Question about Nokia Classic 2700 Cell Phone
How to unprotected SD micro memory card - Nokia Classic 2700 Cell Phone
Cara mengganti imei nokia
Posted on Jan 23, 2013
SOURCE: i forgot the password of micro sd card
256MB micro memory card was locked.. password forgot. how to open card
Posted on Sep 22, 2009
murmerjoy
  • 805 Answers
SOURCE: forgot password for transcend micro sd
formate it
Posted on Jul 19, 2009
SOURCE: my nokia 5130 xpress music is not responding if any memory card(micro sd) is inserted
there is the virus in the card. scan it and deldte the virus
Posted on May 31, 2009
nikeananth
  • 267 Answers
SOURCE: how to unprotect micro sd memory card password
Try to format the MMC Card:----
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called MMC store.
3. Send it to your PC directly and open it in notepad or rename the file.
4. At the end of the file you will find your password. Thank you Sir, Have a nice day.
If above doesn't avail, Try dailing *#7370#
harit1988
  • 149 Answers
SOURCE: my nokia phone micro sd memory card is locked by
if u have not so important data , you may format if from the command prompt of your pc . if the data is important try with any software available to open locked cards.
Posted on Jul 04, 2010
Forgot my Nokia 3110c micro SD sandisk 2GB memory card password
SORRY! BUT THERE IS NO GETTING AWAY EXECPT TO FORMAT MEMORY CARD,
CAUTION- WHOLE DAT WILL BE LOST
ADVANTAGE- PASSWORD WILL ALSO BE DELETED, AND YOUR MEMORY CARD WILL BECOME PASSWORD UNPROTECTED
WWW.TINYURL.COM/9307740
May 05, 2014 | SanDisk 2GB microSD Memory Card
Unprotect memory card
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 15, 2013 | Sony Ericsson XPERIA X10 Cell Phone
I just bought a Medion Action HD Videocamera (MD 86543). Now the SD-card is full. I am not allowed to delete the photos or video. It says that I have to unprotect the SD-card for writing - but how to
Hi John ,
you might have to go out and buy a flash drive that hold a micro sd card so you can plug it unto oyur computers USB ports, you can pick these up for under a fiver.
also you could try putting the micro-sd card into your mobile phone if you have one and format the card from there.
Hope this helps.
Dec 29, 2012 | Computers & Internet
How do I unprotect images
SD and Micro SD memory cards has a small slide switch on the edge of the card, which write protects data on the memory card or add photos to the SD card. Slide the switch from the LOCK position to the UNLOCK position, which is furthest away from the contacts.
Dec 23, 2012 | Canon EOS 450D Digital Camera
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
How do i unprotect my memory card from a canon 450d?
Thanks for using Fixya.
Every SD card should have a write protect switch located on the right edge, about 5mm from the top of the card. In order to unlock the card, slide the switch upwards.
Note that with Mini SD and Micro SD (Transflash) these switches are not present. The card is always unlocked. A switch may however be present on an SD card adapter.
Because of the position of the switch they can often be switched accidentally on inserting or removing the card.
Rating the solution is highly appreciated.
Apr 14, 2010 | Canon EOS 450D Digital Camera
My pc say that i got to unprotect the songs that i want on my micro sd but i dont know how
there is a tab you need to move on the sd card. One side protects your info, the othes side allows you to move or delete info.
Oct 24, 2009 | PNY 2GB microSD Memory Card
Iam trying to download music on my sandisk micro card and it keep saying card is protected unprotect or use other disk
If you look at your micro sd card check for a switch that you can move. Move it in the opposite direction of that it is currently in. If this doesn't work try to change the switch on your sd adapter as well. If this still doesn't work switch the micro sd switch back to original state and try again. One of the cards has the lock activated. You just have to figure out witch one.
Please rate!
Cheers
Sep 28, 2009 | SanDisk 2GB microSD Memory Card
How to unprotect the memory card
On most sd cards there is a physical (tiny) sliding switch on the memory card. Here is a picture of a standard SD card. On the left you can see the gray switch in the unlocked position. Hope that helps. -WN
4bfc547.jpg.
Jul 27, 2008 | Nikon Coolpix 4600 Digital Camera
To set the memory card in unprotected mode, you have to do the following.
On the side of the SD chip, there is a little switch. Shift the switch away from "lock", then insert the card back into the camera.
This unprotects the card. You should now be able to take pictures and videos.
If this does not solve the problem, then it is very likely that the SD card is faulty. I would recommend using Panasonic, Lexar or Sandisk memory cards.
~Lexar SD card
~1 Panasonic SD card
~2 Panasonic SD card
~Sandisk SD card
Jul 13, 2008 | Panasonic Lumix DMC-FZ30 Digital Camera
Nokia Classic 2700 Cell Phone Logo
44 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
