Question about Welding Tools
Murex transmig 500
Mig welder no amp controll
CarlGehrke
  • 169 Answers
SOURCE: electrical problem with mig welder
Call Lincoln Electric (the manufacturer) at 216-481-8100 and ask them to email you one.
please rate my answer,
Carl
Posted on Dec 03, 2008
  • 3 Answers
SOURCE: mig welder tripping power supply
the breaker could be bad. try to change the breaker
Posted on Jan 16, 2009
luxur4
  • 92 Answers
SOURCE: lincoln mig welder
Check the earth clamp, make sure all the cables or in good condition and secured, if the unit is three phase, get an electrition the ensure all the phased are functioning. test the fuses with a meter, get back to me if all is OK
Posted on Jan 23, 2009
luxur4
  • 92 Answers
SOURCE: need wiring schematic for miller 140 wire feed welder
No problem,email, write or phone for this information, Miller personel are very obliging as are most Welding manufacturers.
  • 4 Answers
SOURCE: WILL THE LINCOLN SP125 MIG WELDER WELD ALUMINUM AND STAINLESS?
The mig welder should be capable of welding aluminum not stainless but the makers should be able to give you more detail. mig is used for steel and aluminum normaly but I do not know this transformer
Posted on Apr 08, 2009
Can you reverse the polarity on a old cig transmig 195 so you can use gas less wire
Some do work that way . as for your machine we do not know .
Jan 29, 2016 | Welding Tools
How to reverse polarity on transmig 195 for gasless wire
just take the lead for the wire and attach it to the ground terminal and attach the ground wire to the + terminal
there will be diagrams in your user manual and if you don't have a manual then go google and type in--- user manual for mig welder 195 model( model not included in your question)--- and there will be a psd version to down load
Dec 30, 2015 | Welding Tools
Why does wire weld to tip when trigger is pulled when welding aluminium
The tip of the welder may need cleaned out, your feed speed might need slowed down, check the polarity is it straight or reverse?
Sep 20, 2014 | Welding Tools
Murex transmig 405s
The contactor that controls the power to the tip (the heavy one) may be fused closed This interupts power to the primary winding if tip goes live without wire feeding.
. It may also be a shorted SCR on the control board if wire is feeding or it can also be a fused feed motor contactor- the small one.
Sep 24, 2012 | Welding Tools
Hi, I have a murex tradesmig 160, when welding its like it loses its earth, but earth ok, some times get a good run, and then wont work. feeds wire but no power.
Look inside the unit (make sure the set is unpluged from the wall socket) and check the bolt that secures the cable to the socket, remove the bolt and clean the earth lead and the socket, check that the cable is ok and tight when refastend.
Oct 20, 2009 | Welding Tools
I am looking for a parts manual for a Transmig 300 MIG welder
This is the closest thing I could find,its more like an owners manual www.murexwelding.co.uk/mrxcont/arc/Instruction%20Manuals/Transmig%20300%20&%20350C.pdf
Jul 23, 2009 | Welding Tools
Wire feeds too quickly
Some welders control wire speed with the amps control, some control amps with the wire speed control. You might try turning things up until it runs smoothly without pushing back. If you're new at welding, it does take some practice until it feels right.
Jan 15, 2009 | Hobart Handler 140 Mig Welder
Welding Tools Logo
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
