Question about Weber Q Grill
Soot generated by Weber Side Burner
Side burner works fine but the burner cakes soot on the bottom of cooking utensils.
SOURCE: Low flame/ side burner dosen't light
I just read this online and it worked for me. Hope you have similar luck.
Newer propane tanks contain a self regulating feature that will automatically slow down the flow of fuel if it thinks it's too high. This can be solved by turning the tank valve off completely and disconnecting it. Open the control valves (on the grill control panel) and ten close them. Reconnect the fuel tank and slowly turn on the valve. Now light the grill to see if that fixes it.
Posted on Jan 27, 2008
SOURCE: uneven heat from burners
I'm experiencing the same problem, the left side has the least heat, and it seems to be getting way worse over time.  Has anyone found a solution for this yet?
Posted on May 17, 2008
SOURCE: Weber Genesis Gold B Grill Problem
Could be partially clogged burner openings (jets).
Remove the cooking grates and the flavorizer bars. Obtain a BRASS brush (like used to clean white-wall tires) and brush the burner tubes from side to side and up and down along their entire length to remove all corrosion from the jets. Also the cross-over tube.
Before replacing the flavorizer bars and cooking grates, ignite all burner tubes and check to see the flames are all of about equal length and intensity.
If this isn't the problem, check the screens at the right-side ends of the burner tubes to be sure they're not clogged.
If the burner tubes are all clean and some don't ever ignite, the problem could be in the valves/manifold.
Posted on Jul 18, 2008
SOURCE: Weber Grill, Genesis Silver A Burner Replacement Instructions
Thanks for your inquiry. In checking around, new parts will cost me $45- $50, plus your fees for instructions and several hours of my time. I checked prices at Home Depot today and have decided just to buy a new grill and enjoy it without all the mess.
Stu
Posted on Sep 11, 2008
SOURCE: cannot get good flame on the burner of my baby weber grill. I've tried cleaning it checked hose, tank, regulator, seems to have good flow, but low flame only, even when set in high????????
I had this problem with a brand new grill so it wasn't grease in the hose. Due to the new propane regulators you have to turn the propane tank on for at least a minute before turning the grill to light. Let the tank sit in the light position for five seconds and then you light the grill. This will keep air from getting into the intake hose and will keep your gas flame roaring high.
I was only able to get the grill up to 250 degrees before I found this fix posted on the Weber site. It is listed as the number one solution in the FAQ section.
Posted on Oct 13, 2009
HOW to get rid of yellow flame
have to adjust the air ratio , but without a make who knows , perhaps a gas repairman
Dec 01, 2015 | Kitchen Ranges
Why is there black soot on gas stove burner? What can be done to resolve this issue? Can it be cleaned or does it need to be replaced with new burner valve?
I recommend you have gas company or appliance service. Gas is nothing to "fool" with. It sounds like a fuel (gas) air mixture problem. Have you "cleaned" underneath the burner recently and by chance not re-installed the burner properly? Or someone else? Double check. If you see something obviously wrong, correct it. Otherwise as above.
Mar 06, 2015 | Kitchen Ranges
The gas company red flagged my water heater because of black soot being produced. What could be causing the black soot?
A properly adjusted gas burner does not produce soot. your burner is defective. call a plumber to get it serviced or replaced.
Nov 18, 2014 | Heating & Cooling
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Burner is sooting when grilling with soot on the meat
clean the burner and gas orffice check to see if burner is split if so change it
May 13, 2010 | Grilling
When the model 41 comeson it makes a woolf sound..also the window is sooted up..can you help?
If the burner mat is loose it will make that sound. A loose burner mat will also cause a soot problem. The soot can also be caused by too little air flow thru the burner.
Jan 15, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
1 burner flares and sputters
Hello. Chances are that something on the stove boiled over or got poured into that burner. take it off, soak it overnight in water with dishsoap added, then rinse it and let it dry before reinstalling it. Repeat the soaking in soapy water if necessary until the flaring, sputtering and black soot is gone. regards, Joe
Dec 14, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Black burner
theres no danger.its the residue from the gas.if using propane,it burns very dirty and leaves soot.if natural gas its the same but not as bad.you can simply just wipe them down with water but use an old rag because the soot is very dirty.if using an electric oven/burner the discoloration of the element is from the heat and is normal.also if the oven is gas the soot will eventually clog the holes/orfices in the burner and it will cause some issues.hopes this helps--let me know.
Jan 24, 2008 | Maytag MER5770 Electric Kitchen Range
Weber Q Grill Logo
32 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
