Samsung 32" screws for base won't tighten - Televison & Video
2 Suggested Answers
SOURCE: we purchased a HDLCD 4050
To Fricker923, on May 13,2011. I had the same problem with the screws. The display model in BJ's had a lose base, but I didn't heed the "warning". I got home, instructions mentioned black screws and silver screws, all were silver color, just 3 shorter and 3 longer. So I followed instructions, could not tighten the smaller screws enough to make the stand secure. Piece of **** stand, DO NOT BUY THIS TELEVISION, you will have to return it, or watch it fall off it's shoddy stand. Taking mine back tomorrow. Sad, because the hookups on the back were numerous, the color on the set was good and the price was great.
Posted on Aug 09, 2011
Citoborma 150 operation
you need to replace the scrow & use a shorter one
Apr 26, 2013 | Cars & Trucks
Samsung Optical Drive SE-208 tray rattling won't eject
if you look on the drawer you will see a little hole.push a pin in the hole and the drawer will open.
Nov 15, 2012 | Samsung Optical Drive SE-208AB/TSBS...
Bosch SHX33MO5UC terminal screws won't tighten.
The screw threads are stripped.
Jan 13, 2018 | Dishwashers
Tension screw won't tighten the chain on a Stihl MS660
remove the cover and look to see if the tab is broken off
Apr 14, 2012 | Stihl Models 064, 066, Ms640, Ms660
The focus knobs wouldn't retract the eyepiece and so in my infinite wisdom I tried to unscrew the whole eyepiece assembly by loosening the 3 screws that appeared to attach it to the main body. Well...
Focusers can be replaced and or upgraded-- you disassembled the focuser-- you will need to reassemble it properly -- you might have also messed up the screw threads in the holes and may need to try using a slightly larger size screws. Your local hardware store will have them.
www.telescopeman.org
www.telescopeman.us
www.telescopeman.info
Jul 29, 2011 | Tasco 49114500 Spacestation(r) 114mm...
Faucet handle on Monticello model came off---how do I get it to tighten back on the hub. Received new adaptor kit, but how do I attach handle to the base?
If it's a shower valve there is a small hole on the underside of the handle. There should be an allen key that came with the kit. Use the key to tighten the screw.If there is no key then I think the size is either 1/16" or 1/8". The handle should point down when installed and in the closed position.You can turn the handle for easier access but if it's a Moen Posi-temp this will turn the water on. Stand to the side so you don't get wet. If it's Moen Moentrol you must pull it to turn the water on so if you turn the handle without pulling it you won't get wet. If the allen screw is missing then there should be one in the kit you have.
Jul 15, 2011 | Moen Home
How do you assemble the stand to the tv
This is a pretty easy job.U have the four Philip screws that came with the tv base stand wright?U have a Phillip screw driver wright?Just put the base stand into the tv make sure all the screws holes lines up between the tv and the base stand holes.Than just tighten the Phillip screws with the Philip screws driver,than u are done.
Jul 14, 2011 | Samsung LA40A450 40 in. LCD TV
We purchased a HDLCD 4050 and the stand is very loose and won't tighten. the instructions say it's supposed to come with 3 black screws and 3 silver but they were all silver. Reguardless, they will...
May 13, 2011 | Sansui Televison & Video
How do I install the base stand?
Just put base stand into a hole of the main LCD tv unit at bottom base hole and make sure all the screws holes lines up.Put in those holes with 4 or more philips screws on those holes and now just used a philip screw driver turn it clockwises to tighten those philip screws for it to hold on to the base stand.
Feb 05, 2011 | Samsung LN46A530 46 in. LCD HDTV
Removing the base on a tv
There are 5 screws on the back of the TV under the inputs in an x pattern:
X X
X
X X
Remove these and set aside. You should also see 2 screws on either side of the X pattern, loosen these. You should then be able to slide the TV off the base. Remember to re-tighten the loosened screws. Place the removed screws in the base in case you ever wish to use it in the future.
Nov 30, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
64 people viewed this question
Top Televison & Video Experts
