Question about Riccar 4812 Vacuum
Need parts list for Riccar 4812
I need to replace the motor bearings on the Riccar 4812 vacuum an need a parts list.
2 Suggested Answers
rockmeister
  • 2047 Answers
SOURCE: Problem with Riccar 8850 Vacuum There
Hello there, when sparks come flying out of your vacuum cleaner it usually is as a result of messed up connections and power fluctuations.The probability of the motor needing replacement is very high as unless i examine it i cannot say for certain but one thing i can say for certain is that the entire wiring of the unit has to be inspected thoroughly because this is where the main problem would have emanated from. The unit would definitely need other components other than the motor changed this is because if the other components which have been affected dont get replaced then even a new motor will face the same problem after a relatively short period. best refer the unit to an expert to determine the extent to which the other components are affected and what other parts are damaged. Also to determine if the entire motor needs replacement or some part of the motor can still be salvaged.
Hope this support has been helpful?
Thank you for visiting FixYa.
Posted on Sep 08, 2011
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
Looking for a parts list / manual to replace the motor
You will need to purchase the motor from a Riccar dealer. If you don't have a local dealer contact me at thatvacguy@gmail.com
Jan 21, 2016 | Riccar 8650/8625 s Vacuum
How to replace motor on 8925 riccar vac?
There is not a motor bushing on a Riccar 8925, it has sealed bearings. There is nothing that needs to be timed or adjusted in the motor.
Jul 17, 2014 | Riccar 8925
Replacing off switch
Remove the screw holding the handle to the body of the vacuum. Remove the screws to separate the parts of the handle to gain access to the switch.
Feb 01, 2014 | Riccar 4812 Vacuum
Replacing riccar 4812 hose
To replace just the hose unscrew it from the swivel attached to the back of the vacuum. The replace swivel insert screwdrivers into the tabs holding it to the body (from inside the dust compartment) to remove it, the new one snaps into place.
Jan 03, 2014 | Riccar 4812 Vacuum
Reset button power
Reset switch is located on the back of the vacuum and close to the back wheels.Press a reset switch a few times and vacuum should start. Check also cord plug . Many times metal prongs are broken at the end of the cord (usually one of them)
Nov 28, 2013 | Riccar 4812 Vacuum
Where can I get replacement wheels?
Greetings from GoVacuum.com,
I just wanted to let you know that we are an authorized Riccar dealer, and we can certainly get the replacement wheels for your Riccar 4812 upright vacuum cleaner.
We stock some parts, and what we don't stock we'll order for you. We don't currently have the wheels on our site, but if you still need the wheels, you may email me at chris.jones@govacuum.com.
We do stock a lot of parts for your 4812 Riccar, including the following;
Riccar 4000 Series Bags That Fit the 4812. Paper Bags 12pk.
http://www.govacuum.com/ricc103.html
Riccar 4000 Series Exhaust Filters for the 4812 Part RF4-2;
http://www.govacuum.com/ricc117.html
Riccar 4000 / 8000 Series Drive Belts Part # A20-R2P
http://www.govacuum.com/ricc112.html
Foam Filter Underneath of Bag Riccar 4812 Part B622-0500
http://www.govacuum.com/ricc133.html
I look forward to helping you if you still need to get the wheels for your vacuum.
Thank you,
Chris J.
GoVacuum.com
Jan 11, 2010 | Riccar 4812 Vacuum
Won't come on when I plug it in. Does it have a
Greetings from GoVacuum,
Yes, the Riccar 4812 does in deed have a reset switch. Unfortunately some dishonest repair man will tell you at this point that your motor has gone, but 7-10 times it's the reset switch.
If you look down at the base of th vacuum cleaner at the vacuum bottom in the back, right above the rear wheels, you will see a small red button. Take a ball point pen, and while the vacuum is plugged in, go ahead and push the red button or the reset switch. Did the vacuum come on?
If not, it may another simple problem of the cord/ plug going bad.
I hink if it just stopped workint all or a sudden, it's prbably the reset switch.
If it's not, please email me or give me a call and I then diagnose the problem for you.
Chris Jones
GoVavcuum.com
1-866-468-2288
Nov 27, 2009 | Riccar 4812 Vacuum
Belt on Riccar 8850 is slipping off motor shaft.
NO! there is usually a fan attached to the motor. i have found that junk gets in there and will cause it to viberate. otherwise check the brushroll. there will be connectors on each side with a bearing. if the plastic looks melted, replace the brushroll
Jan 12, 2009 | Riccar 8850 Vacuum
Vacuums Logo
74 people viewed this question
Top Riccar Vacuums Experts
Chris Nomland
Chris Nomland
Jim Parker
Jim Parker
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
