Question about Kenmore Refrigerators
Kenmore elite model 795.77563600 front water dispenser not working
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
  • 92 Answers
SOURCE: ice maker not working
make sure its turned on check the wire connector is seated and check to make sure there is nothing jambed in the tray if all that is ok call for service
Posted on Feb 10, 2008
SOURCE: New Kenmore Elite ice dispenser not working but water is
ther is no ice comming out, it suddenly stopped. Kenmore Elite I dont know whats wrong with it I know that water may not be getting into it but how do I solve this problem
Posted on Jul 13, 2008
  • 6 Answers
SOURCE: Kenmore Elite - Interior water dispenser stopped working
Frozen water tank, some of these had an insulation kit that will prevent this from happening. Make sure you have water coming out of valve to tank, if so it will probley be a frozen tank. Make sure fridge is on factory settings. If it doesnt thaw out, check into the frozen tank kit...
Posted on Aug 07, 2008
  • 14 Answers
SOURCE: Replacing the Ice dispenser motor on Kenmore elite refrigerator?
There is a small door under neath ice maker shelf (literally) w/ 2 small screws that keep it in place,or a button that can release ice maker on the rt. side of machine. Good luck!!
Posted on Apr 04, 2009
Managemylife com sears
Either the cylenoid to let the water in is bad.
Or the hose from the dispenser to the drum is clogged.
Most common with powder detergents.
Some really hot water poured into the dispenser may
solve the problem.
Aug 21, 2014 | Kenmore Elite 45986 Front Load Washer
Water leaks out of the soap dispenser of my kenmore elite front loader and all the soap or bleach us not out
The 1st thing to try is to take out the dispenser ,there is a little piece that you will push down and then pull the entire assembly out, rinse it out with hot water ,most likely there is a build up in the dispenser,there after use only powder detergent, and no more then 1 tbs ,and any other stuff IE bleach ,fabric softener,use 1/2 the amount and dilute it with water.
Jul 20, 2014 | Kenmore Elite 45986 Front Load Washer
My kenmore elite HE, smart pack is not dispensing the fabric softner? Can you help?
The softener water flow is clogged. You know, open the dispenser while it's filling in the final rinse and look over the softener dispenser. Is there water flowing?
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
DOES THE THIS FRIDGE MODEL #106.74912401 REQUIRE TO REPLACE WATER FILTER FOR FRONT DOOR WATER DISPENSE?? ITS A KENMORE ELITE
HI. When a filter has reached its filtering limit, it must be replaced. Once the filter has reached its filtering limits, it will not allow for proper water flow. This will affect the operating status of the dispenser. With that being said, there are other issues that will affect the dispensers abilities as well. These issues are a faulty water inlet valve assembly, and frozen inlet lines. If you are having issues with the dispenser, make sure you inspect these areas as well. Your filter should have an installation date on the label. check to see that it is not over a year old. if so, it should be replaced.
The filter is located behind the front lower grille work. The grille should have a cut out space for it to slide into.
Nov 12, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Kenmore Elite HE3 Washer fabric dispenser not working
This is usually just as simple as adjusting the syphone up and down. releveling your machine or cleaning the dispenser itself. when the water enters the dispenser gravity syphones the water out . nothing really machanical about it. unless the water is not filling up the cup enough to go above the max line. you can test it by putting water in the dispenser above the max line and adjusting the syphone cap up and down.this should grab a suction.
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore elite washer model 20952992 pouring water
We had the same problem. The bleach dispenser tray is located on the drum below the bleach storage pan. The dispenser tray has very small holes that were plugged by rust from the hose clamp that attached the dilution water supply hose to the bleach storage pan. I removed the top of the washing machine to discover the problem, but it may be solved by attaching a flexible tube or small hose to the end of a vacuum cleaner hose and cleaning out the dispenser tray. There is room between the dispenser tray and the storage pan and is located in the front right corner.
Dec 10, 2008 | Kenmore Elite HE4 Electric Dryer
Ice and water dispenser lock light stays on and comes back on quickly after pushing and holding. No water or ice dispensed while light on. Kenmore Elite 23.1 ft side by side refrigerator
I resolved the problem on my Kenmore Elite model 106.55616400 by removing the drip tray, taking out two screws that hold the panel, and disconnecting and reconnecting the wires from the panel to the board. Unplugging the refrigerator did not work.
May 28, 2008 | Kenmore 25.1 Side-By-Side Refrigerator...
Refrigerators Logo
35 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
