Question about GE Profile JT912 Electric Single Oven
My oven does not work at all.
My electric wall oven does not turn on at all.  The clock is not on and none of the  buttons on the unit will turn on. we unpluged it to see if it was the outlet. but it wasn't the outlet is working fine. Help
  • 333 Answers
Put a lanp in the same outlet that the stove is hooked to, If the lamp does not light then you popped a circuit breaker for that line. If the lamp works then you blue a fuse that is probable in the control panel of the oven. I hope this helps
Posted on Jan 21, 2009
None of the buttons are working and clock is not displaying. Just happened last night after use and the only thing working was fan.
Um, is the fan working now? No? >> check power to oven
Circuit tripped? >> check for electrical fault / mice in wires
Oct 16, 2013 | Maytag 30" Built-In Double Electric Wall...
Probe light on convection oven stays on. Clock won't display. Oven still works though.
Sounds like the control board is not communicating correctly with the rest of the unit, consult a professional.
Aug 10, 2012 | Frigidaire 30" Built-In Single Electric...
The stove top works fine .Both of the ovens stopped working and there is no digital display where the clock is . Where is the fuse located for the ovens
Normally, there is a master switch on the wall near the oven. This is in turn is usually fed from its own fuse/breaker on the consumer unit. I suspect this has bblown.
Jul 18, 2011 | Stoves 720EF Electric Double Oven
Our monogram double wall oven has a f7 code on the control panel. None of the buttons appear to be working, except clear, which clears the code. Then still no buttons work, and the f7 code comes back. What...
It's most likely that the error code you are seeing is F1, not F7. F1 is a code for 'stuck touch pad'. You will need to replace the clock/ERC or the touch pad (or both).
Feb 28, 2011 | GE Monogram ZET3058SHSS Stainless Steel...
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Cant set cooker clock so cant use oven as a result
You will probably have to replace the cooker clock. Do any of the other parts work? This fortunately is not that expensive and you were blessed not to have more damage than this.
Jan 29, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Whirlpool electric oven
hi switch main power off at wall. hold middle clock button in and switch power back on at the wall. Display should show --:-- and oven should work.
Nov 30, 2007 | Ovens
GE Profile JT912 Electric Single Oven Logo
82 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
