Xerox colorqube 8870 leaves several vertical oil lines on the paper when printing. I can see the oily irregularities on the black drum which pulls the paper but don't know where they come from. It started happening when the last few original maintenance kits were freshly installed.
2 Suggested Answers
  • 117 Answers
SOURCE: XEROX Phaser 8560 - Maintenance Kit
They sell a lot of maintenance kits that way.I worked for a major Tampa are copier company for 10 years and they used every part until it just quit.However, you should line up a maintenance kit at the ready.Sometimes a counter will shut down the copier when it gets to the point where they want it to stop.
Posted on Apr 07, 2009
I'm getting error 94,7000.00:114.36 on my Xerox 8570 Printer. It sounds like a lot of spinning on the maintenance kit when I boot it. Any suggestions?
The error is a Process Drive Fault. This may be a problem with the Process Drive's Gears.
You probably need to go through the replacement procedure again.
Xerox says to check if they are in their home positions. NOTE: Usually, manually tilting the head back and forth using Drum Maintenance Shaft should leave the Process Drive aligned.
Sep 12, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Xerox problems
Hi Anonymous,
I suspect your question has answer by now.
If not, just visit the www.xerox.com website.
Regards.
Jul 29, 2014 | Xerox STANDARD CAPACITY MAINTENANCE KIT...
Xerox errors
Ink contamination use clean ink smears several time to clear, if that doesnt work replaceing the in resevior is the only option
Jul 22, 2014 | Xerox Corporation Xerox ColorQube 8570DT...
Xerox printing all black pages
You have no light output. The system places a charge, the image will remove charge (without image processing, the system leaves full charge ) (removes charge where no image is if negative processing)
EX: a copier has platen closed makes a copy because the cover has a white surface the light is reflected and removes charge from Drum. If you make a copy with platen open out put will appear black. Charge was not erased, toner is attracted to charged area.
Most systems use a small wire to place charge, depending on what development (pos or neg) with broken wire will also result in either a black or blank output. I would look for a broken charge wire.
Mar 05, 2014 | Xerox Corporation Xerox ColorQube 8900X...
Samsung scx-4521f xerox and printout taken a black vertical line appear on the paper
black vertical lines are generally an indication that the imaging drum needs to be replaced
Nov 25, 2011 | Samsung SCX 4521F All-In-One Laser Printer
My M15i Xerox Workcentre is printing with a vertical line down the page
Solutions for : Vertical Black Lines on Copies When the Automatic Document Feeder and Document Glass are Used Solution : Clean the Drum
  1. Make sure there is paper loaded in the paper tray.
  2. Press the [Menu / Exit] button on the Control Panel.
  3. Press the [Up] or [Down] arrow button until 'Maintenance' is displayed on the Display Screen.
  4. Press the [Enter] button. 'Clean Drum' will be displayed.
  5. Press the [Enter] button. 'Cleaning Drum Please Wait' will be displayed and a sheet of paper will be printed. Toner (Dry Ink) particles on the Drum will be affixed to the paper.
  6. Repeat steps 1 - 5 until the page prints without any Toner particles.
Aug 13, 2011 | Xerox WorkCentre M15i Laser Printer
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
360 people viewed this question
jasbo
jasbo
