Question about Nintendo Wii U
My wii u picks up our internet signal, but will not connect. error 103-1003
5 Suggested Answers
  • 27 Answers
SOURCE: Wifi connection
maybe you had it in to long just let cool down for a few day because you had it in for a few weeks
hope this helps
Posted on Jan 23, 2008
  • 22 Answers
SOURCE: wii internet connection
This is appearantly a common problem with the Wii. I got this information right off their Support Website. Error Code: 50231
The Wii console's internet connection settings have not been configured yet. In order for the Wii console to connect online, you must first go through a quick setup process to connect to your home network.
If you need assistance, we can walk you through the process using our step-by-step guide that allows you to follow along. Please click here to begin.
I hope this takes care of your problm.
Posted on May 12, 2008
shizmo
  • 94 Answers
SOURCE: error code 109144 when try to connect to internet via wii console
Error Code: 109144 There was a problem registering the console to the WiiConnect24 service. What to do:
  • If you have multiple routers and/or modems, try to connect to no more than one router and one modem try connecting from another location.
  • If you are using only one modem or router, something on your network or from your Internet Service Provider is blocking the connection. You may need to contact your service provider for more information.
  • If you do not have the ability to connect from another location (such as a friend's house), please call 1-800-255-3700 so that we may discuss available options.
Posted on Feb 01, 2009
  • 1234 Answers
SOURCE: trying to connect to internet
Error Code: 52230 There appears to be an issue with your wireless router's firewall.
  1. It is possible that your Internet Service Provider (ISP) is not compatible with the Wii console. For instance, if you need to login with a user name and password when you try to go online for the first time after restrarting your PC, your ISP is likely not compatible. Please contact your service provider for more information.
  2. If this error occurs regularly, while you are playing at home, it is likely a connection problem related to your firewall settings. For more information on firewalls, click here.
  3. Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Posted on Aug 25, 2010
Unable to connect to the Internet Confirm the Internet settings of the wii console. Error code 50299.
Go to internet options on your Wii settings, select internet, and then connection settings. Once that is done you will be able to see the wifi connection. Click the wifi connection and delete it. Try to reconnect the Wii to your wifi router and you should have success connecting to the internet. If it doesn't connect repeat the steps listed above.
Dec 31, 2014 | Nintendo Wii Console
I cannot connect my Wii to the internet. Is there a part that I need to connect, or is there something else that I need to do in order to get the wireless connection working?
Here is a step by step instruction on how to connect your Nintendo Wii to the internet. Please note that connecting the Wii to the internet does require a wireless connection, or wireless router for a signal.
http://www.nintendo.com/consumer/systems/wii/en_na/getOnline/index.jsp
copy and past this into your internet browser.. if you should receive an error for any reason, here directions and a link to solve it.
Error Code 51030, 51031, 51032
    It appears that your Wii console's Internet connection may be affected by wireless interference. Try the following:
    • Change your wireless router's channel to 1 or 11
      Changing the wireless channel on your router may help. Most wireless routers have a channel range of 1 through 11. The best channels to try are usually 1 and 11, as they do not overlap with other channels. Typically, the channel settings for your router will be found in the router's main "Wireless" tab.
    • Where is your wireless router located?
      Move your router away from walls and off the floor and try to place it in a central location in your home. Also, keep it away from metal objects such as metal filing cabinets which can cause interference.
    • Look for other devices
      Noise from cordless devices (cordless phones), or wireless electronics (wireless keyboards, headphones, cell phones), especially those using the 2.4GHz frequency, can interfere with your wireless signal. Also, older microwave models can cause wireless interference. Avoid electronics that use the 2.4GHz frequency, instead look for devices that use the 5.8GHz or 900MHz frequencies.
http://www.nintendo.com/consumer/systems/wii/es_na/windows/error51030.jsp
Sep 03, 2011 | Nintendo Wii Console
How do I set up the Wii to the internet?I keep getting error code 51031
Hi.
That error code is usually linked to your Wii's MAC address not being added to the MAC accepted list on your router.
To do this it depends on what router you have, but for most, you can have a direct link from your computer to your router.
Open a internet browser and go to (192.168.0.1)
On most routers this will be its set up page, you have to go to the wireless page and add your Wii's MAC # in there.
Your Wii's MAC address is located in the 'Console information' Wii page
You should just do this after your done....
1) Power on your Wii, go to the settings menu (by clicking the little Wii button in the channel menu)
2) Scroll over to 'internet settings'
3) Select 'connections', and pick 1, 2, or 3
4) In there select 'search for wireless access point'
5) Pick your router, enter your key (password) for your router if you have one.
6) Test the connection
Regards.
Jun 08, 2011 | Nintendo Video Game Consoles & Games
When watching a movie using my wii console. everytime i log on the internet w/ my computer. I loose wi-fi connection to the wii. and get an error code 52230
Error Code 52230 means that your router or Internet Service Provider is having difficulty assigning a DNS or IP address to the Wii. What this usually means when you had a connection and it drops is that you aren't getting a clean signal connection between your router and your console. First step, unplug your modem and your router wait 30 seconds and plug them back in. If that doesn't work:
Various factors affect connecting a Wii to the internet with a WiFi connection as well, including signal strength, distance from the wireless router to the console and obstacles such as walls and ceilings that interfere with the signal. If you're using a G router and you have your Wii too far away or, has obstacles (walls and ceilings) in the way, it will not connect. You should use an N-Router if there is a significant distance between the console and the router or if there are obstacles.
In your case it could be the wireless adapter on your computer is interfering with the Wii. Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker.
May 11, 2011 | Nintendo Wii Console
How do you connect the wii to the internet?
Ok. If you have internet at your home already then, what you need to do is go to the main menu where it shows all the "channels" you have. At the bottom left will be the wii options menu click it, go to wii settings, click the right arrow once click internet, click connection settings. Pick which connection you want it doesnt matter which one you pick. So click one and if you have wireless internet click wireless and click search for an access point and your internet connection from your house should show up if not that is something wrong with the router not the wii at all. Save the settings and click ok for connection test if asks for a wii update hit no and then when it takes you back click at the top use this connection and you will be good to go with the connection
Hope I Helped and Explained without issues NoobTerminator aka Manchild
Mar 26, 2011 | Nintendo Wii Console
Error code 32002
From the Nintendo Website -
Error Code: 32002
Lost connection during Wii system update
Likely causes: Your Internet connection has slowed or was interrupted, or our servers could be busy.
Verify the following:
Slow or incompatible Internet connections can "time out" and result in this error code. Are you using a broadband Internet connection such as DSL, cable, or fiber optic? Other, slower types of connections, may not be compatible. Click here for more info about compatible connection types. Try the following:
Check for wireless interference, which can affect the signal strength to the Wii console. To help minimize wireless interference, try the following:
Make sure other wireless devices such as cordless phones or wireless speakers are turned off, and that the Wii console is an open area without objects or electronics blocking the signal. (For instance, if the Wii is placed in a crowded entertainment center, try moving the Wii somewhere with more room.) Change your router's channel setting to 1 or 11. By default, most routers broadcast on channel 6, which overlaps with other channels and may be weaker. For help doing this, click here and select your router brand and model (if available). The information you need is found in the "Broadcast Channel:" area. Manually change your Wii console's DNS settings. To do this, follow these steps: Access the Wii system settings (how to), and use the right arrow twice and select "Internet." Select "Connection Settings," and choose the connection file (1, 2, or 3) that are you are currently using. Select "Change settings" and click the right arrow 3 times to reach "Auto-Obtain DNS." Select "No," and choose "Advanced Settings." Click into the "Primary DNS" field and enter: 8.8.8.8 Click into the "Secondary DNS" field and enter: 8.8.4.4 Please note: These are public DNS's provided by Google and are subject to Google's Terms of Service. If you prefer to not use this service, doing an Internet search for "public DNS" will provide you with several other options you can use.
Select "Confirm," and then "Save." Select "OK" to start the connection test. Once the test finishes, try to download the update again. Our servers may be busy, especially if a new update for the Wii system is available. Wait at least a couple of hours and try to download the update again. If after waiting several hours you are still receiving this error code, please call 1-800-255-3700. If you are still getting this error code after trying the steps above, please call 1-800-255-3700 for further assistance.
Mar 19, 2011 | Nintendo Wii Console
Can you connect the wii to internet using a verizon usb internet connection no cable or wi fi
It is not possible to stick your usb in to your wii and let it connect on to the internet. However, you can plug it into a computer, which makes it give off a wireless signal. Your wii should be able to pick up the signal, so you can then connect to the internet. If your not sure how to configure the wii to connect to the internet, email me at murkwood17@hotmail.com
Nov 29, 2010 | Nintendo Wii Console
I cant connect my wii to my wi-fi
are you trying to play via wireless internet? if so you might not be getting a strong signal. if possible buy a ethernet to usb adabter for the wii. you can get them at bestbuy or anyother major electronic store. but you usually cant find them at walmart. this will guarantee a strong internet conection
Jul 31, 2009 | Nintendo Activision Guitar Hero World Tour...
Error messages when updating Wii with my wireless connection
Maby the place youre wii is put. I had to put my wii in a higher place.
Jul 14, 2009 | Nintendo Wii Console
Wii Wi-fi Internet Connection
A Wii has a macc address just like any other networked element. Do you have mac-address filtering turned on? If so, you may have forgotten to enter your Wii mac address in the list.
Hope this fixes your problem!
Jan 03, 2008 | Nintendo Wii Console
Nintendo Wii U Logo
115 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
