Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Recall on kenmore elite model 795.77563600 ice maker
fanny
  • 146 Answers
SOURCE: Kenmore elite (106.53606202) ice maker will not dispense ice
When you push the ice dispensing lever, you should be able to hear the micro-switch clicking. If no click, the switch is faulty. The auger motor which is activated by the lever could also be faulty. This is the motor that causes the auger in the ice bucket to rotate one way for crushed ice and the other way for cubes. The auger could also be jammed. Try switching between crushed and cubes to unjam the auger. Empty the ice bucket and start again.
Posted on Nov 03, 2007
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
huuum
  • 750 Answers
SOURCE: ICE CUBE MAKER SMELLY ICE CUBES
Hello margrek
Welcome,
YOU SAID, YOU HAVE KENMORE ELITE BOTTOM FREEZER WITH ICE MAKER THE ICE CUBES SMELL HORRIBLE ALWAYS, I EVEN TOSS THEM OUT EVERY FEW DAYS, STILL SAME PROBLEM
Ice has bad odor and taste.
1• Ice has picked up odor or
flavor from strong food stored
in refrigerator or freezer.
2• Water running to ice maker
has poor taste or odor.
3• Ice not used frequently enough.
4• Cover foods tightly. Discard stale ice. Ice maker will
produce fresh supply.
5• Add filter to water supply line. Consult a water purifying
company.
7• Discard stale ice.
Huuum
Please remember to leave a rating!
Posted on Oct 12, 2008
  • 11 Answers
SOURCE: Kenmore Elite ice maker is not working & red light is blinking
Most likely a problem with the main ice making unit itself. I bought mine at ebay for $49 including shipping. Very simple to replace. You just swap the wiring harness and bottom plate. Takes about 20 minutes to do.
Make sure you do the IR led test. If you think you IR sender and receiver are bad to, $57 on ebay for the set. Most likely not your water solenoid in the lower back of frig (it gets the signal to turn on from the receiver module of the IR board.
Probably not your water filter (cuz the front water dispenser still probably works right?)
And probably not a clogged or frozen line.
Good luck. When it doubt, trust ebay!
Posted on Mar 16, 2009
Kenmore elite fridge recall
I could not tell you without a specific model number. You might try doing a web search for your refrigerator's model number and the word "recall." I assume the refrigerator's warranty has expired, or you would not be asking about a recall.
In the meantime, talk to your Sears service manager and see if they will make an accommodation for you on the ice-maker repair. Sometimes companies will give a courtesy extension on a warranty if the problem occurred during the warranty period, but the warranty expired before repairs were done. However, since you do not mention requesting repairs to the ice-maker before the end of the warranty, you can't expect much joy there.
Sep 09, 2014 | Refrigerators
Kenmore Elite Trio 795.77563600 Ice Maker Not Working
Try putting ice inside instead. if the machine gives you water then it's converting in reverse order.& still working. put the machine upright & youi'll get ice...
Jul 29, 2010 | Kenmore Refrigerators
Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker: just bought a kenmore elite model 795. I t says i...
Look for a lever to select cube size right on the icemaker.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 18, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker not working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
fdfdfs43
Apr 19, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite side-by-side ice maker creaking!
Look behind the freezer rear trim panel for frosted/iced evap. coils and thaw if necessary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 29, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite Trio Model 795.7757960 - Error Code 'IF'
Hi!!! You have a control board problem.Change the control board and you should be okay..Them boards did'nt come out good.Good luck..
Jan 04, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
Sep 22, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
273 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
