will be lucky if any electronic circuit is not burned out specially the ECM.
Must try to use a good tester to trace and check before the battery is connected.
Feb 05, 2011 | 1998 Ford Expedition
I need wiring color code for 97 Ford Expedition
red/yellow leads from the 5amp fuse #29 and red/white leads from 5amp fuse #2. Both of these run into the instrument panel. Let me know if you need more info.
Jan 25, 2010 | 1997 Ford Expedition
Xtreme Sound WMS230 Cassette Player Logo
330 people viewed this question
Top Xtreme Sound Car Audio & Video Experts
Aaron Hackbarth
Level 1 Expert
Are you a Xtreme Sound Car Audio and Video Expert? Answer questions, earn points and help others
