Electrolux Frontloader washing machine problem
I have an Eelectrolux front loader washing machine about 18 mths old Mod EWF1087 which keeps on flashing up an error code E90
Any idea what to do fix the problem?
  • 326 Answers
This indicates the problem with the faulty control panel circuit connections.check out and replace the control panel board
Posted on Jan 21, 2009
  • 4,472 Answers
Error 90 is a common fault code in domestics within the Electrolux, Zanussi, AEG range. It's a wiring fault /connection normally between the printed circuit board and wires. switch off power, remove lid, pull off each connector on board checking for clip holding the connector in place, one at a time, look for arcing marks, rub pins gently with clean cloth, tension up clips in connector(delicately) and refit. having done this, test again with a wet load on spin, then a wash programme. Before despairing check the motor connections.
If you need further assistance please let me know, also take a moment to accept and rate my solution accordingly.
Thank you,
  • Lee A.
    Lee A. Jan 21, 2009
    It should be bad connection in communication wires. should be group of 5 wires that are blue and they come off the main pcb board and connect to the display board of the fascia panel.
    Thanks and enjoy,
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
Electrolux frontloader washer detergent drawer won't stay shut
Hello royal37 - Hi - The dispenser drawer could either be cracked or have a broken latch due to interference between the drawer front and top panel. Contact a professional to move forward accurately and might possibly need to order a service kit (PN: 137146000/part number may be different depending on your model number).
Feb 13, 2013 | Electrolux EWFLW65H 4.7 Cu. Ft. Washer
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
Nov 05, 2011 | Electrolux EW1000i Front Load Washer
Front loader washing machine EWF1087 stopped half way and did not drain, E50 was displayed. Emergency emptying out the water was done and try to restart. Could not start, still displaying E50. What to do?
the error code E50 indicates that the motor has become overheated, you should give it an hour to cool then try running the washing machine again. I'm also including a link to pdf below with the common error codes for your brand of washer in case you have any other problems
Jun 17, 2011 | Electrolux Washing Machines
Hi I have an electrolux front loader model number E/EWF1087/W I switch it on and all the green lights flash and I have an error code reading 'err90'. Can you please tell me what this is and can I fix it...
Sorry to read about your problem, I hope this helps you out.
e90, means a bad connection. at the main control board.
you can try to open the machine and check a and clean all connections to the main board.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Electrolux EW1000i Front Load Washer
How to change door seal on electrolux ewf1087 frontloader
My electrolux EWF1087 is leaking water from the front door, I cannot see any damage on the door seal although I never noticed its folded over and full of dirt. Do I need a new seal ?
Oct 03, 2009 | Electrolux Washing Machines
Fridgedaire frontloader error code E10
I think you still have the factory warranty, please connect the company which you bought your wash machine.
Jul 03, 2008 | Washing Machines
Washing Machines Logo
174 people viewed this question
Top Washing Machines Experts
