Question about Mitsubishi Televison & Video
Power Loss please check the time and reset if necessary. How do I do this?
Replaced bulb in the DLP tv and when I went to turn it on, it stayed on for about 15secs and powered itself off. The message it showed was, Power loss please check the time and reset if necessary.
Slinteriors
  • 8617 Answers
SOURCE: rca 50 in dlp tv.
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 29.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs. This manual contains step by step procedure for troubleshooting Your RCA DLP Light Engine
http://servicemanuals.vstore.ca/
Posted on Jan 15, 2008
SOURCE: PT-50DL54 panasonic 50" DLP
This also worked on my Pt-52DL52 Panasonic also by pushing the Blue action button on the remote and the volume down button on the TV. But first wait until the replace bulb warning light is off, then do it.
Posted on Feb 17, 2008
  • 184 Answers
SOURCE: Dark picture on lg dlp tv
Did you use a generic replacement? Many TVs have a dark picture after replacing the original lamp with a generic. The other issue I've encountered are TVs that have been exposed to cigarette smoke will develop a dark, discolored picture over a relatively short time.
michtech
Posted on Feb 19, 2009
  • 2318 Answers
SOURCE: how to reset a panasonic dlp lamp hours?
Try the following:
If you need to get into the service menu, you can do so by following these directions:
With power on, hold down VOL minus button on projection display and hold down the PIP or SPLIT button (try both) on the remote simultaneously for more than 5 seconds.
You can also click here to get more instructions if the above do not work. See post # 4.
Posted on Jun 17, 2009
  • 336 Answers
SOURCE: I have replaced the bulb but still it will not
Hi,Sometimes its something simple.Did you close the door cover,it has a switch that wont let lamp power on if its not pressed.Did you reset the lamp timer? you can do this by unplugging the tv wait 5 min and plug it back again.Any strange noises like clicking or buzzing sounds? If you heard clicking it will be an issue w the board that powers the lamp its called the ballast.If you heard buzzing it could be an issue with the color wheel,which is a small disc that creates tyhe colors on your tv. Last question did you get the Original Philips lamp or a generic? If you got a generic send it back for testing or get refund and get yourself the original.Email me if you have further questions at r2d2repair@gmail.com have a blessed life!
Posted on Nov 17, 2009
Power light blinking red..tv won't come on after replacing lamp
DLP TV Repair Tutorial - DLP Bulb Won't Turn On - YouTube
? 14:13
https://www.youtube.com/watch?v=5frOnh58Z6M
Jun 26, 2013 - Uploaded by ShopJimmy.com
DLP TV Won't Turn On Common How to Replace Ballast DeadTV ... solid green power light plus sound ...
• New Lamp Doesn't Turn On? Try This! - Fix Your DLP - FixYourDLP.com
www.fixyourdlp.com/forum/viewtopic.php?t=19
Mar 12, 2009 - 50 posts - ‎36 authors
Mine did the same thing after replacing the lamp. ..... TV won't turn on and Color Wheel is GOOD, Temp sensor is GOOD, Ballast is GOOD, and ... • NEW Bulb- still not working
Jan 14, 2010
• Resetting the Samsung DLP Lamp Counter/Hour Meter
Mar 20, 2009
• Samsung Dead Lamp, Black Screen, or Intermittent
Mar 12, 2009
More results from www.fixyourdlp.com
Samsung DLP: replaced lamp however tv won't turn on - HDTV ...
Dec 09, 2015 | Televison & Video
Tv turns on and off 3 times before picture appears
Ballast Board its what turns Lamp on Call Encompass or visit their website. 1-800-638-3328
Dec 14, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Samsung DLP seems to turn itself off
HI, this is a weak power board that is causing this shutdown. there is a faulty IC on the board that is unable to correctly distribute the necessary power throughout the set at this time.
Simply replacing the power board will fix this issue. This is not a do it your self so, we recommend a professional service tech for this repair.
Jun 07, 2009 | Samsung HL-S5087W DLP TV
New bulb/TV still shuts down
Its far more likely the result of the power pwb capacitors that have failed. As the 34 code will appear if the capacitors fail on the Power PWB. You can get the V26 DLP Power repair kit at the following link.with free instructions
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Apr 30, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Buzzing noise from Mitsubishi DLP WD-52327 after replacing bulb
Did your replace lamp come on the screen or did you lose picture? Just because the LED indicator suggest replace lamp it doesn't mean it needs it. If your pix was dull or loss of brightness then replace it, if not then just reset your lamp timer, check your owners manual for instructions.
Feb 14, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Toshiba DLP Model 50HM66
You, more than likely, need a new lamp
Jun 08, 2008 | Toshiba 50HM66 52" Television
ERROR CODE 34 on Mitsubishi TV
I just had the same issue with my TV (dont know code), but the issue was with the power supply.
Feb 16, 2008 | Televison & Video
Televison & Video Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
