Question about Singer Touch Sew 7462 Mechanical Sewing Machine
Singer touch and sew 7462 pedal keeps beeping and wont start
Not sure what i am doing wrong, but the pedal will not start. Instead, it beeps when i place (even the slightest) pressure on it. What's wrong?
dupina
  • 110 Answers
SOURCE: singer 7462 sewing machine
There is two seperate cords on this machine. A power cord and a pedal cord. If you put the power cord in and switch the machine on, and then remove the pedal cord it should give you a beeping sound, which shows you the connection does work.
Please give me feedback in order to help you
Posted on Dec 08, 2007
  • 106 Answers
SOURCE: Singer model 7462 sewing machine
Sounds like there is thread around the bobbin winder shaft and the machine is unable to continue winding, needs stripping and looking at. This is not something you should attempt yourself unless you know what you are doing. A reasonable sewing machine tech should be able to sort it out in a few minutes.
Posted on Mar 28, 2008
SOURCE: Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Posted on Nov 03, 2008
  • 27 Answers
SOURCE: Wont Start (brand new) Just Beeps!
make sure the bobbin winder is not engaged and thread the machine over ,also check that the buttonhole switch is not down
Posted on Jan 10, 2009
  • 240 Answers
SOURCE: Singer sewing machine beeps and wont repond to commands.
Sounds like you may have a blockage somewhere in the bobbin area that needs cleaning as this is normally what happens when it gets jammed. Reverse sewing can sometimes cause jams. Remove bobbin area and reassemble.
Posted on Jun 11, 2009
When I try to push on the pedal, I get only a beeping sound and no action. Can you advise on this situation?
Make sure that your bobbin is full, not empty or wound uneven. Go to singerco.com and see if it is listed in the frequently asked question or in the manual.
Sep 12, 2010 | Singer 7462 Mechanical Sewing Machine
The machine is beeping and does not start. It
Is your button hole lever down? I had the same problem after sewing a button hole and couldn't figure out why I couldn't return to normal sewing. Once I raised the button hole lever the machine worked again.
May 22, 2010 | Singer 7462 Mechanical Sewing Machine
The sewing machine beeps and wont sew when you press the pedal.
check to make sure machine is threaded correctly, expecially bobbin area
Dec 04, 2009 | Singer 7462 Mechanical Sewing Machine
Mar 17, 2009 | Singer 7462 Mechanical Sewing Machine
Singer Confidence 7470 does 3-4 stitches, then beeps and stops
ring up or go to where you bought it from. They should be able to tell you.
Sep 13, 2008 | Singer 7462 Mechanical Sewing Machine
Button Hole Beeping on 7462
Yes frustrating issue this one. I discovered that you need to pull down the retractable button hole guide found behind the needle threader (not visible when you are sitting at the machine).
Hope this helps, happy sewing!!!
Sep 06, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 7436 beeps - not working
Check to be sure the buttonhole lever is in the up position and the presser foot is down. Check feed dogs to be sure they are in the up position.
sewman7
May 26, 2008 | Singer 7436 - INGENUITY
Singer 7462 sewing machine
Dec 08, 2007 | Singer 7462 Mechanical Sewing Machine
Singer Touch  Sew 7462 Mechanical Sewing Machine Logo
70 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
