Question about Mr. Coffee FTX251
I plugged it in added water pressed brew now but nothing happens
Is there a trick or something im not doing right? i have no manual
    Genius:
  • 1,199 Answers
Your doing it right! I think it has a broken heating element and thats why there is no brewing going on!
Please rate this response and help us keep this area free!
Thank You!
Posted on Jan 21, 2009
Why did our keurig b70 just quit working?
Try unplugging it for 30 sec. and plug back in. Give it time to reset. Hope this helps
Feb 05, 2018 | Keurig Platinum B70 Coffee Maker
Cuisinart dcc 3000..set to self clean and nothing is happening? Both the cleaning light and power light are on. How long does the cleaning process take or is there something wrong with the coffee maker.
Press the "CLEAN" button and it will light up red. Then press the "ON/OFF" button which will light up blue. Be patient, nothing happens right away, but the cycle has begun. In a few minutes the water reservoir will begin to empty. This self-clean/decalcification process takes approximately 30 minutes. Then pour the water/white vinegar solution out of the coffee reservoir, rinse the water and coffee reservoirs and run one cycle of fresh cold water through before using to brew coffee.
Sep 17, 2013 | Conair DCC-3000 - Cuisinart Coffee on...
Platinum B70 sometimes won't brew
I also have the same problem. Is there a pattern here?
Jun 11, 2010 | Keurig Platinum B70 Coffee Maker
After getting Replace Water Filter VEntilate display I replaced with Saeco Intenza water filter cartridge I have always used. However, unit does not move off this display after I press OK button. I have...
After replacing the filter in the tank, keep the button pressed; when the indicator light is flashing, then release the button.
Also at times, the gears in the brew drive assembly will not complete the cycle to the proper start position for different reasons. Some of the reasons are:
  1. Brew group jammed or blocked.
    Note: A jammed or blocked brew group can happen when the brew group starts the cycle but doesn’t finish it.
  2. Either one of the micro-switches in the brew drive has gone bad.
  3. Brew drive motor failure.
  4. Broken teeth on either of the brew drive gears.
  5. Dirty brew group, covered by coffee grinds.
  6. Brew group or gears not lubricated.
  7. Connections to the board from brew drive assy., or motor have gone bad
Oct 08, 2009 | Saeco Incanto Classic Espresso Machine
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
New Saeco Odeo Go has solid red exclamation mark, doesn't budge
You have to 'manually' prime the pump: When the red exclamation mark shows, press the water switch on the right side (the picture of the water drip), then open up the steam nozzle and let the machine pump hot water into a cup until the red light goes out.
Jun 11, 2009 | Saeco Odea Go
Flashing water light - will drain water but will not make coffee
Something is wrong on the coffee cycle side of the machine. Check the brew unit screens and and try doing a preground cycle with out inserting coffee. IF water comes out, I would looking into your grinder a little bit and try increasing the grinder size.
Espresso parts and service
www.cerinicoffee.com
Dec 08, 2007 | Saeco Magic De Luxe Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Jim London
Jim London
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
